Question about SanDisk Sansa e250 MP3 Player
No display on sansa e200
When turned on the screen of my sansa displays a black 'splotch' and then disapears as though turned off. On switching there is no display. Only the Volume light (blue light) glows
  • 2,071 Answers
This is a common symptom of defected LCD,you must replaced the LCD so its works better again.
Hope it may help you;
Regards,
VOTIT
Posted on Oct 10, 2008
WHEN I TRY TO SWITCH ON MY SANSA, FIRSTLY IT DISPLAYS REFRESH DATABASE AND THEN THE DISPLAY GOES OFF.
Having gone over a month with no response, I assume the suggested reset procedure solved the problem.
Aug 13, 2010 | SanDisk Sansa e200 MP3 Player
Blue/Yellow Splotches on screen
It will be 12 appliance years old in October. Not much justification for trying to repair it.
Mar 23, 2017 | Sony KDF-E50A10 50 in. LCD HDTV
My sansa e200 is frozen
this could mean the screen is burnt out not that it completely broken or that its not turning on.
Jun 22, 2009 | SanDisk Sansa e200 MP3 Player
Sansa e200 load main image failed
If this happened after updating your firmware, the Sansa FAQ from here http://www.sansa.com/support/sansa_e200/faqs says try this -
03. "Load image failed" appears after updating e200 firmware Applies to the following Operating Systems:
  1. Windows XP, Vista
This error may be caused by the firmware failing to load or the file system is corrupted.
STEP 1 – Reset the player
  1. Press and hold the Power button for approximately 30 seconds.
  2. Turn the player back on.
If the error persists, proceed to steps 2 and 3.
STEP 2 – Connect the player in Recovery Mode
  1. Turn off the player.
  2. Slide the Hold/Lock switch on top of the player so an orange color is showing.
  3. Press and hold the REC button and connect the device to the computer.
  4. A message will appear on the device display screen confirming the connection and a 16MB partition will be viewable in My Computer.
  5. Release the REC button.
STEP 3 – Download and update the firmware
  1. Download the firmware from the Sansa Forum.
  2. Open the zip file
  3. Extract all the firmware files to the 16MB-FORMAT drive.
  4. Disconnect the player.
  5. Slide the Hold switch to the unlock position.
  6. Turn on the player
Dec 29, 2008 | SanDisk Sansa e200 MP3 Player
i'm thinking that it has too much info on it, so it ets stuck when you turn it on.
Jul 31, 2008 | SanDisk Sansa e260 MP3 Player
Black splotch - no good - probably indicates LCD screen damage and will require replacement
But, you can try the "soft" fixes just in case:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Jul 08, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e200 6MB does not start correctly
1-866-726-3475 Sandisk Customer Support
www.sandisk.com
click on support at the top; click on MP3 players,
find your Sansa and click on it there’s a lot of info
Mar 26, 2008 | SanDisk Sansa e200 MP3 Player
Sansa e 200
my sansa e200 is having some problems the ring is lite up but the screen is black i tryed alot of things nothing is really working can you please HELPPPPPP me pleaseeee
Feb 21, 2008 | SanDisk Sansa e200 MP3 Player
It is not turning on
User guide is located here; http://www.sandisk.com/Retail/Default.aspx?CatID=1400 Best of Luck.
Sep 21, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
78 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
