1)I have a sharp Aquos LC-52D62U, when I plug it into power source,the power light starts to flash green, and the screen does not turn on at all. Pressing the power button does not turn the flashing powerled off. I have to unplug the power cord to power it off. _________________________________________________________ 2)I also have the Sharp Aquos LC-37GP1U. when I power it up, I hear a click noise from the power bord. The power light stays on solid green for few minutes but the screen does not turn on, the OPC and the power lights starts to blink green.
  • avelillab Mar 16, 2009
    SHARP AQUOS LC-37" has the same problem, it turnos on, there's a sound of the monito clicking, then it doesn't show image, it just shows a green falshin light over power and OPC... how to fix it?
4 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Posted on Dec 15, 2007
VOTIT
  • 2071 Answers
SOURCE: POWER AND OPC LIGHT BLINKING GREEN
The condition of your TV called power supply overcurrent shutdown that"s why you hear a click. The TV is going into a protection mode to prevent further circuit damage. That's why it will not turn on or not powering up. I would concentrate on the power supply section board. Bad regulation of the incoming voltage could caused this issue although,there is a capacitor across the incoming line and nuetral.Maybe its leak or dry up and cause the problems,change it out with one of identical rating . Although now you are getting into dangerous area,especially if you have no electronic experience background. It could be also be a loose ,crack or cold solder joint,a blown fuse,fusible links or other component .It could be one of several boards.Unfortunately the level of sophistication on these TV make it virtually impossible to diagnose them further without taking them apart and probing around with a multimeter and other tools.This TV is handy enough to take to a repair shop find a good one.You will probably have to pay $75 to $100....
Hope this may help you..
Regards,
VOTIT
DON'T FORGET TO RATE:
Posted on Oct 10, 2008
milten1
  • 1304 Answers
SOURCE: MY SHARP AQUOS LC-32D44U NO
hi
the flashing green light is tellin g you that is not recieving a single, on that channel, be it the cable connection, or the cable.
try changing to a seperaqte input, like AV1 or something similar,
it may just turn out to be that particular input that is lost
unless your good with soldering and working with electronics this is a repair that should be done by an expert honestly....
but like i said check your other inputs,
if your within your warenty I would call Sharp, they are very good with customer service and have never let me down
Posted on Oct 25, 2009
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
Sharp lc-52d62u with sound and no picture. OPC and power lights blinking.
Sounds like lamp problem. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 01, 2015 | Sharp AQUOS LC-52D62U 52in Widescreen LCD...
Sharp Aquos LC-60E79U has flashing green power light and OPC light but won't turn on
Try to I unpluged the power, push volume and channel down, pluged power again
While it's flashing unplug your TV from the main power source for 15 seconds,Then press Valume Up and Channel Up, while holding it plug the TV back in, you should see the TV Turn on. How to Reset Your Sharp LCD TV TV Repair
Jun 15, 2013 | Televison & Video
Sharp AQUOS LC-26P50E television. Stuck on 'Standby'/'Sleep'
Ur power ic inverter board is dead.
U need a new one.This prob.very comon with SharpThe Sharp corp. is a joke,never release much of this part for sale.It almost imposible to find it.
Sep 05, 2009 | Televison & Video
My (sharp aquos lc 52d62u) tv fell to the ground. Image of broken glass and colored lines appear
Unfortunately the panel is cracked internally can't can't be repaired the whole panel has to be replaced. most times the panel will cost as much as you paid for the set. My son cracked ours when it was only 3 weeks old it doesn't take much force to ruin one.
Rustym62
http://www.the-tv-dude.typepad.com
Apr 26, 2009 | Sharp LC-52D62U 52 in. LCD HDTV
Sharp Aquos wont turn on
this is either a power problem or the screen needs re-gasing
Jan 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp AQUOS LC-52D62U LCD TV
Sharp lcd screens are very easly damaged especially the larger screens,this could be at fault even though it looks ok,try shinning a light on the screen and checking every inch,could be the internal screen that has damage hence why not powering up.
Failing that it sounds like an internal short.
Apr 20, 2008 | Televison & Video
Blinking power light.
i hve the same problem. I turned on my Sharp Aquos lc-32d62u HDTV last night for the first time, but it is black and a blinking green light.
did you find a solution?
Mar 06, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Televison & Video Logo
110 people viewed this question
Top Televison & Video Experts
