Home | Air Conditioners | My Teco TC-20 Hea...
Air Conditioners
Problem for Air Conditioners
Generic problem for all Air Conditioners
My Teco TC-20 Heater-Chiller has
By jkeyhome on Oct 10, 2008
My Teco TC-20 Heater-Chiller has stopped working (no display) I have explored possibilities through TecoUS and have tried changing the fuse and also a reset using the pins as described on the following website .. http://www.tecous.com/files/TECO_Seachill_Reset_Guide_(all_models).pdf .. all to no avail. It is possible it was not turned off when the water flow was switched off. If that is so would it not have fused the fuse or is it possible it has cooked something else. Or could there be another cause? Jonathan
Popular Solutions for Air Conditioners
Questions and Unsolved Problems for Air Conditioners
Answer
Looking to replace a 20 yr old Weil-McLain with a dependable, efficient oil-fired boiler for a... (More)
Answer
Our Quality: We believe that our customers should receive the highest quality Hp dv1000 battery at... (More)
Answer
How do I get the remote control to operate only 1 of my 3 air conditioners instead of all 3?
Answer
2004 toyota highlander climate control temperture switch need to find the part anywere but the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Air Conditioners:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
