Question about HP Photosmart 475 InkJet Printer
Pink screen and error message 0000009
Doesn't seem to be an outlet problem. Any other ideas?
  • Anonymous Dec 14, 2008
    I also have a pink screen and the same message.
My daughters pink vtech innotab touch screen seems to be off, it doesn't register the icon she touches, instead it opens the one across the screen from it. Screen calibration seems off, how do we fix...
I have the same problem, i tryed the calibration from support but IT wasnt help home ask And wolume down when i turn it on. Any one did that.
Mar 28, 2012 | Toys
I HAVE A FUSER ERROR 122.06,122.05 AND 122.06 ON A LEXMARK C540 HOW DO i CORRECT
A 122.05 or 122.06 Fuser error indicates that the printer/MFP has detected a problem with the fuser unit. A service call will probably be required to solve this issue. However, certain rare occurrences, such as a power fluctuation or a static discharge in the vicinity of the printer/MFP, can cause a false 122.05 or 122.06 error message to appear. In such cases, the error is only temporary and can be easily resolved without service.
Try perform the following steps:
  • Power off the printer/MFP, wait 30 seconds, and then power it on again.
Did the error message return?
  • If possible, connect the printer/MFP's power cord directly into a grounded wall outlet. In rare instances, a surge protector, extension cord or uninterruptible power supply (UPS), can generate false error messages. Verify also if the printer works on a 110 or 220 volts source. Make sure that the power outlet matches its working voltage rating.
If this doesn't resolve the error, I suggest you contact Lexmark Technical Support.
Oct 17, 2011 | Lexmark C540N PROD SPECS TBD Printer
Lexmark Z55
does an error message appear on the computer screen?
Jul 03, 2008 | Lexmark JetPrinter Z55 InkJet
WorkCentre XE90FX copy service error ?
Most likely the fuser sensor is out of its mounting or the actuator is.
That's really difficult to get out, Have to disassemble the machine. If you do that make sure you have the proper torx tools and patience.
Not the easiest machine to work on. be very careful disconnecting any ribbon cables. The on to the scanner is easily damaged.
Jun 07, 2008 | Xerox WorkCentre XE90FX Laser Printer
White's are pink
ya,this is CCDproblum replace ur ccd
Mar 24, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
FX-160 not working
Check your voltage in your area or check your outlet it may be loose. If your outlet is loose try using another outlet to test the unit.
May be the unit is tripping due to abnormal voltage or loose outlet.
Dec 29, 2007 | DeLonghi Pinguino PAC-02 Air Conditioner
Pink picture
the electronic viewfinder on almost all digital cameras if even they got one is a tiny resolution screen or a mirror reflecting the bigger or smaller lcd screen. switch to your Lcd screen and see if colors are ok or still pink, also look at pictures you have taken. if ok the problem soly lies on the viewfinder which I have many cameras like it and come to think of it they looked aliittle pink too. the view finder helps you only in sunny conditions that you cant see your regular Lcd screen. and should be able to give you a good idea of what you are shooting. pink in real digital colors means you lost some green . look through your menu and see if there is an adjustment for it if not and you cant live with it return for exchange. I looked up the specs and would love this camera. good luck
Aug 31, 2007 | Fuji FinePix S7000 Digital Camera
HP Photosmart 475 InkJet Printer Logo
285 people viewed this question
Seeker5211
Seeker5211
