Kenmore Elite Front Load Washer
I opened the door of my washing machine tonight and my clothes were wrapped up in the gray colored seal between the door opening and the basket.  When I unwrapped everything the gay colored seal was twisted and a then metal ring the size of the drum came out too.. My washer is just over a yr and i forgot to get warranty. Is this fixable?  It looks like I can just put it back, but where does that metal ring go lol?  Thanks in advance
  • 5,911 Answers
The rubber boot is called the "door bellow". The following link explains how to replace one:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
If the bellow is not ripped or torn, you probably will NOT have to replace it. If the front bellow clamp (wire hoop) is the only thing that came loose, you will need to reseat the bellow around the door frame opening and reinsert the bellow clamp. The link explains this in Step 12 (I suggest you use a second set of hands to assist you). Now...if the bellow is torn, or if the clamp is damaged, you will need replacment parts. Let me know if you require additional assistance. I hope this helps you.
Posted on Oct 10, 2008
Smelly discharge water
smelly front loader???all front loader tend to leave a little water left over in the inner tub after every load,always leave washer door a crack open to reduce smell/mold on seal,to get rid of smell simply run a normal cycle,no clothes,with a dose of bleach or better yet AFFRESH,made by whirlpool,a bleach tablet with fragerance,sanitze and smells good!!answer,,,AFFRESH
Mar 27, 2012 | Kenmore Elite 45986 Front Load Washer
The machine is locked and can't open with clothes washed inside,. Add garment light is on and the time is flashing'
Whirlpool-made Front Loading such as the Kenmore Elite washing machines use a door lock and switch assembly having a tab that can be pulled manually for emergency opening of the door. This tab can be accessed with the removal of the lower front access panel. Disconnect power to the washer and drain the water from the tub before accessing it. The link below contains the detailed instructions on manual unlocking of the door.
Manual Unlocking of Whirlpool Duet and Kenmore Elite Front Load Washing Machines
Aug 26, 2011 | Kenmore HE2 Plus Front Load Washer
Ways leak from the bottom when you start the wash
this may be something stuck in the gasket(rubber) that seals the door. Fold down the gasket all thew way around the gasket, remove any thing hat may be there. This could be coins, small articles of clothing, or a wash cloth.
If no obstruction is found, it probrbly require replacement of the door gasket/seal.
Mar 27, 2011 | Kenmore Elite 45986 Front Load Washer
Our front load washer is leaking from the door down the front.
The leak is either the door seal of the large circular rubber seal that sit between the drum and the opening.
Aug 09, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore front load HE3 is leaking from underneath the unit , I checked the gray seal and it seems fine , I did have a large load in . Any ideas
If your Kenmore FRONT LOADER is leaking, the following link can give you guidance on how to inspect the washer to determine where the source of the leak may be coming from:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
Most commonly, the source of the leak comes from the door bellow (gray rubber seal). They do wear out with age and can develop small rips and tears. A routine inspection of the perimeter of the door seal can determine if you have any holes. If the seal is damaged, it must be replaced. The following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
The manufacturer recommends that you leave the washer door open between washes to prevent the seal from becoming permanently stretched. Once the seal stays compressed constantly it can stretch and not seal properly. In addition, leaving the door open helpd let the wash tub air out and prevent mold, mildew and musty odors.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back with your complete MODEL NUMBER and let me know. I hope you find this information helpful.
Jul 10, 2010 | Kenmore Elite 45986 Front Load Washer
Torn seaL ON KENMORE ELITE WASHER
i have a kenmore elite washer the red lite is lit on controlles locked how do i solve this
Mar 22, 2009 | Kenmore Elite 45986 Front Load Washer
Front load washer door won't open
There is an override switch directly below the latch under the machine on most front loaders.
Jan 24, 2009 | Kenmore Elite 45986 Front Load Washer
KENMORE ELITE HE3 WASHER
2 things you may try if you haven't already ..let washer fill with hot water ..pause and open door pour in about 2 cups chlorine bleach before starting back up..with rag soaked in bleach/water clean inside front door boot ..be sure to roll boot toward front and clean out accumilation under it wash as much as possible off door seal..allow to finish cycle (normal wash should be fine)..may also try removing lower panel remove pump acess plug and clean pump out thoroughly..you are not alone ALL front washer have same issue and if some sort of routine cleaning isn't done problem reoccurs also leaving door slightly open between usues will help ..by the way that is a german made washer
Sep 12, 2008 | Kenmore Elite 45986 Front Load Washer
Chenging the rubber gasket attached to kenmore H2e front load washer
The following link provides you with step-by-step instructions on how to change the door bellow:
This is not a difficult repair. Just follow the steps provided. If you have any questions, please let me know. I hope you find this information helpful.
Sep 02, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
713 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
