Question about Sharp LC-37GP1U 37 in. HDTV LCD Television
POWER AND OPC LIGHT BLINKING GREEN
I own a sharp LC-37GP1U, when I turn it on I hear a click sound from power bord, and the power led comes on solid green but no picture. Then few minutes later the power and OPC leds starts flashing green.
Can you tell me what is the problem please.
  • Anonymous Mar 25, 2009
    it takes me up to 20 minutes to turn the darn tv on. when i press the power button it just clicks between opc and power. if i'm lucky i hit power again when it's clicking on both lights and it turns on. i think i'm going to have it replaced
  • 2,071 Answers
The condition of your TV called power supply overcurrent shutdown that"s why you hear a click. The TV is going into a protection mode to prevent further circuit damage. That's why it will not turn on or not powering up. I would concentrate on the power supply section board. Bad regulation of the incoming voltage could caused this issue although,there is a capacitor across the incoming line and nuetral.Maybe its leak or dry up and cause the problems,change it out with one of identical rating . Although now you are getting into dangerous area,especially if you have no electronic experience background. It could be also be a loose ,crack or cold solder joint,a blown fuse,fusible links or other component .It could be one of several boards.Unfortunately the level of sophistication on these TV make it virtually impossible to diagnose them further without taking them apart and probing around with a multimeter and other tools.This TV is handy enough to take to a repair shop find a good one.You will probably have to pay $75 to $100....
Hope this may help you..
Regards,
VOTIT
DON'T FORGET TO RATE:
Posted on Oct 10, 2008
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Power light comes on for about 30 secs, something clicks and both power and ocp lights start blinking contineously. the screen does not light up
I have this model of the sharp tv.Happen to me very often the Power and OPC LED light indicators blink continueosly.Not the power supply board,it the Tuner board that take in the comming broscast signal that have the problems.You still can used this tv.Push the power button sometime the tv it will work right away.Not,each time POWER and OPC lights continueosly blinks.Just push the power button again each time the POWER and the OPC continueosly blinks.Just have push power button again about 4 times each time Power and OPC blinks recycles,it will finally show the backlight and picture come on.My guest,if u do this by pushing power button to recycles about 10-12 times each time the POWER and OPC blinks it time to change the Tuner signal board.
Jun 03, 2010 | Sharp LC-C4655U 46 in. LCD TV
THE TV IS CUTTING OFF BY ITSELF AND THE OPC LIGHT IS BLINKING
This problems very common on Sharp Tv.Do ur tv LED power light turn on solid first.Few mins,than LED,OPC flahes.Power LED,OPC flashes,push power button again,do this at leat 5 or 6 times somtimes the backlight will come back on and work.The power LED,OPC light flashes,turn off/on more than 5 or 6 times don't work.Ur Tuner signal board is dead,must replaced.
Mar 30, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No picture, when powering up the light will turn yellow, them the t.v powers up and can hear sound but no picture, and then hear a click and light flashes green.
First turn on,do the power LED light stable?Few sec.Power LED and LED OPC flashes?This very common on Sharp tv,tries power off/on at 4 or 5 each time it flashes,well power up have backlight on and it work.After this doesn't work than ur Tuner Signal board it dead.
Feb 03, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My sharp LC-37d62u display problem
This problem very common in sharp tv.The POWER,OPC flashes.First turn on have power LED indicator light stable at all? Tries the power again couple times will have backlight come back on,than it will work.Not at all more than 5-6 times than ur main turner signal board is the problem,must replaced.
Jan 05, 2010 | Sharp LC 37D62U 37 in. LCD HDTV
No picture no sound opc light and power light
This is very common in sharp tvs.U turn it on.U get power on light stable right?U hear a click,one or twice,sometime tv is good right?Sometime POWER light and OPC light flashes?Push the power button on/off couples times will work, picture will come on.If keep trying off/on couples time after POWER and OPC flashes,don't ever stop and never get backlight and picture.Ur Video backlight board is dead must replaced.
Dec 28, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp 52" Aquos LCD Will Not Turn ON-Blinking LEDs
I had a similar problem. Fleeting video, then audio only for few seconds and then nothing except the green power LED blinking on and off.
I changed the power inverter board, backlight inverter boards and power supply board but still the problem is not gone.
Just 18 month old TV and out of warranty.
Jun 06, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LC-37GP1U 37 in. HDTV LCD Television Logo
861 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
