Question about Sony Handycam DCR-VX2100 Mini DV Digital Camcorder
A/V and S-Video out not working
I'm not sure what happened but all of a sudden I can't use these outputs to view the camcorder on a monitor while I am recording. It seems like it would be just a setting, but I can't seem to find it.
Thanks!
    Problem Solver:
  • 18 Answers
Befor spending any money, look in your menu if "display" is on"LCD" only or "v-out/LCD"
Posted on Dec 26, 2008
Aspire One AO725-0635 powers up but screen is black with white lines. Not dropped, just happened suddenly. We powered down, removed and put back battery. Still monitor black with white lines. Help! ...
Lets step through some trouble shooting. Can you plug in an external computer monitor? If this works then it is cable connections to the notebook monitor. If a normal computer monitor does the same thing it is potentially video settings or hardware. Since there is some kind of output then the video card is outputting so it us not likely the video card has failed not impossible just less likely. If the external monitor works and the laptop one still fritzed check the video settings are right. If video settings are ok then it could also be cables issue on the laptop. Faulty RAM chip can also cause the problem as described this is also worth checking.
Jan 15, 2013 | Acer Aspire One AO725-0635 11.6" Netbook...
Hi I have just connected my onkyo tx-sr 507 everything works perfectly apart from the monitor channel I have used a composite video cable to one of the inputs on my tv from the monitor output while using...
The 'monitor' video output would go to a corresponding composite video input on the TV/monitor. It would be selected as a source, not a channel. I'm sure the unidentified video device's manual explains it. Any RCA cable would suffice.
Aug 08, 2011 | Onkyo Tx-sr507 A/V Receiver
Someone did my wedding video, it wont finalize, but plays back on the camcorder. She lent me the camcorder, along with usb cord and software. I cannot get the data from the disc to transfer to my...
Unfortunately, only video and/or pictures from your (SD Memory) Card can be transferred (via the USB cable) to your computer. Video/pictures from a disk is not accessible to your computer.
So, you may wish to try to playback the video (on the camcorder) with the output to a DVD recorder (using the AV cables from the camcorder to the DVD recorder or a VCR recorder). This assumes you have a DVD recorder (or VCR recorder) that will take the RGB input from the camcorder. Connect it up just like you're viewing the playback on a TV monitor.
Jan 27, 2011 | Samsung SC-DC173 DVD Camcorder
Black bars on zr300
Cleaning Tape did the trick. Thanks!
Andy
Mar 30, 2009 | Canon ZR300 Mini DV Digital Camcorder
Monitor "out of range"
Out of range happens when the video output of the computer is set to something the monitor cannot display. Like trying to talk to someone that does not understand your language. Just because the previous monitor was the same brand does not imply it will handle the same input. Either buy a different monitor or borrow one till you get one that works, then change the video output to something your new monitor recognizes. I have this problem at church - if I change the video output to a real high resolution the main big monitor will display it but the smaller one will say "out of range"
Sep 28, 2017 | Star Logic Computers & Internet
Monitor for recording
attached the jack wire from the camcorder video output and the red and yellow wire goes to the tv video input.select the AV from your tv.good luck.
Sep 28, 2008 | Canon DC100 DVD Camcorder
View finder no working
Do you have an image on the fold-out monitor?
Jun 13, 2008 | Panasonic NV-DS60 Mini DV Digital...
No firewire
Make sure your camera driver is up to date from ACER
http://www.acerpanam.com/flex/acerdrivers/bin/drivers.html?CFID=392700&CFTOKEN=65510280
Link to downloads for the Acer 5100 laptop
The only connectors on your camcorder are as follows:
1 x microphone
1 x headphones
1 x IEEE 1394 (FireWire/i.LINK)
1 x S-Video output
1 x composite video/audio output
1 x Control-L (LANC)
1 x DC power input
If you have an s-video on your laptop you can connect it with an s-video cable and audio cable (red and white one end, black the other end
I am looking at the computer on line and on the Left View, I see a 4 pin iDDD1394 port. You can use this to connect your camera,
Also, on the rear view you do have a s-video port.
You should have no problem connecting the computer and camcorder.
Mar 31, 2008 | Acer Aspire 5100 Notebook
No input on RGB1, etc.
First find someone you know who has a working unit, just to make sure you don't have a problem with your PC output or the cable so you KNOW you have signal at the input.
If no signal then, make sure your input is "configured" correctly in the user menu.
I would have to think your VGA input board on the projector is faulty but let me know what you find.
Jan 15, 2008 | Hitachi (DT00431) Projector Lamp for...
Sony Handycam DCR-VX2100 Mini DV Digital Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
