Question about HP Officejet Pro L7680 All-In-One Printer
HP Officejst Pro L7680 All in one
My top feeder was not workign properly - I took the rollers off, the black & blue palastic peice and now that I have put it back together - the lid will not shut completely ( the blue handle it sticking up slightly & will not allow it to shut. Obviously I have not put it back together properly but can NOT find how to do so on any documentation (lid photos are not helpfful). Thanks!
  • 6 more comments
  • BTyerman Nov 07, 2008
    The paper roller mechanism at the top left of the machine is very poorly designed and only compounded by the lack of documentation roller and other components. After fiddling with the plastic parts I can send a fax or print a copy, but then the problem recurs. It is maddening.
  • Anonymous Nov 26, 2008
    Our printer just wont feed through, the rollers dont drop. Its a pain in the arse
  • Anonymous Dec 01, 2008
    same here on the lid not closing...excact same problem
  • Anonymous Dec 04, 2008
    I took it apart and no can not put it together.
  • justpsgthru Jan 23, 2009
    Took the rollers out to clean them because it was copying with a line down the middle and now I can't get the door to shut closed. Obviously I am putting them back wrong....HELP!!!!!!!!!
  • Anonymous Feb 22, 2009
    It's Junk!!!!!!! I'll never buy a piece of **** like this again ! I want my money back!~!
  • txgeekman Feb 23, 2009
    ADF is a P.O.S. and I love HP products. I guess their quality is going down hill. So far this is the only problem I am having with this unit. The ADF pulls in the paper and either tears it to shreds or it will curl it, crumble it, pull it in and turn the paper so that your image/copy is not straight. Worked great for about 6 months, now it's starting to get worse.
    Hey HP, how about producing reliable products like you used to....
  • Anonymous Mar 04, 2009
    It takes two or three attemps to get the top feed to take the paper. Have also had a problem with it not taking the paper correctly and tearing.
    I have used HP printers for 20 years and purchased 4 this year. No plans to buy another HP until they start building good printers again.
Printer gives repeated "clear paper jam" messages and even though there is no paper anywhere in the paper path it will not clear.
Posted on Oct 24, 2008
The roller in the feeder has come out, I don't know how to put it back in
I am not sure as to which roller you are talking about but please find below the solution. !!!!DO RATE MY SOLUTION!!!Pickup roller replacement
  1. Tip the device over on its rear side, with the top of the device facing you.
  2. Rotate the bushings (callout 1) on each side of the roller upward. c02755446.gif
  3. Remove the left-side bushing by sliding the bushing to the left.
  4. Slide the roller and shaft toward the left until they clear the hole in the right-side bushing, and then lift the right end of the shaft.
  5. Slide the roller and shaft toward the right, and then lift the roller and shaft together out of the device. c02755447.gif -------------------------------------------------------------------------------------------------------------- This is for ADF (Automatic Document Feeder) on top of the printer.
    3. Press the round blue button while lifting the green lever. Rotate the green lever until it stops in the open position. The pickup roller assembly should remain on the surface.c00802892.gif
    4. Remove the assembly, and then wipe the assembly with a soft, dry, lint-free cloth.c00802893.gif
    5. Replace the assembly, with the largest roller down, in the upright holder, and then press until the assembly snaps into place.c00802894.gif
    6. Make sure that both sides of the assembly are secured by the blue hooks.c00802895.gif
    7. Lower the roller assembly, and then close the ADF cover.c00802896.gif NOTE: If jams continue in the ADF, contact a local HP-authorized service provider.
Jun 27, 2011 | HP LaserJet M3027x MFP Printer
I have a tippmann custom pro with a cyclone feeder. I recently got the SAW stock to put on it and encountered some problems many times after I reassembled the gun. I took it apart at least 5 times before...
Hi there. Tippmann markers are super tough to make sure that they are put back together properly. The stupid clamshell design plus all the little, under engineered parts make it difficult to get it back together properly, especially after installing a stock. I was in the paintball industry for 10 years but have been out of it for a little bit, but i was one of the founding members of Uprising Nation and was a gunsmith/ salesman for / Xtremes. Now with that said...I even had trouble with the tippmann 98's...and I can rebuild an autococker with my eyes closed but can sometimes be stumped by the tippy's bad design. It is really tough to diagnose an issue on these guns without looking at it. You may have the ball detent backwards,l missing a pin, sometimes the after market stocks on those are a little too large on the outside diameter preventing the internals from properly seating. The cycloce system may be off due to the valves not meing properly aligned or the connecting rod not being in all the way. Many times though it is incorrect installation of the detent or the deternt gets damages. That little orange peice of **** flap is a mance. I would start there.
It may seem like i am bashing your gun. Im not... Once they are put together properly they work great. Just DONT TAKE THEM APART. lol. If you buy the parts at a local gun shop they will install them for free.
lol I have 6 guns for sale :)
Have a good day
Apr 10, 2011 | Tippmann 98 Custom Pro Act Paintball Gun
My dear wife took the lid handle off our breville gourmet wok. The pieces include a screw, a spring and 3 other parts. Im not sure if i put it together properly. Could you help out. Thanks
This is for assembling the Breville Wok lid. This has a built in vent that lets steam escape during cooking. There are 8 pieces not including the glass cover: bolt, metal vent, black O ring, tan round plastic piece, black lid piece (has open/close) on it, spring, clear plastic seal, lid handle.
Order of assembly as follows, starting on inside of glass cover.1. Bolt.2. Metal vent piece sits on top of bolt.3. Black O ring fits snuggly onto of vent piece.Insert what you have assembled against inside of glass cover, bolt poking through topside of glass.4. Add tan plastic piece with 3 prongs going facedown against the glass hole of cover.5. Larger black lid piece goes next. You will need to line up the openings on tan piece and this lid piece so that it sits semi-flush against glass. When complete this piece will turn in place to open/close vent (less than 1/4 turn before stopping).6. Add clear plastic seal to underside of handle.7. Place spring between handle and top of black lid piece and screw together until snug.
Test lid by turning lid piece. It should move back and forth according to the open/close print on top. If no luck, go to step 5 and try again. It is a little tricky, but does work when done correctly.
Feb 02, 2011 | Breville EW30 Gourmet Non Stick Electric...
When I load papers into the document feeder on top of my HP Officejet 7210 All-in-One printer to scan these documents, the PDF file (scan results) have a multi-color series of lines from top-to-bottom on...
  1. Remove all originals from the document feeder tray.
    NOTE: It might be easier to work with the automatic document feeder if the document feeder tray is removed first.
  2. Lift the cover of the automatic document feeder. Figure 1: Lifting the ADF coverc00222493.gif
  3. Lift the lid on the HP all-in-one, and locate the notch near the top right edge of the lid backing. Figure 2: Locating the notch near the lid backingc00222494.gif 1 - Notch 2 - Lid backing
  4. Place one or two fingers in the notch, as you lower the lid of the HP all-in-one. Keep your fingers in the notch until the lid is almost closed. Figure 3: Inserting fingers into the notchc00222495.gif
  5. Push against the top of the face plate with your thumb as you pull the bottom away from the right side of the HP all-in-one with your fingers. Use a slight twisting motion to help release the face plate on the right side.
    CAUTION: Do not pull the face plate all the way off yet. There is a plastic catch on the far left inside of the face plate that helps secure the face plate in place. If the face plate is pulled straight off, the plastic catch on the inside of the face plate might be damaged. Figure 4: Releasing the face plate from the right side of the HP all-in-onec00222496.gif 1 - Releasing the right side with a slight twisting motion
  6. Slide the face plate to the left until the plastic catch on the left side is not touching any part of the HP all-in-one, then pull the face plate away from the device. Figure 5: Removing the face plate from the HP all-in-onec00222497.gif 1 - Sliding the face plate to the left 2 - Pulling the face plate away from the HP all-in-one
Cleaning the rollers or separator pad Follow the steps below to clean the rollers or separator pad.
  1. Once the face plate of the ADF is removed, use the blue-green handle to lift the pick assembly. Figure 6: Blue/green handle and the pick assemblyc00222498.gif 1 - Blue-green handle 2 - Pick assembly This allows access to the rollers and the separator pad. Figure 7: The rollers and the separator padc00222499.gif 1 - Rollers 2 - Separator pad
  2. Lightly dampen a clean, lint-free cloth with distilled water, then squeeze any excess liquid from the cloth.
  3. Use the damp cloth to wipe any residue off of the rollers or the separator pad.
  4. If the residue does not come off using distilled water, try using isopropyl (rubbing) alcohol.
  5. Use the blue-green handle to lower the pick assembly.
Reattaching the face plate of the ADF Follow the steps below to reattach the face plate to the front of the automatic document feeder.
  1. Hook the face plate onto the left side of the HP all-in-one so that the plastic catch on the far left inside of the face plate catches on the notch on the front of the automatic document feeder. Figure 8: Hooking the face plate into the left side of the HP all-in-onec00222500.gif 1 - Notch 2 - Plastic catch
  2. Line up the right edge of the face plate with the right side of the HP all-in-one, and then press on the right side of the face plate until it snaps securely into place. Figure 9: Snapping the face plate into the right side of the HP all-in-onec00222501.gif
  3. Place your hands towards the center of the face plate, and press until the center of the face plate snaps into place. You should hear two clicks; one when the left side snaps into place, and one when the right side snaps into place. Figure 10: Finishing re-attaching the face platec00222502.gif
  4. Close the cover of the automatic document feeder.
  5. If you removed the document feeder tray, reattach it.
Dec 07, 2010 | HP Officejet 7210 All-In-One InkJet...
The top feeder gets jammed = seems to be a problem with the blue
Open the lid and clean the rollers with Isopropal Alcohol.
It should also be under warranty!
Jun 16, 2009 | HP Officejet Pro L7680 All-In-One Printer
Installing the hook and bobbin assembly.
The plastic bobbin case should sit on top of the raceway, it should slot in quite easily, once the bobbin case is in put the small metal clip at the top over to hold it in place.
May 27, 2009 | Singer Sewing Machines
Braun electric water heater lid came off along with spring parts, all intact. How do I re-assemble it? Manual? Schematic available?
This is the solution for the BLACK Braun electic water heater, so you must adjust the color to fit if yours is another color.
First take the 3 pieces that go inside the top. Two look like a "Z", and the other is the square, white doo-dad. Take the square piece and slip it into the slot with lid open. YOU CANT PUT IT IN FLAT UNLESS THE LID IS OPEN! Make sure that you can put it in FLAT. Once it is in flat, take it back out. Now you have the 2 "Z" pieces. Fiddle around with these pieces until you learn how to put them in together so they will fit together. This may take several tries. There is a piece that acts like a pivot. Now take all 3 pieces out. The trick is not to put the 2 "Z" pieces in together. You have to figure out what Z-piece to put in first. Then put the rectangular white piece in, and then the other Z-piece. This all must be done with the lid OPEN, otherwise the rectangular piece will not lie flat. Make sure the little spring inside this rectangular piece it put in properly - it should be against the little black doo-dad on the lid. If everything is sitting happily together, you should be able to snap the other black part onto the lid, and close it successfully.
May 16, 2009 | Braun WK200 AquaExpress Electric Water...
Jams coming out of cassette at U-Turn, Black Guide has spring on it
Remove the peice as shown in the photo below to reveal the feed wheel beneath.
Open the top cover and remove the screw just to the left of the white/clear section shown in the photo below.
The smoked plastic peice will unclip from the fron end by grasping the inner most edge and gently rocking up and inward. This will reveal the entire feed wheel.
Clean the entire wheel in the above photo with a damp (Not soaking, just damp) cloth. The wheel will turn making a clicking sound (top inward) allowing you to clean it entirely. Also clean the obligue roller (1st part removed) with a damp cloth and blowing out.
Reassemble as you just took it apart. Pay close attention to the smoked plastic peice that it gets front clipped properly back into place. Don't force it. It will all go back together relatively easy.
That should help eliminate a lot of your jamming issues.
Hope the above helps you. :)
Aug 25, 2008 | HP LaserJet 4L Printer
Fell please!!!
The larger white pieice that has holes in it should be connected between both the spring and the smaller razor, The bottom of the larger white peice has to be able to fit in the peice of medal that moves in a circular motion inside the top part.
First, Try to make the hooks of the spring go in pretty securly inside the small holes. The flat side of the white peice has to be connected to the flat side of the smaller razor. They should kinda snap together on the top hole. I had to gently place the parts together and push the larger white peice in the medal by placeing the larger razor peice right on top and pressing down really hard. You might hear some snapping but the peices should all connect together and the large medal peice should connect to the black groves and press hard. Hold in place while putting the screws back in.
Jun 21, 2008 | Conair GMT182CS
HP Officejet Pro L7680 All-In-One Printer Logo
499 people viewed this question
Ben Johnson
