Question about Jenn-Air 24 in. JDB8910 Built-in Dishwasher
Soap door not opening
Soap door will not open
- Make sure the spring action door is working.
- Make sure there is not anthing blocking the clasp.
Posted on Nov 23, 2008
The soap door will not open during wash cycle, I tried both short wash & reg wash.
The only experience that I have with this type problem was from having dishes blocking the soap door. You can tell if this is the problem when you open the door. The soap door will then open and the soap will run down the door.
Apr 25, 2012 | Samsung DMT800RHS Dishwasher
Soap box not opening and soap not being used during wash cycle even thought the soap button selected.
The soap door is opened by heating a bimetal bar that bends when electricity is applied. This prevents the door from opening when the cycle is momentarily selected preventing the soap from dumping. The unit is behind the soap cup in the door.
May 27, 2011 | Whirlpool Dishwashers
Soap dispenser door does not open during wash cycle. it can be opened with the manual release.
close the soap door and put into diagnostics. most models you can do so by pushing heated dry-normal-heated dry-normal. let it do its test and if the soap door opens during the test cycle, most likely the soap door assembly needs to be changed.
Nov 17, 2009 | Whirlpool Dishwashers
Soap dispenser door not opening up
there could be many solutions from not enough water in the dishwasher
to the piece on black backing in between the door and inner linning has warmed up and slide down restricting the soap door from opening
the lack of water could be from a defective water fill valve or a restriction in the drain line holdingf the drain valve open alowing water to escape
when the machine fills open the door see how much water is in it close the door wait 2 min open the door again if water went down the problem is arestrictioninthe drain valve (water should fill to touch the element in the bottom i hope this helps
Oct 17, 2009 | GE 24 in. GSD6600G Built-In Dishwasher
The soap dispenser opens but the soap is not dispensed and the dishes do not get cleaned. Can you help?
Make sure that there is nothing blocking the soap door from opening fully when the dishwasher is shut. This happened to me and I also thought that the soap door was opening during the cycle when it actually only partially opened during the wash and then popped open fully when I opened the dishwasher at the end of the cycle. So some, but not all, of the soap was used.
Dec 28, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Soap door does not open
I have a 1 year old whirlpool that had this problem ... items in silverware compartment were blocking the soap door. when we opened the DW, the soap door was open, but could not open properly during the cycle due to kitchen utensils in the way ... took a while to figure this our as it was intermitent (both the problem ... and us putting tall stuff in front of the soap door). Our soap door needs 3.5" of free space in front of it ... I think it's a design flaw. Good luck.
Oct 22, 2008 | Frigidaire 24 in. FDB750RCC Stainless...
Soap dispenser door
I have a whirlpool that had this problem ... items in silverware compartment were blocking the soap door. when we opened the DW, the soap door was open, but could not open properly during the cycle due to kitchen utensils in the way ... took a while to figure this our as it was intermitent (both the problem ... and us putting tall stuff in front of the soap door). Our soap door needs 3.5" of free space in front of it ... I think it's a design flaw. Good luck.
Sep 02, 2008 | Frigidaire 24 in. FDB750RCC Stainless...
Soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Mar 01, 2008 | Dishwashers
IT SEEMS YOU SOAP DOOR HAS A BAD SOLENOID ACUATOR OR RELAY
Jan 17, 2008 | Kenmore 24 in. 16592 Built-in Dishwasher
Soap not dispensed and dishes not washed
water is getting past the gasket during the start up cycle. by the time the door opens, the water has caked up the soap. also, its not clear when in the cycle the door is opening.
try using liquid soap.
also, take a peek just after the machine has finished filling and starts washing to see if the door is opened on the soap disp.
good luck
mark
Dec 19, 2007 | LG 24 in. LDS 5811 Built-in Dishwasher
Jenn-Air 24 in. JDB8910 Built-in Dishwasher Logo
99 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
