Question about Cameras
The lens will not retract. When in picture mode er18 appears on the otherwise blank screen. It will switch to allow me to view the pictures on the card
  • Cameras Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Oct 11, 2008
View screen is white (blank) with internal cracks
Look fo the switch that has two setting. one of them will say LCD and the other Migt EVF if you have a view through your view finder this is your problem.
Jun 28, 2009 | Samsung L200 Digital Camera
Screen black in all lighting. Icons and Menu show but screen otherwise black in all modes. Can view photos on card. Can take a picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image Mode selection.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Camera lens does not retract & view finder is just blue, will not go to other screens
The lens maybe out of track. Perhaps you have bumped the camera or dropped it. Look if the lens are a bit tilted, if so, try straighten the lens with your fingers, very gently. Hope it works.
Oct 04, 2008 | Fuji FinePix F470 Digital Camera
E 18 problem
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Oct 02, 2008 | Panasonic Lumix DMC-LS75 Digital Camera
E 18 problem
Hello there,
Jun 09, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
A85 Dead
I read something about the fuse going out...
http://www.dcresource.com/forums/archive/index.php/t-18151.html
Apr 12, 2008 | Canon PowerShot A85 Digital Camera
Sony digital camera dsc s40
code error 61 related to internal lens problum.i think lens movement moter stuckup this is reparable
Jan 13, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Lumix tz3
Low battery maybe? Try holding camera firmly in one hand, with camera on and in record mode, and strike in on its edge firmly on the heal of your other hand. This technique is often sucessful with temporary camer 'quirks' like freezing, lens not fully retracting, etc.
Dec 31, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
E 18 problem
the E18 means the lens system has a problem. I had it with my S2 and sometimes it worked, sometimes not. Eventually it stopped working. The only solution was sending it to repair, they changed the lens system.
Best Regards
Nov 19, 2007 | Canon PowerShot S2 IS Digital Camera
Cameras Logo
71 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
