Question about Tomtom ONE GPS Receiver
TomTom One repair
my tomtom One sometimes doesn't turn on. . i see that you've had some luck repairing that problem. Can you please send me pictures and details to my email address: jfox100 at hotmail dot com.
Also, i've removed the four torqs screws from the back of hte device, but i cant get the tomtom to come apart? whats the trick to disassembly after the screws are removed?
thanks
Jim
  • 2 more comments
  • timtim123 Oct 12, 2008
    I have the same problem (will not start up) there is a small hole on the bottom, take a pen and push it in, this should re-set and start.
  • timtim123 Dec 22, 2008
    I have had problems with THAT loading with the cable.... here is what I found... it seems mine is lose where you hook in the power cable, every time you unplug it make sure it is done straght out and not at an agle.. might be your cable is lose and you charge is too low to boot... that is the problems I'm having with my GPS
    I will try and show you on youtube as soon as I can.
    Tim
  • bridenhour Feb 18, 2009
    TOM TOM ONE XL WILL NOT TURN ON
  • Anonymous Mar 04, 2009
    will not turn on
  • 502 Answers
The only place I could find is this general GPS Repair Service that also takes care of TomTom.
Posted on Dec 21, 2008
I got mine to re-start and did all the loading with my computer, I re-set it back to factory settings, that seemed to do the trick.
Just get it to start then plug it in to your PC, your PC will ask you if you want to run your tomtom from your PC, press YES, then re-set it to factory setings.
Posted on Oct 15, 2008
I, mine gps do not succeed to load with the cable with feeding in the car I am in montreal and I do not succeed to find an attendance center tom tom you can give to information thanks
Tom tom go 930 screen does not respond to touch.
Hi, Victor you can try to reset to default with a paper clip and make sure your battery is fully charged for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Touch screen TomTom EN
Repair Touchscreen Not responding for TomTom GO 930 Repair 4CH9 000 UK rep
TomTom GO 520 Touchscreen Problem
http://download.tomtom.com/open/manuals/gox30/FullManual/refman/TomTom-GO-en-US.pdf
Nov 03, 2016 | GPS
Hello, I have tomtom 730. I got a problem cause, my tomtom after turning on shows battery sign with exclamation sign and it turning off itself. what does it mean, battery is bad or tomtom needs repair.
The battery with exclamation point means the battery is not charged. Check your car charger fuse and the fuse box fuse for the power outlet. Next check the TomTom connected to your PC with the data cable, it should charge that way too. Let it sit for about 1 hour and then try to power it up and see if you get the same thing. If you do get the same thing then most likely the USB jack on the TomTom is broken off from the board. If that is the case you will need to have it serviced, you can either send it to TomTom or find a local repair company. If you are interested we do repair TomTom units with these issues. Contact us at tech@ccl-la.com if you need any more information.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 19, 2010 | Tomtom GO 730 Car GPS Receiver
Will not turn on.
HELLO THERE
There is a internal fuse that may have blown or the wire that feeds the device is loose also
If resetting doesn't help, then the lighter adapter inside the TomTom has gone bad. It is known as CLA. Probable the sense wire is detecting false voltage. Most probably you'll have to send to TomTom service center because the defective part is not available anywhere. If you try to repair it yourself(i.e. the sensor wire) and anything goes wrong then TomTom won't take responsibility of it. If the unit is under warranty then you'll get it repaired for free. If you have any other queries then I would be glad to assist you further.ok
best regards michael
Sep 21, 2009 | Tomtom GPS
Broken tomtom one 3rd edition
Try resetting the unit. Little black button labeled reset on bottom.
Jul 27, 2009 | Tomtom One Europe v2 GPS Receiver
Broken Screen
There's really nothing we can do for you about that. A broken screen is not something you can fix yourself. Go to tomtom.com and contact support, and they will walk you through sending your tomtom back to them for a repair or replacement.
Please rate, thanks!
Feb 23, 2009 | Tomtom ONE GPS Receiver
Tom tom one v1 Loose power connector
If the problem exists both when you use the vehicle power connector and the usb cable to your computer, then you have to assume that the problem is with the socket on the One. If it's still in warranty, I would send it back to Tom Tom for repair. Contact customer support for repair information.
The link is as follows:
www.tomtom.com
Jan 26, 2009 | Tomtom ONE GPS Receiver
Tomtom one repair
If the green light does not even come on when you plug in the charger you must have an issue with the logic board. Did the GPS get wet or did it drop, was there anything else the preceded the moment it stopped working? There is a company that sells GPS logic boards for TomToms : GPS Repair
Sep 20, 2008 | Tomtom ONE GPS Receiver
Seeking the repair of my tomtom Go 910
One suggestion is to plug the Tom Tom using the temporary power cord to you home circuit (not the power source from the car). That worked for me. Sometime the Tom Tom shuts down when left in the hot car requiring a reset. Then the best way is to plug in at home and restart. Try it, otherwise I can't help.
Jim
Aug 19, 2008 | Tomtom GO 910 GPS Receiver
Tomtom 1 stopped talking
Check in preferences > Change Voice to make sure that a voice is selected. If it is, it probably corrupted. Pick a new voice. If none of the other voices work, plug your TomTom into your computer and boot up TomTom HOME and reinstall the voices. If after that they still don't work, contact TomTom support and ask them for advice. They will probably have you send it in for repair on broken speakers.
Please rate, Thank you!
Apr 14, 2008 | Tomtom ONE GPS Receiver
CANNOT RECHARGE TOMTOM
If you have the green light lit on top of the tomtom but it won't switch on , then you have a condition commonly known as "the Green Light Syndrome". Most likely cause is blown components inside the tomtom that regulate voltage. The reason they blow is usually due to user connecting incorrect charger ( such as a 12v one for a phone ) or sometimes the tomtom charger goes faulty and instead of ouputting 5 voltas it outputs 12 volts and damages the tomtom inside. the parts are not easily repalced and require a specialist repair centre that has good experience of repairing tomtoms. You cannot repair it yourself using a normal soldering iron. Good luck.
Feb 16, 2008 | Tomtom One Europe v2 GPS Receiver
Tomtom ONE GPS Receiver Logo
1,086 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
