Question about LaCie Computers & Internet
My external hard drive was will not power on. I believe lightning from an electrical storm has caused the damage. I dont know if it is the hard drive or the ac power supply? i need to get it fixed... can anyone help?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • LaCie Master
  • 1,001 Answers
    Scholar:
  • 105 Answers
Try plugging in the Hard disk to some other power outlet, if it still does not power on , you may need to replace the drive. Sometimes, the problem maybe with the connector that is used to connect your hard disk to the main power supply. Check this cable with some other Hard disk to make sure there are no problems with the cable. If this also does not work , try getting a replacement (Incase your product is still under warranty).
all the best
Posted on Oct 10, 2008
What does it mean when one reads FD in the panel and the lights on the panel aren't stable?
The control board to your range may have been damaged because of the lightning storm. It happens when lightning strikes a power line and sends a surge of power to your home. This large current surge can easily damage electronic circuits. More often than not if a device is on and lightning strikes, that is when the device gets damaged. During large lightning storms it is best to turn off all electronic devices. The electricity going to your house is fine now and that is probably what your electrician checked.
Nov 22, 2017 | Kitchen Ranges
Had a lightning storm,now brand new aircon wont restart,remote is ok
The electrical storm may have caused a power surge and burned out the circuit board. Especially, if the power went out briefly and then came right back on. Most manufacturers recommend turning the unit OFF during a power outage/electrical storm.
Hope this helps you.
Mar 25, 2011 | Heating & Cooling
Lightning storm seems to have hit earthing or power system of my house (totally knocked out the power in 2 neighbours houses) Computer died, but all other electrical components no problem - including the...
Yes, it's fixable, no , it's not worth it - it will cost you to fix it almost as a new pc. To recover your files just take the hard disk out and put it in a external enclosure  - around $25 - and plug it in in another pc.You will end up with an external disk, just wipe all Windows related stuff and use it as a backup.
Sep 10, 2010 | Acer Ferrari 5000 Notebook
Why using a telephone during a lightning strom is dangerous?
Hi
Lightning routinely gets into copper telephone cables during storms and can overwhelm the fusing protectors at your home and enter a telephone set, causing a lot of immediate damage to the telephone and the user.
Lightning can travel from outside your home to inside your home—and to you—through materials that conduct electricity, including electrical wiring, phone lines, water, and plumbing. These safety guidelines will help minimize your risk.
If you need to use the phone corded phones are dangerous during thunderstorms. Lightning traveling through the telephone wires has killed people. Cell phone and cordless phones are a safer choice, but stand away from the cell or cordless phone's power base
Hope this will help you.
Mar 18, 2010 | Lands Phones
Power will not come on, some kind of timer seems to be in place,
Claim fusion on your insurance policy but dont mention lightning as its an act of God and not claimable in many instances
Aug 01, 2009 | Samsung HLN5065W 50" Rear Projection...
The power adapter does not work
open plastic case and pull out the sata hdd and put it in a comp with sata support
Jul 13, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
My cpu got a power surge during a lighting storm an burned up my power suplie ive replaced it an now the power light will come on when i push the power button on and the fan on the mother board works but...
In addition to your power supply, your motherboard was also probably affected by the surge. Most surges do damage beyond the motherboard. The power supply is still supplying power to it, which is why the fan runs and power lights come on, but it probably isn't doing much more then that. You might want to start looking for a motherboard replacement. The best and most inexpensive place is www.tigerdirect.com.
Mar 25, 2009 | HP Compaq Presario SR1303wm PC Desktop
Unusable new oven after ice storm
HI. the storm has caused an electrical surge that traveled through the home wiring system and, the Oven control received the hit in this case. it is damaged at this point, and it should be replaced asap, if possible. this code represents a major control breakdown. the board is ruined.
replace it asap.
Dec 17, 2008 | Whirlpool RF380LXPS Electric Kitchen Range
Lightning Storm/Affinity Washer
During a lightning storm, a lightning strike could have induced a high voltage surge in your incoming power lines. Left unprotected from these power surges, the weakest link ( normally low voltage electronic controls) are the most susceptable. Just because you had power available at the wall receptacle after a storm doesn't mean that your washer control system wasn't exposed to one of these surges and got damaged. On the contrary, it is extremely likely that the washer took a 'hit' and was damaged.Other devices plugged into the same receptacle may have survived that hit because electricity travels the path of least resistance.. In this case.. that path may have been thru your washer.. My point being is that your washer could have sustained a power surge and was damaged so don't rule that out. Of course, that surge could have taken an internal fuse or other component out too..
Jul 17, 2008 | Frigidaire Affinity ATF7000E Front Load...
Computers & Internet Logo
168 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
