Question about Akai LCT2785TA 27 in. LCD Television
Somebody please help
Hi, if you still have the TV apart , please help me identify the following parts R107, R 106 R104 and C 17.... no details required just colors on resistors and whatever #s on Capacitor... I have posted this request so many times and no one has responded. I'll help fix yours too, I do a lot of electronic repair and I'm trying to fix this TV that I picked up from a client. The only problem is someone cut those components and I can't find any schematics for it. Megmeet (the manufacture) won't reply to my e-mails and all parts distributor want to sell me a new power supply. Please help and thanks in advance.
5 Suggested Answers
  • 5568 Answers
SOURCE: Resistor Values
I'm not sure if Akai has made any of the sets that carry their name; some have come from Samsung and others purportedly by Funai but when I have tried to find service information on given models, it has been a dead end regardless of who made it. The true manufacturers refuse to recognize model numbers assigned by Akai.
If you had just burned resistors, I might be able to help you but when missing, you're kind of stuck.
Posted on Sep 29, 2008
  • 367 Answers
SOURCE: Akai LCT2785TA Won't Turn On
It's worth a shot.First I would open the back of the TV,and look at the can shaped items on the boards.If any of them have the tops,or bottoms bulged out,they need to be replaced.Then you can get the stuff you need to replace the bad capacitors.This should get it working again.If it is anything else,you will have to buy some equipment like a multimeter to test the components,and find which ones are bad.As far as what you need,it all depends on how much you want to get into this,and,or other electronics.You would need a soldering iron,solder,solder braid,and a desoldering bulb/plunger to get started.I hope this helps.If you have any questions,please let me know.Thank You very much!
Posted on Nov 02, 2008
have akai lct2662 screen is bad power supply and board ar good
Posted on Jan 27, 2009
SOURCE: I'm looking for a power supply for a AKAI LCT37Z6TA
I bougt this PS on eBay for $85-13S/H. Something wrong with my TV but supply is OK Markmaya
Posted on Apr 01, 2009
How can I fix the picture color problem on my Dynex TV?
hi, thanks for contact me :
seems that your TV have a bad T-CON board, you have to take it apart and check for the exact part number on the board, because those sets have different version of those boards.
to give u an idea after you take it apart look at the top of the screen for a part like this :
after find the correct part number get back to me to address you in the right way
Mar 03, 2015 | Dynex DX-L42-10A 42 in. LCD TV
I need trippers for an Intermatic Raintight Outdoor Timer model HB11R
1) Intermatic trippers: Buy Amazon or Intermatic store
Copy following link to identify tripper
2) Copy following link to identify Intermatic analog timers with replaceable trippers
3) Add comment and describe timer in detail, and color of tripper
Dec 10, 2012 | Intermatic & Indoor/Outdoor Rain Tight...
How do you change a color wheel on a 2007 philips 60 inch dlp HDTV
You may find the part a little difficult to find but it requires entire light engine be removed and taken apart--not likely a do it yourself job--I would suggest you look on You Tube as they have video instructions for a lot of sets for replacing the wheel--even one close of age and model would help.
Apr 25, 2012 | Televison & Video
Hi. no matter how i set up the colors, brightness, convergence, my screen has a yellow cataract like color. Can i clean the light bulbs or something. Mangnavox 51mp329h hd projection tv
I have a simple suggestion which will tell you exactly why the picture looks yellow.
It requires no parts or special tools but I need to know if you can follow simple instructions?
This is not an uncommon problem and if you require further help I can explain exactly what to do and what to look for.
Sep 16, 2011 | Philips Magnavox 51MP392H Rear Projection...
Hi I have a Samsung HLN467W, a 46" DLP TV. And after 50-60 minutes, it starts to flicker white, like lightning flashes. But the whole screen is not blank white, it's more like the images are...
It seems color wheel problem in your tv that gets problem after some time and you hear high pitch noise along with picture flicker.
Color wheel need to be replaced to solve this issue. Required color wheel is available with (click to view image of part and price info) and it is job of qualified tv repairman because light engine will take apart for that.
Hope these info will help you.
Mar 15, 2011 | Samsung HLN467W 46" Rear Projection HDTV
How to take the washer kenmore apart to change the lid switch.
If this is a Kenmore top loader, the following link explains step-by-step how to access and replace a lid switch:
Replacement parts (if required) can be found at the following websites:
The average cost of these components varies, so shop and compare. The first three websites I listed have helpful exploded view parts diagrams that can help you locate and properly identify the parts you need.
If you have any questions about this repair, please post back with your MODEL NUMBER and let me know. I hope this helps you.
May 05, 2010 | Washing Machines
Funny colores and shapes on my 42" Toshiba projection TV
There are a number of possibilities based upon your description. Can you be a little more descriptive about the colors? For example, does the picture look like a 3-D one? Also, please confirm the model as that will help to identify specific defective parts and more detailed solutions.
Jan 30, 2009 | Toshiba 42H81 42" Rear Projection...
Akai LCT2785TA 27 in. LCD Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
