Question about Brother MFC 420CN All-In-One InkJet Printer
Black ink won't print, other colors work alright
  • 5 more comments
  • jaemom Oct 10, 2008
    Just changed black and color cartridges on hp deskjet D4160 - won't print black. color fine. took out black few times and reinstalled. still won't print.
  • nscoleman Nov 09, 2008
    Tried 2 different new cartridges and only color prints on test page.
  • Anonymous Nov 17, 2008
    I have the same problem. I have almost gone through a new ink cartridges by cleaning the print heads but nothing has worked. I have even tried doing the calibration and changed out the cables thinking that maybe it was a bad cable but nothing works. If anyone has solved this, please let me know.
  • Anonymous Nov 27, 2008
    I too have the same problem but check this out...when I put a new ink cartridge in the black doesn't print BUT when I put my old ink cartridge in it works just fine.I tried the new one 3 times then decided to try the old one. Is it possible that the cartridge is bad and not the printer??
  • solddeals Apr 15, 2009
    the same problem & its driving me crazy
  • roberta perez Apr 15, 2009
    had the same problem and followed what the 1st person said about take the new ink cart. out and put in the old one and yes it worked, i took back the new cart and they replaced it with another and it worked too.
    thanks for the tip. your awesome
    had the same problem with the black not printing, did what the 1st guy said to do, put back the old cart, and it worked.....the black ink prints, and the new cart had a defect, went back to store and they replaced it. and it worked also.
    thanks guest, your awesome
    Problem Solver:
  • 6 Answers
I had the exact same problem and this is how I fixed it. You have dried ink in the print head and cartridge slot and you need to loosen it up.
Remove the black ink cartridge and if you feel inside the slot, you will notice that it is dry and sticky.
Get a paper towel and soak it in warm water. Dab the wet paper towel in the empty cartridge slot and you will notice that all of that dried ink is now on that paper towel, continue to clean the inside of the slot, then dry it with a dry paper towel.
Run a couple of more cleaning cycles, then start to print. At first you will only see black lines, then run a couple of more cleaning cycles and try again. With each of these cycles you will notice that the text will become more and more clear until finally, it will print perfectly. Hope this helps.
Dave
Posted on Dec 18, 2008
Posted on Nov 11, 2008
4 Suggested Answers
KingDWS
  • 1606 Answers
SOURCE: MFC-790CW; will not print the black color..
You probably have a plugged print head or the black ink feed is plugged.
Depending on how bad it is you may find it easier or even cheaper to replace the printer.
If this is a ink caused problem you stand a chance of fixing it if you are patient but you might go through half an ink cartridge to get it working, If it is stubborn it can take 20 or 30 cleaning cycles before you see any black. You can try using household vinegar (dissolves the dried ink) on a qtip or lint free paper towel to try to clean the print head. To do this you remove the ink cartridge and very gently rub the towel with the vinegar on the print head. This might require you to move the print head to one side so you can see the actual print area (where the ink comes out). Keep doing this until the towel starts to come clean ie not as much ink coming off. Then run a few print cycles and if this works your printer will print as good as the first day you had it.
The next stage would require filling a old clean ink cartridge with vinegar and running cleaning cycles. Usually can be pretty messy and you should rethink buying a new printer but will really clean things out.
It is also possible that the print head has picked up clay or paper lint from the paper and this has hardened like a cement. That means replacement.
Posted on Aug 17, 2009
SOURCE: full of black ink & need to print black. other
I ran this process two months ago when the printer was 4 months in use.
Try running through the manual cleaning process for the print heads.
1-press ink
2-choose cleaning
3-choose ALL. If that doesnt work try cleaning BLACK only.
when the cleaning finishes the machine will go back to standby mode automatically.
see pg 172 in users manual under routine maint.
Posted on Jun 28, 2010
  • 1116 Answers
SOURCE: My Brother LC61, bought in
This is common problem with Brother Printers. I am going to assume you are using Non-Brother branded ink cartridges. Brother cartridges have a cleanser in the ink that most generic cartridges don't have. This in turn causes the jets to clog and not allow ink to pass through them. The fix is to go buy a couple of Brother cartridges and do a cleaning with those cartridges. You may spend some money doing this as a cleaning wastes a lot of ink, but it will clean the injection lines and fix the printer. You could also consider buying a new printer. I know this is not the answer you were looking for, but it is the true answer. I just bought a new printer due to this fact.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Posted on Jun 11, 2011
My Pinnacle Pro 901 is set to print using black ink only but it keeps telling me I need to replace color cartridges and won't print.
You won't be able to print if one of the cartridges is out of ink. The printer needs all cartridges with sufficient ink levels to prevent damaging the printhead.
Every time a cartridge is replaced, all colors are primed simultaneously thus the need for all cartridges to have ink.
Oct 25, 2012 | Lexmark Pinnacle Pro 901 All-In-One Inkjet...
My hp photosmart 5514 won't print. I put in new ink-black and color- and it goes through the motions, but the page is empty
I just had this exact problem on my HP 5514. Black won't print after running out of black ink. New cartridge no good.
I tried everything-no good. I suspected the pinholes in the printhead were clogged with dried ink because I didn't change cartridge in time.
The fix that worked perfectly was when I hacksaw top off old black cartridge & removed all foam wicks so now I had a funnel(can see clear thru). I installed the cartridge & filled it with alcohol, printed page & did head clean; then printed few more pages. Problem cleared almost immediately. I then soaked up extra alcohol inside cartridge with paper towel. Removed modified cartridge & installed good one. I guess this could be done for colors as well. I don't know if this is a proper procedure, but it sure worked well for me.
Oct 05, 2012 | HP Photosmart 5514 e-All-in-One -...
Why won't my Lexmark 5600- 6600 Series Printer print in color?
It could be the print setting on the application where you're printing from. Before you send your print job and hit "Print" button on your computer, check in the Printing Preferences and make sure it is not set to print "Using black ink only.".
Mar 06, 2012 | Lexmark Office Equipment & Supplies
The printer won't print. It says replace the color ink cartridge. All I want to do is print black and white.
You can only use the black ink cartridge without the color ink. But no need to replace them in your printer.
When you print just choose black and white for the printed text must be black not colored. But if you still received such notification...just try to replace the color ink cartridge to continue printing
Note: As per my experience. printer with exclusive black ink alone will damage the printer easily due to unbalance printing of ink
Sep 20, 2011 | HP OfficeJet 6210 All-In-One InkJet...
I have to print a word document in black. Because I have no yellow ink, the printer won't print anything. I have tried everything and just want to print a simple one page document and I have plenty of...
here's a solution i came across when dealing with the same problem. apparently the printer expects all of the cartridges to be full and has a sensor to make sure they are even when only printing black. hope this helps!
http://journal.drfaulken.com/trick-your-brother-inkjet-into-working-when-an-ink-cartridge-runs-dry/
Jul 13, 2011 | Brother MFC 490cw Color Inkjet...
Won't print black ink
Try to print with other colors. Change the font color to red. If that printed, then you need to change cartridge for the black ink.
Jul 12, 2011 | HP Photosmart Premium C309A All-In-One...
The black print won't print, but colour does, although very lightly. I have refilled the ink cartridges at Island Inkjet, so there is ink,..but black won't print at all.
your black ink cartridge got bad sprayer nozzles now you gotta replace it
and why the other color one is not bad yet cus printer as will known will depend on black ink far more so the black cartridge is heated up more times
May 27, 2011 | Canon PIXMA MP610 InkJet Printer
My printer has been printing for 3 days in a row now WITHOUT a black ink cartridge inserted! How is this possible? It prints black text alright, so it cannot be the color cartridge in there doing the...
If there is no black cartridge installed and the printer is printing "black", it's not true black. The printer combines the colors to make black. I didn't think that it would print at all with a cartridge missing. Learn something everyday!
Sep 17, 2010 | HP LaserJet 3050 All-In-One Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
328 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
