Question about Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway FPD1960 monitor power suply
So 8 months ago you answered someones question about a fried power suply and a possible replacement, i have removed and cleaned the power board and still dosent work, how much would you want for a replacement?
    Novelist:
  • 159 Answers
Cleaning won't do it.
It probably needs all new capacitors on the board. are any canister looking components bulged up at the tops ? This is the most common problem on the ones I fix.
ebaysbammbammfran
Posted on Oct 12, 2008
Gateway 19" lcd color monitor, product no. fpd1960 model no. 900g
The most common cause of power up issues with the Gateway FPD1960 monitor is a failure of the filter capacitors on the AIP-0100 power supply board in the unit. Here is a link to repair information for that board.
http://www.ccl-la.com/catalog/product_info.php?products_id=206
Nov 14, 2012 | Computers & Internet
Powers on but only get vertical colored lines
Try to replace all of failure capacitor on power inverter board.
Thanks for visiting FixYa. We answer your question for FREE. Please feel free to click on "YES" button in return. Have a good time...!
Thanks
Jun 27, 2011 | Gateway FPD1960 19" Flat Panel LCD Monitor
support.gateway.com/s/Manuals/Monitors/8511446.pdf OK manuals above and below. support.gateway.com/support/manlib/.../Monitor.shtml Below is how to repair your monitor step by step, hope this helps. http://www.ccl-la.com/LCDrepair10.htm
I looked for a service manual, but could find none :(
Jun 06, 2010 | Gateway FPD1975W 19" LCD Monitor
My monitor power on then cut off what can i do
I had the same problem with the exact same model of Gateway 19" LCD. Likely this is the same issue you're experiencing, and I hope you're able enough with a multi-meter and soldering iron to fix this issue, or willing enough to tear this thing down to its components and at least try to fix it.... otherwise you have a fancy dead-weight object on your hands/desk.
In my case, the 5V power was fried so I actually inserted a 5V 2A power supply inside the monitor housing and soldered the +5V and GND leads to the marked connector pins that connect the power board(larger) to the vga signal board(much smaller). I stripped the guts from the 5V power supply so it would fit easier, and then stole power from the 120v monitor input and directly wired that to the wires that were hooked to the 120v power supply prongs(after removing those prongs as well). The monitor looks and functions as if it were brand new, there's nothing extra hanging out and no bulges anywhere. It works excellent.
Aside from my more-so hackful approach, here's some links and quotes, from other sites, from people who know what components to replace on the power board and still achieve a well-working end result.
From: http://www.topix.com/forum/tech/TNTK13PFRQURRRJJC/p4
Sure-power wrote:
I repair the Gateway FPD1960, FPD1975W and FPD2185W monitors. You can contact me at sure-power@nc.rr.com if interested. If you can remove the power/inverter board it will save $$ on shipping costs. I have sucessfully repaired hundreds of these monitors. From: http://gatewaymonitors.blogspot.com/2007/09/gateway-monitor-recall.html
Russ said... Thank you Michael & Germel & everyone else for your help. I replaced the 5 470microfarad and 4 220microfarad caps on the FPD1960 and it works again. If your in the Metro Detroit area I can perform this repair for $60 onsite.
(insertabovename)@gmail.com
June 19, 2008 10:57 AM icon_delete13.gif b16-rounded.gif Russ said... russix
at
G Mail
Dot
Com
Feb 22, 2010 | Gateway FPD1960 19" Flat Panel LCD Monitor
Monitor will not power on - faint flickering when the power cord is plugged in. Gateway FPD1960 TFT LCD Color Monitor
Hi
i recommend the following
1) if your monitor has a 3 pin kettle type lead, please replace and see if this sorts the issue, if it is hardwired then unfortunatley your monitor is faulty and will need to be replaced/repaired
Please leave feedback/vote if this has been useful
Feb 10, 2010 | Gateway FPD1960 19" Flat Panel LCD Monitor
Where to get LCD Lamp?
Your problem may not be a lamp issue at all..it might be a power board problem.
May 28, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
FPD1960 model #900G
Try running the factory reset on it.
Feb 23, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway fpd1960 monitor not working
Sears can fix it about $80 an hour. or you can try the manufacturer of the monitor to see if they can fix it....shipping and handling would cost about the same as taking it to sears repair. would advise tring to fix it your self....take it to a professional.
Nov 12, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
19 "lcd gateway monitor will not power on.
Have you tried your monitor on somebody else computer?
Jun 14, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway FPD1960 19" Flat Panel LCD Monitor Logo
133 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
