ViewSonic VA902 19" LCD Monitor Logo
Posted on Oct 10, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Monitor is vertical display instead of horizontal display
My 2 year old managed to change the monitor from horizontal to vertical. So to view the monitor you either sit with your head on the side or turn the monitor on its side. Do you know how to get it back to a horizontal view.
We have a viewsonic VA902
Kazz
Anonymous
Level 2:
Champion:
  • Expert 293 Answers
  • Posted on Oct 10, 2008
Anonymous
Expert
Level 2:
Champion:
Answers
293
Questions
0
Helped
128280
Points
473
Hi...there! Kazz,
Go to your toolbars bottom R/H corner and look for the VGA settings icon ( nVidia or ATI). Right click on that...and look for rotation settings, from there just followed the settings... Have nice day!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 17, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7557
Points
Ctrl Alt plus arrow button!!
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
3answers
Monitor viewing position
what model of monitor do you have..?
My crt acer ac512 monitar only centre line view,c"not full view why?
there are several reasons why picture of crt monitors did not display good picture. if your monitor had horizontal line at the center of the screen?...the faulty is in the vertical deflection, check the vertical oscillator also the fusible resistors & capacitors around that section. if there had vertical line at the center of the screen?..check the horizontal deflection, horizontal output transistor also check the YOKE.
Monior displays vertical instead of horizontal
Nothing wrong with your mon. It is your windows display setting.
Go to display properties and change it back to normal.
1helpful
2answers
the keys ctrl+alt+right arrow should do the trick for you. if not then right click on the keyboard and select properties for options and you will find your graphics software has its own rotational software. good luck with two year old, sounds like you'll need it.
Fix the monetor view to horizontal view
Orientation can be changed to landscape mode by accessing the video card properties in the windows "Control Panel".
Monitor display is vertical instead of horizontal
What Video card are you using?
WIN XP
Right click Desktop>>>Graphics Options or
Right Click Desktop>>>Properties>>Settings>>>Advance
and change the rotation to NORMAL
For Intel Video card go to GRAPHICS Properties
For ATI Video card go to CATALYST
For NVIDIA Video card go to PHYSx
2answers
Horizontal lines on my monitor
I have a similar problem with a 2 year old Samsung monitor. I have tried to make a screen dump of it, but the horizontal lines do not show up then. This I have read indicates that the problem is in the monitor and not the video card.
Hansol 730E CRT monitor
REPLACE THE BOOSTER C 5,6nF-1600V
Top ViewSonic Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
