Question about Jensen VM9410 Car DVD Player
Blowing fuses on vm9410
Everytime i finish connecting my vm9410 jensen it keeps on blowing the mini fuse what could be the problem (ive used up about 5 fuses)
Use a bigger fuse or a smaller one
Posted on Oct 24, 2008
Odometer fuse keeps blowing when starting
Try a slow blow fuse? I think thats what they are called.
Mar 14, 2014 | 1996 Chevrolet Blazer
Unit will not turn on
check the fuse on the back ofthe radio. also chek the radio fuse for the car. make sureyour power connections and your ground is good
Sep 14, 2010 | Jensen VM9410 Car DVD Player
Jensen VM9410 - Stopped Operating All Of A Sudden
Sound like to me you got a problem with the capcitor inside the unit, if its under warrenty it will need to be serviced. If its not I ould be checking capcitors inside to make sure there not bulging leaking or otherwisen ot wroking correctly.
Jun 24, 2009 | Jensen VM9410 Car DVD Player
Bypassing E-Break
Just connect the emergency brake wire to earth (vehicle body)
Jun 17, 2009 | Jensen VM9410 Car DVD Player
Blowing fuses
Are you sure you don't have the positive and negative power wires reversed?
Does the fuse blow without remote voltage applied?
Nov 09, 2008 | Jensen JPA285 Car Audio Amplifier
Vm 9410
go to a audio local seller and ask them if they have one they should be able to get you one
Jul 10, 2008 | Jensen VM9410 Car DVD Player
Jensen vm9410 wont power up
easiest thing first. check the fuse on the hot wire on the radio harness. next, check to ensure the hot wire is to battery power, and the acc (likely yellow or orange) is attached to a wire that turns on with the ignition. next, check to ensure good ground. all this should take less than 10 minutes.
Apr 06, 2008 | Jensen VM9410 Car DVD Player
Tv tuner for vm9410
YOU CAN CONNECT THE TUNER TO THE AUX. CABLES. AND THEN JUST TURN ON THE TUNER AND SWITCH TO AUX MODE.. GOOD LUCK
Mar 01, 2008 | Jensen VM9410 Car DVD Player
Vm 9410
Make sure that you have a good ground, Connect the orange wire and red wire are both connected to a reliable ignition wire and that the yellow wire is connected to a straight battery source. And that your fuse, if any, is tight and good. If this does not help, there may be internal problem of many sorts.
Jan 23, 2008 | Jensen VM9410 Car DVD Player
Screen went dim
I have the same problem with the same head unit except mine is new out of the box. Is this a factory defect or is it something I can fix
Oct 11, 2006 | Jensen VM9410 Car DVD Player
Jensen VM9410 Car DVD Player Logo
123 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
