Question about Mag Innovision LT776s 17" LCD Monitor
MAG LT776s Monitor power cord
I misplaced my DC 12v 4.0A power cord and want to know where I could get another one or one that would work with this monitor.
  • Anonymous Nov 10, 2008
    That is funny, I have same problem, except that we have too many power cords, and don't know which is correct. One that we use the screen will flicker once in a while, the other makes a buzzing noise. The solution was great if it works, we tried ordering from 12 volt battery .com. I hope it is a legitamate site. I tracked down MAG Innovision, and they said you had to buy it from the manufacturer because it was proprietary. But she also said it was a 12 volt, and 4-5 amp power supply. Thank you fixya if it works.
    Brigadier General:
  • 6,966 Answers
Your description is the external power supply/adapter for a Mag Innovision LT776s 17 in. Flat Panel LCD Monitor. One may be purchased here. Aftermarket/replacements may be found here, here or here. Pls verify that the plug matches the jack and the polarity is correct. Additionally, if it would be a replacement, pls check the voltage and current rating.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 10, 2008
I bought a mag innovision model 780 monitor at a garage sale to use with my ACER mini laptop. This monitor has a manufacture date of January 2003 - it did not come with a power supply. Where is the power...
With Most Mag monitors, the plug is a simple 3 prong on the bottom side of the monitor. Though it isn't proprietary, it isn't a common power plug either. Radio Shack does carry this type of cord. Just look on the bottom side of the monitor itself. the three round plug "thingy" is where the 110v plugs in straight from the wall. Best of Luck!
Feb 03, 2010 | Mag Innovision LT776s 17" LCD Monitor
Power-Supply Plug in on Monitor not present ?
wait, is there not a power port? if ther isnt, it may be on the vga port where it connects to the pc, it may of got cut off, your alternative is opening up the mointer and wireing a new power port
Aug 27, 2009 | Computers & Internet
Power supply to Mag 780 Model
No, it has a normal, seperate power cord. But the socket in the monitor is very small, it's a small round one. When facing the monitor from the back, it's located directly to the right of the monitor-stand, at the bottom-side of the screen. Just put the monitor on it's side to see it clearly.
It's all explained with pictures in your monitor's manual which you can download from the official website here:
Aug 23, 2009 | Mag Innovision LT776s 17" LCD Monitor
MAG 780 Innovations LCD Monitor
The plug end (to the monitor) is a partial square end with three top angles. That plugs into the back of the monitor. You can see the plug socket from the underside.
Jan 29, 2009 | Mag Innovision LT776s 17" LCD Monitor
HDTV on Mag LT776s
that monitor wont produce the 1280x720 resolution. It isnt hdtv ready
Aug 07, 2008 | Mag Innovision LT776s 17" LCD Monitor
Factory mode on Mag Innovision LT776s 17 in
Sounds like one of 2 things.
  1. The internal bios of the monitor has failed and the monitor is pretty much wanting to know what to do. It is of course waiting to be programmed as it would have in the factory.
  2. Someone has knocked the front panel accidently pressing a combination of buttons to put it into factory mode. This is normally POWER + MENU held together when switching on. The only problem with this theory is after a power down, it should reset to nomal mode. It can be a different combination of buttons also, like AUTO and POWER or even all three together.
Apr 15, 2008 | Mag Innovision LT776s 17" LCD Monitor
I dont know about capacitors or regulators i just need to know how to turn this thing on.
on the specs from ebay I see you need a 12v dc 5 amp ac power adapter .
normally they have an led , but if you can't get power you will have to verify that you have the 12v at the tip, you will need a multimeter or 12v bulb connected to the end.
if your getting power then the panels circuit is at fault.
talk to a local geek about checking it out.
Mar 28, 2008 | Mag Innovision InnoVision LT 765S 17" Flat...
Mag Innovision LT776s Model 780
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Nov 23, 2007 | Mag Innovision LT776s 17" LCD Monitor
Mag LT776S Monitor (Screen turns black)
This is not quite clear. You say no image at home or at school but worked at the store Did you see it working at the store? Check the cord sonnector for bent pins and or replace the cord- then come back
May 16, 2007 | Mag Innovision LT776s 17" LCD Monitor
Mag Innovision LT776s 17" LCD Monitor Logo
964 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
