Locked channels on a tv
I bought a tv from a hotel (commercial rca) and some (most) of the channels are blocked... I can't watch any channel past 27... help!
    Scholar:
  • 142 Answers
You need to replace the eeprom IC in your set. Hospitality tv's ( i.e. hospital,motel etc...)have a eeprom IC that restricts programming and the use of the menu so guests can't mess up the tv picture or get unauthorized programming that they want you to pay for or just don't offer more than 27 channels. I have done this for customers before. The eeprom IC is an 8-pin IC that is right next to the microprocessor and is easy to change. Be careful soldering on an RCA board though...too much heat will lift the solder pads.Good luck!
barneyluc
Posted on Oct 10, 2008
RCA XL 100 Commercial Skip TV
Only thing I can think of here is to get a Universal remote, then try these pins to Sync your TV with URM:
RCA - 000,003,004,005,007,009,011,015,048,082,092,094,
096,098,101,102,103,107,113,125,129,067,179,187,188,191,194
May not work 100%, depending on remote functions.
Instead of just buying any, you could maybe borrow one from a friend first of all.
Oct 11, 2017 | Televison & Video
How do i reset this tv?
The TV will search for active channels and add them itself. Use the remote to select the on screen menu and go to the Channel Setup mode. Then just push the up arrow and it will add the channels for you automatically.
There is a possibility that this set has another "mode' where you can select "hotel" or "standard" if it's there make sure you set that to standard the "hotel" mode disables some of the features like the ability to set the channels. I can't find this owners manual on line for free (RCA usually won't provide them) I can't be more specific. I doubt that you got a copy of the owners manual when you got the TV.
Zashiban
May 31, 2010 | RCA F27442 27" TV
How do I unlock the tv's settings?
you should be able to go into your menu options. under channel set up. there should be an add or remove channel option and if your set has a locking feature it should be right in there that you'll find the unlock feature, Other than that, if you dont find it really the only other locking feature would be in your menu, under the parental control setting, this is another way to block and unblock channels as well, good luck. feel free to ask me any other questions you have!
Mar 24, 2009 | Zenith H27E55DT 27" TV
Hotel TV remote
for phillips tvs that come out of a hotel try this code with RCA universal remote. the big remote not a small remote. 319753 followed immediately by the mute button. this will pull up the tv setup menu.
Jul 31, 2008 | Philips Magnavox REM-350 Remote Control
Zenith TV not programmed for home purpose
If you have a remote that can access menu and your remote has number buttons and an enter key, you can follow this instructions to go to installer menu. Note that the installer menu is slightly different for each model, eg. some options are not available.
I was able to go to installer menu using two universal remotes. The remotes that I used were Dish Network 3.0IR and RCA RCU300WBL. Both remotes programmed for Zenith H2531DT TV. The reason why I had to use two remotes is that Dish Network remote was only able to access menu. It did not have ENTER key but RCA remote had ENTER key but I wasn't able to go to menu with that.
To go to installer menu (different from regular menu):
- Hold MENU for 8 seconds.
- Press 9, 8, 7, 6 and ENTER in the sequence.
You should be in the installer menu now. There should be a line that looks something like this:
03 VERT POS 13
Use SELECT button to scroll through each option, and ADJ button to adjust the values for each option. For example, to enable the front panel buttons on your tv, set KEY DEFEAT to 0. Other options that you might want to check:
CHAN LOCK which locks your TV to a single channel and wont let you change (set 0 to turn off)
START CH/VOL will set your tv to a specified channel when you turn on tv. (set 255 to disable)
You will have to look in the menu for some of the options because they are different for different TV series. A good place to find manual is on www.zenith.com or http://safemanuals.com/
I work in an old hotel and it took me few hours to figure out how to disable start channel lock. It drove me nuts. I hope someone finds this useful.
May 26, 2008 | Zenith SC652 Remote Control
Locked out TV channels
Need a make and model to determine what codes needed to unlock.
Jan 19, 2008 | Televison & Video
Trying to get channels above 42 to 99
I had the same problem the solution is you have to get institutional remote and reset the tv from commercial mode to consumer mode and then you will have access to the full menu. go to www.phillipsitv.com to get the directions. I actually asked a Hotel could I borrow their master remote used it and took it back and my tv works fine. Hope this helps.
Dec 01, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
