Question about Toshiba MD14F51 14 in. TV/DVD Combo
Television not working - help!
My tv shut off while I was watching it and it will not turn back on. It turns on for a quick second and then goes out again. I have unplugged it and plugged it in again as still nothing. I have only had it for 2 years.
  • laghiroli Nov 13, 2008
    same problem. tv went off during watching. every time i turn it on it stays on for about 5 seconds and shuts off automatically. have the tv for only 2 years. help????????????
    President:
  • 1,952 Answers
Chcek ur power and electricity problem then power plug loose connecntion
Posted on Oct 10, 2008
Turns off 10 second after i turn it on
Check in the Menu for a sleep timer or some type of timer that is shutting it off automatically. It should be in the TV's menu under the power settings or something similar.
If that's not it, or that doesn't work for you, leave the Television unplugged for a while (long enough for all of the settings to reset) and then plug it back in and see if the problem persists. If so, you may have to get the TV serviced.
I hope this helps :)
Best Regards,
James
Jul 29, 2009 | Emerson EWC1304 13 in. TV/VCR Combo
Cant turn tv on
may be your DM board is gone......
Mar 08, 2008 | LG RU-23LG10P 23 in. TV/DVD Combo
After watching tv for about 5 mins after first turning it on, there will be a clicking noise and the tv will shut off. I am unable to turn it back on it seems, until it cools off. thought there might be a...
Try blowing a fan across the television where it will help to cool the inner components and see if that helps. If it does, then you definitely have a fan out in the TV and it will need serviced. If it doesn't help, something else is wrong with the TV and it may need serviced. Or you could try unplugging it for a while to reset some things on it, and then power it back on and try again.
Best Regards,
James Trageser
Jul 21, 2009 | RCA D52W135D 52 in. TV/DVD Combo
TV turns it self off, after a few seconds of being on.
This television has had a problem with component failure. It turns on and then when it turn off it is going into protection mode to prevent further damage. The circuits in the television will go into this mode when they sense unusual voltage or current levels in the circuits. This television need to be tested for faulty component operation. The Customer support telephone number for Toshiba is 1-800-631-3811. Call them and give them the model number of your television and ask them where the nearest authorized service center is and for a telephone number. Give them a call and ask them how much they charge to estimate repairs for your model television. They should be able to help you. Then you can evaluate whether not it is worth repairing or replacing. I hope this information helps you with your problem.
Jun 09, 2009 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Tv turns itself off after bout ten seconds
Your over voltage circuits(hi-voltage and low voltage) are defective.When the voltage exceeds the specs it shuts off the tv.Unless your a service tech,you can't fix this.There are components on the main circuit tha t have to be changed.Sorry, no easy fix.
Jan 03, 2009 | Emerson EWC1303 13 in. TV/VCR Combo
Magnavox TV Model CT270MW8
we were watching a dvd and the unit shut off. We can't get the DVD door to open. Is there anything we can do to get the DVD to open and start playing a DVD?
Aug 09, 2008 | Televison & Video
Television Shuts Off
TRY REPLACING THE REGULATOR OR CHECK DIODES IN SAID CIRCUIT ,ALSO CHECK FOR BAD CONNECTIONS.
Jan 26, 2008 | Toshiba MD14FN1 14 in. TV/DVD Combo
TV wont stay on
The vcr carriage was probably damaged ( broken gear or carriage gear, etc ), As for repairing it, it may not be worth it and chances are, you won't find a new carriage for the unit. I have, in the past, disarmed the VCR unit and at least the customer could watch the TV. Thats not possible in every set, but it seems to work in the majority of them. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 22, 2007 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
TV Dilemma
you have a stuck vhs tape in it.
Oct 20, 2007 | Sylvania 6727FDE 27 in. TV/VCR/DVD Combo
My Tv is turning off by itself
if all you want to do is disable the vcr portion turn the set on , install a blank vhs tape it has to be blank or the vcr will try to read it .and the tv and dvd should work fine. this is a timing problem in the vcr deck its not hard to fix but it is a pain.
Nov 05, 2006 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Toshiba MD14F51 14 in. TV/DVD Combo Logo
204 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
