Question about Whirlpool Refrigerators
I just moved my fridge down a set of stairs and pluged it back in and now the heating element around the freezer is so hot you can't touch it, any ideas
    Sergeant:
  • 409 Answers
the heating element that you are refering to is the heat exchanger and it maybe possible that when you moved it, you disconnected it.
all you have to do is check to make sure that it's plugged in and also that you have no leaks.
Posted on Oct 10, 2008
Freezer not freezing
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Oct 30, 2013 | LG LFX25971ST Bottom Freezer French Door...
Freezer is all frozen
One solution:
This can happen if door has been left open. To solve:
Oct 28, 2013 | Samsung RF265AA Bottom Freezer French Door...
Freezer compressor is short cycling
Sep 06, 2013 | Electrolux Refrigerators
Warning light
Aug 04, 2013 | Bosch Classixx KGV28323 Bottom Freezer...
I keep getting water at the bottom of the fridge, under salad boxes on my Hotpoint fridge
Jul 03, 2012 | Hotpoint-Ariston HS3022VL Refrigerator
Westinghouse silhouette frost free 522 fridge is not cooling properly top and bottom.freezer fan is still working,and the motor at the bottom in the back of fridge stay's constantly running and has done...
The heating element, located behind the back plate of the freezer, is probably not working. A failed heating element leads to a build up of ice around the evaporator coils in the rear of the freezer. If the back plate of the freezer is removed (ONLY DO THIS WITH THE APPLIANCE UNPLUGGED FROM THE POWER SUPPLY) and there is a large build up of ice around the evaporator coils then it's a fairly good indication that the heating element is not working. The heating element comes on periodically to defrost/de-ice the evaporator coils. Heating element is often activated by a small timer switch which turns the heater on for a set time every 24 hrs or so. Heating element may be open circuit or timer switch may not be operating. Most likely to be open circuit heating element.
Jan 01, 2010 | Westinghouse Refrigerators
Heating strips which prevent door condensation over heating
MG,
During the move a hand truck got into the condenser fan and shut it down. Pull the fridge out and remove that cardboard cover in the back. On the left you'll see the compressor, on the right is the condenser fan. Make sure that there is nothing blocking the fan blade from rotating (I bet there is). Don't forget to replace the cardboard! It's crucial to the operation of you fridge.
After clearing the fan, plug it back in and you have your old fridge back! Cool, Huh?
Show me some love and rate this solution, will ya? Thanks!
SG
May 30, 2009 | Zanussi ZEBF250W Bottom Freezer...
Not as cold as it should be
see if there is ice on the back wall of freezer if so this is an automatic defrost problem timer heater or limit switch
Apr 17, 2009 | Whirlpool ED5SHAXM Side by Side...
The freezer is not cold enough - ice-cream is soggy! despite putting it on coldest; and the red warning light is permanently on. And I can't find the booklet. Help!
If the coils are frozen up already,putting the setting to coldest is the worst thing to do.Even though inconvenient,try unplugging for substantial amount of time (3 or 4 hours) to allow the coils to defrost.Be prepared for water leakage during this time.If this seems to work , chances are the defrost timer or defrost heating element are bad and the problem will recur after a week or two.
Jan 17, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
