Question about Dryers
Need wiring diagram for Maytag Dryer Model PYE3300AYW
  • Dryers Master
  • 19,396 Answers
You find wiring diagram inside the machine, in an envelope near to control panel.
Here instead you get exploded views and replacement parts.
Posted on Oct 10, 2008
My dryer makes a loud roaring sound then eventually stops and wont turn back on until it cools down
you lent vent may be clogged but I don't know much about driers sorry
Nov 12, 2013 | Dryers
Maytag_Owners_Manuals PYE3300AYW
For the dryer to take to long to dry is usually a sign of the vent duct work being restricted with lint. Check the vent hose, outside vent door, and the internal duct for lint buildup.
Oct 21, 2011 | Dryers
May Maytag dyer Performa Model number PYE3300AYW will not start the light in the dryer is off i turned to turn off and on the breaker but nothing happens. My question is that if the light needs to be...
no the light has nothing to do with the dryer not running, sounds like a breaker issue. You will need a multimeter and some screwdrivers. first make sure that the breaker has power, you will need to take the front panel off, then with the meter check for your 220 volts at the breaker(where the wires are hooked up), next check for voltage at the outlet, if all these have power then it is in the dryers cord, you will need to move the dryer out and remove the plate and check for voltage, if it does then you will have to trace it into the dryer. Good Luck Tim
Nov 25, 2010 | Maytag PYE2300AY Electric Dryer
No power to the dryer.just stopped working no waring maytag pye3300ayw
If there is no power at the wall outlet ... lease check your power panel for a tripped circuit. Reset it by moving the handle to the off position and back to the on position. If you turn it on and it trips again, you need a professional electrician to repair the short that evidently exists somewhere in the line.
Mar 08, 2010 | Maytag PYE3300 Dryer
How to lift the top of Maytag perfoma PYE3300AYW?
You will only need a putty knife. Unplug the dryer. In between the front panel and top there are 2 clips holding the top down on the left and right side. The clips will need to be depressed one at a time toward the back of the dryer and lift up on the top at the same time. The thermal fuses are both located on the element mounting assembly on the back top of the dryer. They will measure 0 ohms if good. Click this link, schematic diagram, number 3 is a picture of one of the clips. They are located anywhere from 2 to 6 inches in from sides of the washer.
Thank you.
Jan 25, 2010 | Maytag PYE3300 Dryer
Maytag PYE3300AYW Elec Dryer Runs, But No Heat
hello kellygubser,
If you are sure the thermal switch is ok.. have you checked the high temp ( bi metal snap switch) too? Here is a link to the wiring diagram of your dryer. You can see that there are a few other temp switches in circuit of the heating element that would disble it.. Hope this helps
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Jan 06, 2009 | Maytag PYE2300AY Electric Dryer
I have a Maytag Perform Electric Dryer Model #PYE3300AYW. It died in the middle of a cycle. All wiring has been checked, house breakers have been check, door switch has been checked. I replaced the...
If you have 240 volts going to the dryer the you will have a problem with the termal limiter, a set of contacts (normally closed) in the motor or your push button. Let go with the high limit since the pushbutton or the contacts are not in use when the motor is running.
Oct 22, 2008 | Maytag Dryers
I have a Maytag Dryer Performa Model PYE3300AYW that want run, light does not come on either. Checked Breaker and it was fine, even replaced breaker to make sure, still no luck. Checked thermal fuse and...
Look on the wiring diagram for the dryer. Follow black wire ( + side ) from plug to motor checking all devices in the circuit, also check for any on the white ( - side). Do all tests with the Electricity OFF. Safety first!!! Good luck. BpB
Aug 16, 2008 | Dryers
Maytag performa pye3300ayw dryer
Check for burnt or loose wires at the junction where the power cord attaches to the dryer. Also check the door switch. When you open or close the door you should hear a click, that usually means the switch is ok. Then open the cabinet top and check for broken wires.Check unit with power off / cord unplugged!!! Safety First. Good luck. BpB
Aug 16, 2008 | Maytag PYE2300AY Electric Dryer
Dryers Logo
744 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
