Question about Camping, Backpacking & Hiking
Flashlight I have a coleman flashlight its called a job pro and the head swilvels to a 90 degree and moisture had gotten into it and rusted the end spring and I like it but is it worth fixing and is there any warranty on by any chance Mr Ed
    Champion:
  • 242 Answers
You will not find a warranty on this item that covers you problem. These flashlights are not expensive ($5-10). If you want to fix it yourself do this:
Wear rubber gloves and remove any residue using a paper towel. Scrape off any hardened material with the end of a screwdriver. Now, clean the spring with one of those disposable nail files, sand paper, or a wire brush. After it's clean you can coat the spring in some Vaseline petrol jelly. Next time, take out the batteries when not in use to prevent this from happening again.
Posted on Oct 23, 2008
Replace batteries on flashlight
Maureen, Coleman Graphite Flashlight replace batteries. Remove bottom cap, it will be on tight, if you do not have good strength in your hands use a pair of pliers or channel locks. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to change the batteries in Mag Lite
Aug 26, 2016 | Coleman Graphite Flashlight
Replace batteries
Marcia Boal... hello,
If our battery has corroded it may be impossible to get the end (opposite the light) cap to come off. The light is designed to be moisture resistant... Likewise even penetrating oil cannot get in...
To guarantee long reliable service it is best to put a tiny dot of grease on the threads on assembly.
Maglite Solitaire makes a wonderful little flashlight...
(all metal construction... single AAA battery)...
((Mini = 2 AAA batteries... opens the same)).
Basic colors included black, red, silver & blue
but this particular light was also quite popular for commercialization... often displaying many BIG NAME
COMPANY LOGOs.
The initial closure of the end cap can be quite loose to be effective because of it's O-ring design... however some folks put the end cap on too tight...
The
It might take some serious force to get it open again.
Consider using a piece of leather in a pair of pliers to avoid marring the case. Reassemble without over-tightening.
Hope this helps!
Maglite Solitaire Incandescent 1 Cell AAA Flashlight Black Basic Handheld...
Amazon com Maglite Solitaire Incandescent 1 Cell AAA Flashlight Blue Home...
Maglite Solitaire LED 1 Cell AAA Flashlight Red Basic Handheld Flashlights...
Maglite Solitaire LED 1 Cell AAA Flashlight Silver Basic Handheld...
Aug 19, 2016 | Camping, Backpacking & Hiking
My flashlight don't work at all. since I drop it. Coleman LED Aluminum flashlight-2000004480. Also where can I get the same exact one.
In order for someone to help. We need more information, the manufacture name, the exact model number. Usually found somewhere on the device. That model number has to be the longest model I've ever seen. Maybe the LED is bad.
Apr 11, 2016 | Coleman Camping, Backpacking & Hiking
I have a coleman companion flashlight/lantern and need to disassemble it for battery replacement. i can`t fiqure out how.
Really? Put the flashlight down and slowly step away from it and if that doesn't work threaten it with a hammer?
Seriously did you read the package directions? The pointy end with the gray ring is the end most likely screws off to put the AA batteries in.
Jun 06, 2015 | Coleman Camping, Backpacking & Hiking
How do you open a Coleman flashlight
You need to specify the model of the flashlight. However, for most of them you simply unscrew the bulb head or the battery end cap, empty the old batteries and insert the new ones with the positive end of the batteries always pointing toward the bulb end and the negative end of the batteries toward the spring in the end cap.. Be sure to discard the batteries properly. Contact your local trash disposal company to determine where and how to dispose of them.
Jan 02, 2015 | Camping, Backpacking & Hiking
Wont start
If so, change the fuel filter! Simple job, but be safe and use only battery powered flashlight and mop up all spilled fuel. To check filter, use piece of rubber hose on end from tank and see if you can easily blow thru filter. BE CAREFUL as gas will spray from other end of filter. Catch all fuel in can and you can examine fuel to see if it contains rust or water.
Jan 01, 2014 | 1999 Chevrolet Tahoe
Camping, Backpacking & Hiking Logo
197 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
