Question about Alps MD 5000 Thermal Printer
Alps 5000md My printer begins the print job seems to get stalled and then orange error light comes on. The beginning problem occured when the printer stalled on a color cartridge and the print did not release. Upon restarting the printer, I noticed the printing was only blue and the next time I tried it was all black when it stalled. The cartridges stack and when they don't stack, the printer shifts the cartridge to another slot. Tried printing a test page, no luck. The printer error pops up several times in the lower right hand corner. Maybe when it is trying to change cartridges? Thanks for any help.
5 Suggested Answers
fcollingwood
  • 58 Answers
SOURCE: Alps MD 5000
Did you pack the printer correctly before moving? When you got the printer, it would have had a packing piece preventing any carriage movement. If you did not put this in place before packing the printer for the move, you have most likely damaged the printer beyond repair.
Posted on Oct 23, 2008
Cabe5
SOURCE: set up installation for 5000md xp will not start up
Cut or copy the driver zip file and go up a few levels and paste it on the desktop or in a folder on the desktop or in a folder in my docs and unzip ALL the files to this new folder and run setup. I had same problem. For some reason if you save the file 3-4 or more folder inside a folder inside a folder ect (you know...try to be organized?) it won't run. Whats more if you were to just move the SETUP.exe file and not the other folders (such as DATA) the install would start asking you for files that ARE in the data folder, asking you to point to them. If you did it would act like it couldn't see them...Why? I have no idea....all I know is once i moved EVERYTHING (all the files from the zip)up to the Desktop or a level below it like My docs, C drive etc it ran immediately and saw all files. You can run that SETUP and/or use add printer from control panel > printers and faxes
Posted on Aug 23, 2009
  • 83 Answers
When you moved, did you secure the print head and remove the ink cartrdiges? A Changer Error message is bad. Check the changer for any broken or bent parts.
Posted on Jun 28, 2010
  • 83 Answers
SOURCE: incomplete print job
Cartridge Changer Errors are series. Did printer work before you installed XP?
Posted on Jul 14, 2010
How to test the MD 1300 , also look on how to get error codes...
One test you can run is the self print test. Discount the printer from your computer. Load a single sheet of paper and the CMYK cartridges. Turn on the printer. Press and hold the "reset" button until the lights begin to flash. Release the "reset" button and the printer should do a self print test.
Dec 26, 2010 | Alps MD 1300 Thermal Printer
Have an MD 1300. printer begins then stops before actually doing the job. Get message: "cartridge change error - cannot complete print job." I have tried putting in a new cartridge but same...
What color are the cartridges that you are putting in? Are they blue or are they greyish in color? If you are trying to print on laser or other such paper, you need to be using the greyish cartridges. Also make sure that the cartridges that you put in have plenty of ribbon in them and that you've put them in facing the correct direction, you should be able to see the color names when you open the printer. If you don't, you've installed them facing the wrong way. Also make sure that you have all the correct colors installed for the print job. Unless you're printing strictly in black and white, you'd be surprised at what colors are needed to make a color, unless you're using pure Cyan, Magenta or Yellow. Any colors other than those will need to use a combo of those colors to reproduce colors properly. I hope this helps. If not, write back and say what steps you've followed to try to remedy the error.
Nov 18, 2010 | Alps MD 1300 Thermal Printer
Printer crashes
Hi Ann,
Check the ribbon cable that comes out of the back of the print carriage for damage / disconnection. They don't normally wear loose, but it is possible.Failing that, the print engine could have failed, which would deliver duff data to the heads, thus printing rubbish onto the page.
Mar 05, 2009 | HP DeskJet 670c InkJet Printer
Incomplete print job
Oct 10, 2008 | Alps MD 5000 Thermal Printer
Alps MD 5000
Sep 06, 2008 | Alps MD 1000 Thermal Printer
ALPS 5000
Cartridge changer error can be bad. Inspect and clean the changer. Try changing the order of the cartridges in the holder. Any effect? With just the black cartridge installed, try printing an internal self print test. Does that work?
Sep 04, 2008 | Alps MD 5000 Thermal Printer
Alps MD 5000
May 22, 2008 | Alps MD 5000 Thermal Printer
Ink module will not center itself
  1. Confirm that the printer is powered on and press the <Open> button (MP500) or manually pull open the paper output tray
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    NOTE: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Unpack the ink tank and pull the orange tape off completely in the direction of the arrow and remove the film.
    Note: Tear the orange tape carefully along the dotted line. If the orange tape remains, printing problems may occur.
    <4> Tape is completely removed.
    <5> Tape remains.
  5. Remove the orange protective cap located on the bottom of the ink tank by twisting as shown in the diagram.
    CAUTION: Do not touch the ink tank contact <6>. Doing so may cause printing problems. Do not squeeze the side of ink tanks as this may cause the ink to leak out. Do not reattach the protective cap once you have removed it.
  6. Insert ink tanks into the print head.
    NOTE: Press the mark <PUSH> on the ink tank firmly until you hear a click.
  7. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    Note : MP500 shown.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    NOTE: Click for Ink Tank Lamp indications.
  8. Close the inner cover and the scanning unit (printer cover).
    CAUTION: When closing the scanning unit (printer cover), be careful not to jam fingers.
    Memo: The next printing begins, the print head cleaning will begin automatically.
You can check the status of each ink tank according to the way its lamp flashes.
- On: The printer is ready to print.
- Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
- Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
- Off: An error has occurred and the printer is not ready to print.
Mar 28, 2008 | Canon Pixma MP500 All-In-One InkJet...
Getting error 681 "more thn one magenta tank instaleld" on MP530
Install the Print Head and Ink Tanks MP530 / MP800 / MP800R / MP830
Install the Print Head and Ink Tanks Instructions to install the print head and ink tanks.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
Follow the instructions below for Installing the Print Head and Installing the Ink Tanks.
  1. Raise the print head lock lever.
  2. Pull out the print head from its package, then remove the orange protective cap from it.
    Caution: Do not touch the print head nozzles <1> , electrical contacts <2>, or ink supply ports <3>. Doing so may cause printing problems.
  3. Place the print head in the print head holder and lower the print head lock lever carefully until you hear a click.
  1. Unpack the ink tank and pull the orange tape off completely in the direction of the arrow and remove the film.
    <5> Tape remains.
  2. Remove the orange protective cap located on the bottom of the ink tank by twisting as shown in the diagram.
    Caution: Do not touch the ink tank contact <6>. Doing so may cause printing problems. Do not squeeze the side of ink tanks as this may cause the ink to leak out. Do not reattach the protective cap once you have removed it.
  3. Insert ink tanks into the print head.
    Note: Press the mark <PUSH> on the ink tank firmly until you hear a click.
  4. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    Note: Click for Ink Tank Lamp indications.
  5. Close the inner cover and the scanning unit (printer cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    N
    ote: The next printing begins, the print head cleaning will begin automatically.
Jan 22, 2008 | Canon PIXMA MP530 All-In-One InkJet...
T420 error lights
does this occur after while, during or after printing?
from what application are you printing?
sounds like the print you are sending may be too big for the memory of the printer, or it can not recognize the file type.
Oct 16, 2007 | Lexmark T420d Laser Printer
Alps MD 5000 Thermal Printer Logo
67 people viewed this question
Top Alps Office Equipment & Supplies Experts
Jesse Walters
Jesse Walters
Samuel Konger
Samuel Konger
Are you an Alps Office Equipment and Supply Expert? Answer questions, earn points and help others
