Question about Belkin F1DK102U 2-port KVM Switch
Belkin F1DG102U switch - problem with the monitor resolution
The monitor resolution is lower when docked laptop hooked on via the KVM switch. ControlPanel's Display shows max resolution which is still lower than when laptop connected to monitor directly. How to go about this issue? Thanks, A
  • Lozicle Dec 03, 2008
    Exactly the same problem.
    Resolution from a laptop via the KVM is fuzzy to say the least.
    Please help !
5 Suggested Answers
jbjennings
  • 24 Answers
SOURCE: I have a Viewsonic VS11531 27.5 inch monitor I use
In the link below, on page 9 of the PDF the maximum stated resolution of the KVM is Up to 1920x1440 @ 75Hz.
http://cache-www.belkin.com/support/dl/p75457_f1da116z_man.pdf
The monitor supports up to 1920x1200 @ 60Hz.
It sounds like there is an issue of synchronization between the monitor and KVM. This will force the monitor into a lower resolution to sync them. You may want to check with Belkin to see if there is a firmware update for the KVM. There may also be a driver issue with one(all) of the video cards on the system. I recommend updating the drivers on all affected machines with the monitor connected directly to the individual machines. Rather than using generic drivers, I would use the drivers downloaded from the manufacturer of video cards and from Viewsonic for the monitor.
Posted on Nov 03, 2009
SOURCE: Using Belkin F1DG102U KVM the dell computer will not boot up
I have the same problem
have a solution ?
Posted on Nov 18, 2009
SOURCE: Scroll Lock doesn't work /BELKIN 2-PORT KVM SWITCH
What operating systems are these? Have yout ried hitting scroll lock 4x instead of 2x?
What brand/model of KVM are you using?
USB or PS/2?
Posted on May 06, 2010
SOURCE: screen resolution keeps switching
If its a usb kvm, check usb connections, one computer should stay fixed, the one that doesn't is your problem
Posted on Nov 22, 2011
Screen resolution keeps switching
Nov 21, 2011 | Belkin F1DF102PEA 2-port KVM Switch
Kvm switch screen resolution
Formore details please visit http://www.kvmconsolesolutions.com/
Nov 21, 2011 | Belkin F1DK102P 2-port KVM Switch
One computer is allowing the keyboard and mouse to be usable while the other is not. This problem happend about a year and a half ago and didn't come up again until I moved to a new warehouse and now it's...
remove old drivers and update them with new one by following this link
this allows you to use additional options....
http://tinyurl.com/f1dg102uuk
also you can download the quick installation guide found in the link above....
Apr 20, 2010 | Belkin F1DG102U 2-port KVM Switch
Power light went off
No, the switch is powered from the keyboard connection on your computer.
Feb 01, 2010 | Belkin F1DG102U 2-port KVM Switch
I have a Viewsonic VS11531 27.5 inch monitor I use a OmniView® PRO3 16-Port USB & PS/2 KVM Switch. The monitor has a res of 1900 x 1200 but when I hook it to the kvm switch the display will not...
Jun 28, 2009 | Belkin Computers & Internet
Audio with KVM switch
Check that the audio-cables from the "other" computer to the KVM are not near anything "bad", such as AC adapter for the speakers, or close to any speakers.
If you temporarily connect the speakers _directly_ to the "other" computer, does the "noise" go away?
Nov 11, 2008 | Belkin F1DG102U 2-port KVM Switch
How do I hook up a Belkin 2-way Switch with Audio Support and Cabling?
kvm switches are easy, they just dont look it with the number of sockets.
hook up your keyboard monitor speaker mic mouse cables to the output sextion of the kvm just as if you were hooking them to a single pc.
hook the cables from the pc-s as if the kvm switch were the peripheral devices,
so that all the outputs from pc 'A' are connected to the relevant inputs on 'A' side of the kvm,
all the outputs from pc 'B' are connected to the relevant inputs on 'B' side of the kvm
Jun 26, 2008 | Belkin F1DL102P 2-port KVM Switch
KVM Monitor resolution out of frequency and will not display
Restart your system in a VGA mode (you will find this below Safe Mode, by pressing F8 before windows is loading) This way yours screen resolution will be at the very low frequency then you can change it back to the resolution you like. Eg. 800x600 or 1024x768. Remember to keep your Screen refresh rate lower like 75Mhz
Oct 30, 2007 | Compaq (242697-001) 8-port KVM Switch
Problem with laptop connection
KVM's work best when you are using the same or similar type of hardware however there might be an issue with your video card interfacing with the KVM. I would switch the Video cables and see if the problem moved or disappeared. If the problem moves, then I would suspect the video card is the culprit. Since many problems can be traced to software compatibility issues, I would check to see if there is an updated driver for your video card and or your monitor first. If the problem disappears it could possible be a loose cable connection on the destop PC or the KVM itself. I would also try a different set of cables.
Jan 30, 2007 | Belkin F1DK102P 2-port KVM Switch
Belkin F1DK102U 2-port KVM Switch Logo
271 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
