Back to:
Tags:
Vanguard Vanguard 2-Way Lightweight Video Tripod
Conversion-Vanguard---> Galaxian
By Pasty - usenet poster
I've been looking at the pinouts, and being new at conversions, I see a few
things that may be a problem if I try this.
1- vanguard has +5v and galaxian has +5vdc or is this a typo??
2- Galaxian has 2 pins where it says -12v where vanguard at that position has
+12v
Can anyone help me out?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 26, 2006
FixYa! (100)
Cornish
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I'm sorry, I mislead you. I have it in the subject area, but I guess it
wasn't that clear. What I want to do is put a Galaxian board into my Vanguard
machine. I just had a question as to what to do with the different voltage
for these 2 games.
Jess
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Conversion-Vanguard---> Galaxian:
I don't want to Accept this solution
Solution #2
FixYa! (100)
kcw573
Rating: 0%, 0 votes
Probably, if your question was more clear.
Your subject: "Conversion-Vanguard---> Galaxian" leads me to
believe that you want to plug a Vanguard board set into a Galaxian
machine. If you really mean Galaxian (not Galaga) and it's a
standard machine, about the only thing that cabinet will easily run
besides Galaxian is Pacman.
In the days before switching power supplies games had line voltage
AC coming in that went to a transformer that output lower AC
voltages. These lower AC voltages went to a power supply that
turned the lower AC voltages into the needed DC voltages (usually
+5 VDC, +12 VDC, and sometimes -5 VDC).
The problem with Galaxians is that the part of the circuit that
turns the low AC voltages into the DC voltages needed is right on
the logic board so when you remove the logic board you remove the
power supply. To run Vanguard out of Galaxians you would also need
to add a power supply. A newer switching supply would work fine
but you still have some pretty extensive control panel mods to do
as Galaxians only has a 2-way joystick and a single fire button.
Rick Schieve email:
With the split of att.com and lucent.com, direct replies to me are
sometimes getting messed up. If you don't think you are getting
through to me send directly to the above address.
Thank You!
Can you Help with these Tripods problems?
Tripods
Where can I send my bad Gitzo tripod? One of its legs...
Tripods
Where can I get a replacement for the quick relase plate...
Tripods
should not support SD card
Tripods
Hi, I have a Focal (K-Mart) model# 20-08-87 that has...
Tripods
Any way to loosen the pan/tilt springs a bit for less...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
