Question about Kenmore Freezers
Items in freezer melting, Ice maker empty, fridge feeling warm
Checked manual and replaced water filter...also removed dust from back of fridge and compressor. Plugged fridge in again, hoping for the best. Water dispenser still works fine as well, water is chilled.
    Sergeant:
  • 409 Answers
you have 2 problems:
frist check the freezer thermostat and make sure that it's set to at least 5 or 6. if that is okay and you still have this problem, you may need to have the thermostat replaced and maybe more.
as far as the icemaker, if it's just the ice part that does not work, i would recommend checking the valve and water line coming into the icemaker.
can you tell me if this is a side by side or a top or bottom mount freezer? if you have the model #, that would be great.
Posted on Oct 10, 2008
Hotpoint fridge freezer ff200 tx displays error code A1?
These tempratures are pretty cold should be around 0 deg. but it sounds like you might have a bad defrost timer or defrost thermostat the frost should not come back if defrost system is working
Jul 26, 2014 | Hotpoint Freezers
Why does my daewoo fridge freezer works intermittently ?
You either have a faulty thermostat, a loose connection or most likely a build up of ice inside the freezer. I had the same problem. Almost replaced fridge. Took all the food out one day, took out the racks and disassembled bottom and rear and found a two foot log block of ice inside air return. Removed ice everything works perfectly.
Jul 22, 2014 | Daewoo Freezers
Hotpoint FZ175G red warning light comes on freezer still freezing after reset light comes on again after a couple of hours
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Sep 17, 2013 | Freezers
Fridgidaire freezer warming up
Sep 09, 2013 | Freezers
Siemens American fridge freezer with ice maker, freezer too warm and pipe that water flows from to ice maker is hot, not making ice?
That is a very bad sign, but before you unplug it pull the machine out from the wall and check to see if it feels hot back there as well. Then remove the lower cover and find the condersor fan motor. Its the only fan back there. I'd willing to bet that the fan is not running. The purpose of the the fan is draw air across the compressor and blow it through the condensor therefore lowering the temperature on both parts. When its not working/ running, the heat from the compressor and the condensor is pass onward to the machine and the machine then acts as a heat sink
May 11, 2012 | Siemens Freezers
FREEZER MAKING ICE, BUT FOOD IS THAWING
If you have a Freezer on the top model Kenmore, with warm temps in the fridge, AND water dripping onto the top shelf of the lower fresh food compartment (FFC), this is usually caused by a clogged defrost drain. Since Kenmore is not an actual manufacturer of anything, they take other brands, i.e. Kitchenaid, GE, Frigidaire, etc., take their names off and put on a shiny Kenmore nametag. This is a common problem with Kitchenaid refrigerators. You can determine if your Kenmore is made by kitchenaid by looking at the model # tag. the first three digits will indicate the manufacturer, Kitchenaids begin with the sequence, 106.*.If this is indeed how your model # begins, keep reading. Since the water cant go down the drain tubing to the pan at the bottom of the unit, it builds up on the freezer floor, eventually blocking the air return vents from the fridge to the freezer, and the vent from the freezer to the fridge. YOu can check this very easily. Look at the ceiling of your FFC, near the back. toward the sides you will see two square holes, about 2" square, stick your finger and feel around the inside of those holes, do you feel any ice/frost, or do you just feel styrofoam, you might even see frost/ice below the level of your ceiling? This drain usually gets clogged with defrost water that does not completely drain, then of course it freezes, eventually plugging up the drian hole located at the level of your freezer floor, behind the back wall. The water keeps accumulating, and freezing, on the freezer floor, eventually filling in and clogging the air vents..no air flow , the fridge wont cool. The easiest way to resolve this, empty out all contents and store someplace cold for 24 hours...a 2nd fridge, outside in a cooler if its cold like here in chicago. After its empty, unplug, open both doors and blow a fan for 24 hours. Prepare for an abundance of water due to melting ice.
After you defrost, you can plug it back in and it will be fine, HOWEVER, I suggest you take the back freezer wall off, you might have to take a floor cover off first, likely 2-4 screws in both the floor and the back wall. When you have the evaporator exposed, you will see a black cal rod defrost heater underneath the evaporator, as well as your drain hole just to the right of center underneath both heater and evaporator. Take a piece of 12-14 gauge solid, not stranded wire, removing the insulation and exposing the entire 6-8" piece of copper wire. wrap the wire around the diameter of the cal rod heater, 3-4 turns should be sufficient, and stick the other end of the wire down that drain hole. This will melt any ice that will build up in the future, everytime your unit goes into defrost cycle, so this wont happen again.
If air vents are clear of frost/ice, next thing to check is the back wall of your freezer, does there appear to be frost/ice/snow on the back wall? If so, your unit is not defrosting. On most Kenmores, this is usually caused by your defrost timer, located in the canopy mounted at the top of the FFC on Top freezer models, or your defrost thermostat, which is clipped onto the evaporator coil inside your freezer. Again, if its a 106 model Kenmore, this thermostat will have a pink and a brown wire coming into/out of it. My suggestion, if it isnt defrosting, change both. tjhe defrost control will connect with a plug, but you will have to hard wire the thermostat, ( cut wires from old, strip wire, and connect using wire nuts and electrical tape.)
Since y ou mentioned the water accumulation, more water recently, my diagnosis would be the former versus the latter, as the lack of actual defrosting coincides with lack of defrost water, however I'll never say never.
If your unit is a side by side model, check for ice on freezer floor...clogged drain. Check again for frost/ice on back wall, not defrosting, check same two parts, (the heaters rarely go bad on Kitchenaids, but never say never) You should also check for air flow into fridge, even if no frost / ice visible on back wall. Open the FFC door, and locate the air vent near the top, back of the fridge, on the left wall. While depressing the door switch, AND WITH THE FREEZER door closed, put your finger/hand near that vent. Do you feel any cold air? If you dont, you could have a bad door damper, not uncommon, or a bad damper control--> the temperature control WITHOUT the off or "0" position.
If any of this seems a bit overwhelming, I suggest you have a reputable repair technician check your fridge.
Oh, and lastly, you WILL NOT have two compressors, one for each compartment, nor will you have two sets of defrost heating elements, one for each half.
ALL cooling for 99% of refrigerators made in last 25 years takes place in the freezer, with the fridge being an empty box, except for an air intake vent, and an air exhaust vent which leads directly back into the freezer. When a refrigerator unit seems to still be cold in the freezer, but not cold enough or not cold at all in the FFC, its ALWAYS going to be caused by lack of air flow. But as you can see, there are a few things that can cause that lack of air flow.
Apr 05, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Slow ice cycle
Are you having any temperature related symptoms, i.e., soft ice cream that appears to have melted slightly and refrozen, soft breads in the freezer, warm or hot outer surfaces anywhere? If cooling is not a problem whatsoever, are any of your ice cubes smaller than normal, or do you have hollow ice cubes; you would be able to crush the cubes in your hand? If either of these pertains to you, you have not enough water coming to the ice maker, due to a faulty water valve not opening completely, or your water source pressure is low. disconnect your water line from the fridge, test pressure of the water line by placing end in a bucket, turning water on. It will be obvious how the pressure is. if pressure is good to really good, you have a bad water valve on the fridge. If pressure is so-so to bad, change source water valve.
If cubes are not small nor hollow, but rather normal full size cubes, just not enough, you probably have an intermittent problem with your icemaker, replace that.
Mar 31, 2010 | Avanti Freezer Compact Ice Maker - 12 lbs....
Ice maker not making ice
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips and replace it if it does.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Sep 03, 2009 | Freezers
Water pools at bottom of freezer, freezes and water leaks out
Hello, this sounds like you have a blockage in the drain tube, remove bottom shelf from fridge and remove the styrofoam..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Aug 31, 2009 | Freezers
Q: Does the water for the ice maker go thru the in-fridge filter?
the water should go thru the filter first then to everything else.
Jan 02, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Freezers Logo
135 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
