Question about Refrigerators
Find cut sheet for reach in freezer model of 2
GE 25 cubic ft refrigerator/freezer. Freezer on top. Freezer is working but there is no air getting down to the refrigerator. How do you fix that?
Posted on Nov 18, 2008
How doe I freeze fresh peaches
Blanch them in boiling water 1 minute, then dunk in ice cold water to peel. Cut them up removing the pit, and lay out in a single layer on baking sheets. Place in freezer for a day, then transfer to freezer storage bags and store in the freezer.
Sep 11, 2014 | Home
How do you remove the top to see the gears in a Royal 16CDX cross cut paper shredder. The overload message is displayed, and I don't know how to get it unjammed.
a possible solution is to UNPLUG the unit, reach in from underneath and start pulling stuck paper out. On mine (different model) I can remover the paper receptacle bin and reach up to remove stuck paper. this usually is caused by overloaded bin pushing shredded paper back up to cutters because it is overfull......BE SURE TO UNPLUG FIRST !!!!!
Nov 17, 2012 | Royal 160MX Also called 16CDX Cross-Cut...
Paper always packs up in the blades and it will not cut more than 1 sheet at a time. Sometimes not even that. Any solutions for this? I constantly have to dig the paper out of the blades, even after...
All x-cut shredders should be oiled. Buy some shredder oil ( this is a lightweight oil ) from your local store then pour some of the oil across the cutting blades where you insert the paper. After putting the oil in run the machine in reverse...this will help get the oil all thro the cutting mechanism. Then start shredding 1, then 2, then 3 etc, etc sheets at a time...when you hear the motor starting to "labour" to take the sheets thro'..then you have just about reached the point where "thats its maximum". You should occassionaly shred a sheet of paper with a bead of oil on it ( in an "S" pattern) to help keep the mechanism lubricated. Running the machine at about no more than 75% of its maximum capacity and regular oiling will prolong the machines life.
Dec 15, 2010 | Royal VF1012mx Shredder
Why would my Chest freezer be flooding my basement while it is still frozen inside
freezers still make condensation like air conditioners. they have a drain line heater to keep the condensate liquid until it exits the freezer. then it goes into a drain pain that usually has the high (hot) side line running through it to evaporate the water and at the same time increase efficiency. you probably have a rusted out drain pan which you can replace. you can make one from sheet metal and just seal the corners with RTV silicone, be careful sheet metal WILL cut you badly, so wear gloves whenever handling that stuff.
Oct 10, 2009 | Freezers
Need schematic Kenmore bottom freezer model # 79565002401
you can pull off the kickplate(underrthe freezer door, and if you reach up under theright hand side there will be( if no one has removed it) a tech sheet/ wire diagram for you r machine
Mar 10, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Need to remove the big piece of sheet metal on whirpool refridg
the rear panel is not removable. you need to clean the drain from inside the freezer compartment.
  • 1 remove food from freezer
  • 2 remove shelving and icemaker if equipped
  • 3 remover rear access cover in freezer usually 2 or 3 screw
  • 4 clean ice out from underneath the coil you will uncover the drain hole
  • 5 force hot water thru drain hole i use a turkey baster or large syringe
  • 6 reassemble in reverse order.
if you have any further questions please ask here and I'll be glad to assist any way I can. thanks Peyton
Mar 05, 2009 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Sheet of ice forms on bottom of freezer
Your defrost heater assembly has probably failed. Look at the ends of the heater for darkness like that of a bad neon bulb. Replace the heater assembly as a unit after removing the ice with a hair dryer. Becareful not to drop the glass heaters when replacing.
Jan 19, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
My freezer's defrost systems runs constantly
i dont think so i would look at the compressor kicking out on thermal overload or a faulty thermostat thermostats have two settings cut in cut out your cut in could be bad and not turning the compressor on till the temp reaches melting temps now if your hearing a click buzz then you need to look at the compressor and make sure the compressor fan is running but its not a defrost promblem
Sep 11, 2008 | Frigidaire Freezer Refrigeration White...
True Commercial freezer not cutting out
Tech. can not find freeon leak in line but endicator is regestering freeon leak in side of back panel.
Jun 04, 2008 | True 52 cu. ft. / 1472 liter Commercial...
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
