Question about Entrega (HUB-7U) Networking Hub
Mac hub 7
I had to re-install windows XP on my HP multi Media 1170n.
now Entrega Mac Hub 7 usb hub doesn;t function right. Can't figure out all lights are red except one yellow, I think it is a mouse I have hooked up to it, the mouse works
but all the other devices don't. is there a gudie , I couldn't locate on your site. or do you have instructions for new driver, installation, etc.
Bob Price
rdp5000@aol.com
Where do I find drivers for a Belkin USB Hub?
Hi, when you connect a USB hub, operating system (i.e. Windows, Mac, etc ) it should install automatically a generic driver for it, only when you connect a device to USB hub, in example, a camera, you have to install drivers for that specific device according to its installation guide.
May 09, 2016 | Belkin Computers & Internet
How to download free driver for belkin F5U237
A driver is not provided by Belkin for this device. It should work with generic usb drivers found in windows or mac.
Feb 24, 2014 | Belkin (F5U237) 7-Port USB Hub
My hub cant find drivers
It's a USB hub, it doesn't require any special drivers. Just plug it into the computer and plug in devices. Be aware hubs have very limited suppliable power so if you plug in a lot of devices that use a lot of power and have no power supply of their own you will overload the hub and it will stop functioning.
If the computer is having problems identifying the hub. Go into Device manager and locate any yellow ? or ! devices right click the device, properties and post the status codes.
Device Manger Windows XP Right Click My Computer, Properties, Hardware Tab, Device Manager
Windows Vista/7 Right Click Computer, Properties, Device Manager
Comment if you need further assistance
Aug 17, 2011 | Targus ACH114US 4PORT USB HUB
Where can I find a windows 7 driver for the d-link dub h7 (7 port usb hub)
Manufacturer's site for this product:
http://www.dlink.ca/products/?pid=DUB-H7
Click on the Support Resources tab.
Click on Quick Install Guides
Your going to find that only Win98, WinME, Win2K, WinXP, Mac OS are currently supported.
Suggets tou write to D-Link to express your need: http://www.dlink.ca/contactus/feedback/
Jan 26, 2011 | D-Link DUB-H7 USB 2.0 7 Port Hub
Belkin F4U017 7 port USB hub Connected to a Windows Vista 64bit computer Windows updates are automatic When plugged into the computer, Device manager reports the hub as a "Bluetooth Radios: Broadcom...
I just had the same problem and was able to figure our a permanent fix.Judging by the date of you post, I'm guessing you've already remedied this problem one way or another. But just in case you haven't or someone else is having the same problem, I'll go ahead and post what to do. First, make sure you leave the USB hub plugged in right now so that Device Manager lists what it thinks is the Bluetooth device. Go into Control Manager > Hardware & Sound > Device Manager. Right click on Bluetooth device that is showing up in error. From the dropdown box, select Properties. Click the Driver Tab. Click Uninstall. Check "Delete the driver software for this device." Click OK. Unplug your USB hub for a few seconds, then plug it back in. Windows should now recognize it as a "Generic USB hub." You should be good to go. Just remember not to install that update again or try to update the driver for the Generic USB hub. If you do, you'll end up with the same problem. I hope this helps someone out there.
Sep 24, 2010 | Belkin (F5U237) 7-Port USB Hub
Lost mt power supply cable, can you tell what the input voltage is for the HUB 4U is?? Also can his be used om a Mac OX 10.4.11 Dave
Since the manufacturer is out of business, it is hard to find any information on this hub, but you can find more details here or here (for Mac).
The voltage for the adapter has to have an output of +5VDC with minimum 2.5A.
Important!!! - The inner post is positive and the barrel is negative.
And - yes - it can be connected to a Mac since both versions are technically identical.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Nov 04, 2009 | Entrega (HUB-4U) Networking Hub
His speed 7 port USB hub not responding - green light for devices does not stay on and device is not present in Mac window Mac USB ports work directly replugged all connections with no success
If it has its own power then it should be OK however if you have 4 devices connected pulling too much load then it wont work - check the devices to see if this is the case. Unplug one at a time and see what happens
Hope this helps
Mark
Aug 20, 2009 | Belkin (B5U034) 4-Port USB Hub
Usb hub
here's the compatibility requirements:
Compatibility PC with Intel® Pentium® processor; Windows 98 SE, 2000, ME or XP;
Mac PowerPC processor; OS 8.6-9.x, 10.X and later
http://www.dynexproducts.com/pc-357-2-dynex-7-port-usb-20-hub.aspx
you might want to update your drivers to the latest version
http://www.dynexproducts.com/t-drivers.aspx
Oct 14, 2008 | Dynex Computers & Internet
Dynex DX-7P2H
hello,
The media is compatible in the following OS:
So there is no need to install the driver;
for more info about the product is here:
best melnavz,
PS:
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
May 19, 2008 | Computers & Internet
7 port usb hub
5V DC 3.7A  center + Adapter : )      Jay........
Dec 30, 2007 | Entrega (HUB-7U) Networking Hub
Entrega (HUB-7U) Networking Hub Logo
Top Entrega Computers & Internet Experts
David Payne
David Payne
Are you an Entrega Computer and Internet Expert? Answer questions, earn points and help others
