Question about Maytag MER6772 Gemini Electric Kitchen Range
Display Malfunction I went to set the timer while baking a pizza and I got a "set or en" on the display of my Maytag Gemini Ceramic Top electric oven
  • 750 Answers
Hello murfraven,
Welcome,
You said, you went to set the timer while baking a pizza and I got a "set or en" on the display of my Maytag Gemini Ceramic Top electric oven.
How old is the range?
And the model number?
Threat it like an error code.
This can reset the system.
Turn the breaker off to cut the power for 5 minutes.
Then restart the breaker and try the range.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
If this does not remedy the problem, then the switch itself is bad.
Let me know how it works out.
Huuum, Please remember to leave a rating
Posted on Oct 17, 2008
Maytag cwe4800acb oven shuts off and display goes blank during heating
Display on maytag oven 8114p471-60 went blank - Fixya
www.fixya.com/.../t16018814-display_maytag_oven_8114p471_60_we...
Jan 20, 2013 - Stove top electric ignition still works fine, so there is power going to the .... maytag cwe4800acb oven shuts off and display goes blank during .
Oct 10, 2015 | Maytag CWE4800ACB 2.6 cu. ft. 24" Single...
My maytag gemini oven has been stuck in sabbath mode for months and holding the clock button does not help. It does this everytime we lose power and it stays off for months and will turn on when ever it...
This is from the Maytag website it explains how to cancel the sabbath mode;
To cancel the Sabbath Mode:
Press the Clock pad for three seconds.
Or
After 72 hours, the Sabbath Mode will end.
  • "SAb" will flash for five seconds.
  • The time of day will return to the display.
NOTES:
  • Sabbath Mode can be turned on at any time with or without the oven on.
  • Sabbath Mode cannot be turned on if the keypads are locked out or when the door is locked.
  • Most prompts and messages and all beeps are deactivated when Sabbath Mode is active.
  • If the oven is baking when Sabbath Mode is set, the Bake icon will go out at the end of the baking cycle. There will be no audible beeps.
  • If the oven light is desired while in Sabbath Mode, it must be turned on before the Sabbath Mode is started.
  • When the Sabbath Mode is started, the temperature display will immediately show the set temperature, rather than the actual oven cavity temperature. No preheat beep will sound.
  • The self-clean cycle and automatic door lock do not operate during the Sabbath Mode.
  • Pressing the Cancel pad will cancel a Bake cycle, however the control will stay in the Sabbath Mode.
  • If power fails, the oven will power up in Sabbath Mode with 72 hours remaining and no cycle active.
I hope this helps to return it to normal mode,
GENE
Oct 13, 2011 | Maytag MER6772 Gemini Electric Kitchen...
I have a Maytag Gemini range and the bottom oven is off by 25 degrees. When I set it for 350 it only gets up to 325 actual temp even though the digital display says 350. Is there an adjustment or do I have...
Sorry to read about your problem, I hope this helps you out.
OVEN TEMPERATURE ADJUSTMENT
If you think the oven is operating too cold or hot, you can adjust it. Bake several test items and then adjust the temperature set- ting not more than 10° F at a time.
To Adjust: 1. PresstheBAKEpad(upperorlower
oven) and enter 550° F.
2. PressandholdtheBAKEpad(upperor lower oven) for several seconds until TEMP ADJ is displayed.
3. PresstheAUTOSETpad-eachpress changesthetemperatureby5°F. The control will accept changes from -35° to +35° F.
4. Iftheovenwaspreviouslyadjusted,the change will be displayed. For example, if the oven temperature was reduced by 15° F, the display will show -15° F.
5. When you have made the adjustment, press the CANCEL pad and the time of day will reappear in the display. The oven will now bake at the adjusted temperature.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Maytag MER6772 Gemini Electric Kitchen...
OVEN WILL NOT BAKE , IT WILL BROIL
I have the same problem, I took off the back panel and noticed that the EOC (electronic oven control) board is blackened and most likley need to be replaced. My wife was cooking a pizza and she smelled a burning plastic smell, she looked in the oven and saw the pizza on fire and smoke bellowing from the control panel area. So i unplugged the oven and saw the circuit board did start on fire and fortunatly it went out before serious damage. No matter what you set the oven on the display shows it as being correct, but only the top element comes on and it is on HIGH!!!! DO NOT BUY FRIDGIDAIRE!!!!
Dec 22, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Maytag Gemini Electric Oven - Lower is not locked, but will not open.
Usually, starting with a COLD oven, turn the self clean on. Wait 3 minutes, then turn it off [cancel] WAIT 1 minute at least, do not immediately pull on the door. This should reset the lock sync. If you cannot get it open still, you may have a faulty sensor that thinks the oven is overheated, or at this point you could have a bent actuator rod from all the tugging!
May 01, 2017 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemini MER6772 keypad/ovens not working
I had same problem, error code F 1-8, shorted keypad. I was so frustrated I went ahead and tore it apart. There was a surprising amount of gunk and moisture between the plastic face and the actual contacts. I cleaned it up and let it dry out. It worked OK for a while, but the seal is not good, and moisture from baking is still getting into it. When it goes bad again, I'm going to take off the plastic face and just press the sensors with a pencil eraser. I'll probably replace the range within the year. No way I'm paying $385 for new pad + installation on 10 year old stove.
Dec 23, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Cannot figure out how to make oven work
Hi, try this and see if will help you. Most of the Gemini models are the same.
To set Bake:
1. Press the Bake pad.
• BAKE will flash.
• 000 will flash in the display.
2. Select the oven temperature. Press the
Autoset 0 pad for 350° F or the appropriate
number pads.
• Each additional press of the Autoset 0 pad will increase
the temperature by 25 degrees.
• The oven temperature can be set from 170° to 550°.
3. Press Bake pad again or wait four seconds.
• BAKE will stop flashing and light in the display.
Nov 20, 2007 | Maytag MER5775Q Electric Kitchen Range
Maytag MER6772 Gemini Electric Kitchen Range Logo
282 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
