Samsung CM42W5 Projection TV
I have a problem with my blue lens within my television. The Blue lens on my Samsung 42" projection TVhas a blue lining that sinks in from the top left portion of the screento the top right protion and sinks half way down. The picture is visible (seems almost transparent) within this section of the TV. Its a Samsung model: CM42W5. Theonly way I can use the TV is if I cover the blue lens entirely. Thepicture is visible just slightly distorted and of course....no blue ispresent.
Anything can help at this point.....Thanks!
SOURCE: Digital Array?
I have the very same problem. Was there a solution to landfill2004?
Posted on Sep 07, 2007
Shuttle83
  • 1139 Answers
SOURCE: My Hitachi 65SWX20B Model, made in 02, just developed Picture disturbance
Can you post a picture of the set. This might be a convergence problem. seeing the set will confirm this.
Thank you,
shuttle83
Posted on Oct 28, 2007
SOURCE: blue/green line left side of the screen top to bottom
I have a green line on the left side of my laptop, can you tell me what is that?
Posted on Sep 06, 2008
  • 4234 Answers
SOURCE: Picture shadow on rear projection Sony big screen TV
You have 2 distinct problems that should be addressed separately. Please repost the Samsung problem. I will address the Sony problem here.
If the "shadow" makes the picture seem somewhat of a 3D one, the problem is with the convergence circuit. This could be as simple as bad connections on the pins of the convergence ICs or defective ICs. If you can solder and would like to attempt the repair, update this and I'll provide more details and instructions.
Dan
Posted on Sep 25, 2008
SOURCE: Sony KF50WE610 Vertical Blue Lines Across Screen
the vertical blue lines indicate some interference from other electronic gadgets near your tv. it started showing up on my sony grand wega when i installed my wireless modem. i almost ordered a new rear projection lamp costing over $100 but decided to experiment. i first moved my desk computer farther away from the tv then isolated the wireless modem router by placing it inside a small glass - the vertical blue lines became lighter in color so i dedided to find another small glass that fit inside the first glass container then put the router in the double glass - no more blue lines and my wireless modem router still works.
do some deductive thinking to figure out what's messing up your tv and isolate the interference.
good luck!
Posted on Jan 19, 2009
I recently bought a samsung hcn4226w at a yard sale for $50. Thought it was a good deal, but when i got home I saw the picture had a double image and the picture doesn't seem bright. After some tinkering...
This tv have convergence problems.Ur tv convergence board the 2 STK convergence ICS are defective,and some or all it resistor are dead.Try website like Tvrepairworld.com to buy a whole refurbish convergence board for the replacement.Spend about $100 dollars more this tv can be save.
May 14, 2010 | Samsung HCN4226W 42" Rear Projection...
Colour has screwed up
Call Encompass Parts Distrubtion 1-800-638-3328 its either your DMD board 180.00 or Light Engine and they do not have any in stock Cost $1,056.00 Try UED 1-800-648-6657>
Dec 31, 2009 | Samsung HLN5065W 50" Rear Projection...
Cannot not line up the red and blue lines on my samsung projection tv. it is a 2002 samsung tv
Needs new convergence amps and possibly a few low ohm resistors.
Those Samsung amps usually run hot to the touch and sometimes only last 4 to 5 years depending on usage.
Apr 20, 2009 | Samsung HCM4215W 42" Rear Projection...
Blue ghost
Replace convergence IC'S and check values of convergence circuit resistors.
Aug 07, 2008 | Samsung HCN4226W 42" Rear Projection...
Studioseries (samsung) 42" rear projection tv red duoble outline of picture
sounds like the red convergence Ic is weak ready to go out. try replacing the ICs around 10.00 do the blue as well as that will be next.
Mar 18, 2008 | Samsung HCM4216W 42" Rear Projection...
AKAI PT55
The green convergence can only be adjusted through the service menu
Feb 10, 2008 | Samsung HCN4226W 42" Rear Projection...
The color on my PCL542R is off...
try turning up the blue drive alittle see if that helps.
Feb 02, 2008 | Samsung PCL542R 54" Rear Projection...
Samsung rear projection tv
It probably is see if you can align the convergence manually or auto if available, you can order just the convergence ic's or the convergence amp board, whichever you prefer. check pricing and availability. also check Blue crt for faded picture, usually dirty crt fluid, makes picture dark and discoloured. If it is you may need to replace the blue crt also. this gets a little expensive, again check pricing hope this gets you started RFT
Jan 06, 2008 | Samsung HCM4215W 42" Rear Projection...
Out of Focus
· Samsung parts for convergance problem
· http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Nov 24, 2007 | Samsung HCN4226W 42" Rear Projection...
Televison & Video Logo
175 people viewed this question
Top Televison & Video Experts
Electro Med Services...
