Question about Kenwood Audio Players & Recorders
Kenwood KR-A4070 blowing 5a 125v fuses
Radio was playing fine, and all at once stoped playing. Power trans seems to be working, will click on and off. I pulled top cover found a 5amp-125v fuse blown. Replaced fuse, but still blowes at plug in. Stand-by light still works, but have no sign of power on front panel. Why'll looking for any visual problems found a ceramic resistor/or what looks to be a resistor with crackes. (mpr 33d 0.22ohmkx2 YOUHYUN) This are the numbers that are on the part with the cracks in it.
  • rzrfreefr
    rzrfreefr Aug 05, 2013
    can you show a picture of where is it ? I have the same effects on KenWood KRF-V4550D
  • 4,234 Answers
I am guessing that the ceramic resistor is close to the output transistors. I would also guess that one or more of the output transistors has shorted. This causes a high current draw that is blowing the fuse. You could also have a power supply problem. The ceramic resistor is a .22ohm dual emitter resistor that is used in the output stage. The transistors located close by are probably shorted and should be replaced. Start there and let us know what happens once the transistors and the resistor are changed.
Dan
Posted on Oct 10, 2008
I can't operate my kenwood KR-A4070 receiver manually anymore, it only operates with factory remote. When it was new, I could manually press the various function button's..such as power-tuner-etc., an
Only a service person can help now. Likely you have a connection loose, a buldged cap or maybe just a transistor with a cold solder joint. Not being able to see it makes it hard to tell.
Jan 21, 2015 | Kenwood Audio Players & Recorders
My kenwood reciever kr-a4070 keeps blowing a fuse
have you tried a different outlet? something my be wrong internally
Jul 31, 2012 | Kenwood Audio Players & Recorders
2002 F150 SuperCab Power Windows via 5A radio fuse. Wierd!
The location for the circuit breaker is in the fuse box under your hood number 601. Its a 30a CB.
Aug 09, 2009 | 2002 Ford F150 Regular Cab
Sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Mar 05, 2009 | Sony STR-DE845 Receiver
Indentifying fuse type on tac0151 chassis
Are just regular fuses 5A/125V. You can replace them with anytype 5A fuses.
Jan 05, 2008 | Toshiba 50H81 50" Rear Projection...
6.3a slow-blow 125v fuse
It will work, the amp rating is most important, 125v / 250v does
not matter.......note: if you blow the fuse again, the TV will
need service.................T.
Dec 08, 2007 | Panasonic CT-36SX12 36" TV
6.3 slow-blow fuse
Important parameter is 6.3 amp slow-blow,voltage rating = 125v
or 250v OK, No Worries.............................T,
2 fuses blow on power up
Its the power pack on the system board. It has a short in it and causes the fuses to blow.....if your farmilar with replacing it you can order the part though the manufacturer.
Nov 15, 2007 | Pioneer SD-582HD5 58" Rear Projection...
Toshiba 50H81 TAC0151 Blowing Fuses, I Need schematic
Well without the schematic, knowing Toshiba they have alot of convergence problems, so see if the fuse blown in the convergence area, if you you may have to replace convergence amps. These are the big STK's. Most of the time there was a color problem with set before going out. If no problem with this on your set then look in the HV area Hor. and Ver. area. Hope this helps!
Sep 09, 2007 | Toshiba 50H81 50" Rear Projection...
880 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
