Plasma HD TV Picture blue color static
There is a light blue static/distortion in color that appears mostly in darker screen shots. It is getting worse. I call it static because it comes and goes and changes shape slightly. It appears as a glare, unnatural color on lighter areas in darker screen shots. It also appears as light blue static sometimes in the upper edge and side of the screen, agains coming and going and slightly changing shape
    Top Expert:
  • Televison & ... Master
  • 76,099 Answers
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Posted on Aug 02, 2017
SOURCE:
SOURCE: blue tinting appearing on the right side of screen on vpl-es1 projector
A warning in the manual was given as to be carefull when using this projector with games as some parts of the screen will not move, just like if you watch Tv on it and there is a channel logo in one corner that doesn't move! It burns the display like it would on a pc monitor if no screen saver set. This is not a problem you can fix, that is perminant damage to the lcd in the projector!! S Platt
Posted on Jun 28, 2007
  • 1694 Answers
SOURCE: Yellow and Blue shadow on left side of screen
Blue convergence off = needs convergence IC's replaced =
Would you like step - by - step how to ??????
Posted on Nov 09, 2007
  • 39 Answers
SOURCE: static picture or flashing colors pictures wd-52525
HEY AWOOD,THIS SYMPTOM IS DUE TO POWER CAPACITORS GOING BAD IN THE POWER SUPPLY AND THESE CAPS CAN CAUSE A COUPLE DIFFERENT SYMPTOMS,YOURS SEEMS TO BE THE MOST COMMON.IF YOU'RE TECHY ENOUGH YOU CAN REMOVE THE BACK AND GET ACCESS TO THE TWO PLUGS ON THE LITE ENGINE TO TEST (WITH A VOLTMETER) THE 5 VOLT SUPPLY ON I BELIEVE PLUG J19 PINS 1 AND 3.IF LOW THEN REPLACE 6 CAPACITORS ON POWER BD. YOU SHOULD BE ABLE TO SEE IF THEY ARE BAD JUST BY A VISUAL INSPECTION.GOOD LUCK JOE TV
Posted on Nov 12, 2007
SOURCE: Distorted picture and multi-color words
You need to resolder the convergence chips. This is a very common issue with this line of TVs.
Hometheaterspot.com's Mitsubishi forum has detailed posts on how to fix this. Just serach for "55809 convergence" and you should find the info you need.
Posted on Dec 20, 2007
salt56
  • 373 Answers
SOURCE: Glare - HP Plasma TV Model PL4260N
Requires taking the back off: There is a module about 1 and a half inches square with 4 controls on it (looks like a small phillips screwdriver will fit.) Sits vertically. A yellow one on the lower left side. Tweek or turn it just a little about 2% and watch the picture and seen if the problem goes away. First unplug the tv before taking the back off and when back is off position the tv and yourself to turn the control and turn the tv on. You will need someone to turn tv on for you. Then do the tweeking with someone watching the picture for you
Posted on Dec 31, 2007
Blurry, purple bar across middle of plasma tv screen
Plasma screens are extremely susceptible to getting broken from any impacts to the face of the screen. What you are describing sound very much like distorted or dead pixels. It may not be a fixable issue, you may have to replace the entire unit or live with the purple bar. The reason you don't notice it as much when the screen is dark is because purple is on the darker end of the spectrum, and will be most visible in contrast to lighter ad brighter colors.
Apr 01, 2016 | Samsung Televison & Video
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    www.stereoandvideorepairco.com/.../DistortedPictureTroubleshooting.ht...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    removeandreplace.com/.../flat-screen-tv-has-lines-going-through-screen-...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
    yourbusiness.azcentral.com/distorted-colors-lcd-projector-8597.html
Feb 08, 2016 | Televison & Video
I have a phillip magnavox big screen tv it works fine but the color is too dark i think i need a picture tube
If its the one indicated here or one like it :
The picture tube type (CRT) rear projection tubes require annual cleaning.
With set off and back removed locate the three large black lens atop the chassis--hard to miss them.
The are the red, green, and blue tubes and are your light source for the picture---------if dark and they are dirty or dusty the picture will be darker and not as sharp or clear as it once was..
spray some glass cleaner on a paper towel and wipe them clean.
Do not touch anything else in set and do it with set unplugged.
put back cover on and see if picture is noticeably improved; if so do it once a year or more if in a dusty place.
Let me know if you have questions.
Mar 16, 2012 | Philips Magnavox 51MP392H Rear Projection...
I have a 46 inch Toshiba plasma tv. It is having a problem where the picture does not come up as soon as I turn on the TV. After about 20 minutes of warming up, the picture appears as normal but during the...
This tv is not repairable only can be replaced the Plasma screen itself.Not woth it,replacing the plasma screen,will cost the same as a new tv.This problems,u discribing is the Plasma screen itself sure comming to used and ages.Not any electronic boards componnent.Because the floorscents Plasma gas u seeing on the screen itself forming and lighting up the Plasma screen itself.
Dec 31, 2010 | Toshiba 42HPX95 42 in. Plasma Television
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
Just tonight we were watching TV and the screen got darker. Picture is still fine, just got darker, on some channels the top and bottom center bow in toward the center a little, easy fix or a lot of...
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 18, 2010 | Panasonic PT-51G53 51" Rear Projection...
My Toshiba cinema series HD separates the red & blue color.
*Screen Looks 3-D
*Colors wont align
Problem #2
Apr 18, 2010 | Toshiba 57H82 57" Rear Projection...
Red, blue and green dots appear on screen like snow
ask ur service provider and ask him to change ur revolution or ask him to change ur sreen
May 21, 2009 | Philips 42PF5331 42 in. Plasma Television
Static on 50
WHAT COLOR ARE THE SPARKLES? IF RED , BLUE AND GREEN, THEN IT NEEDS TO HAVE THE PANEL VOLTAGES ADJUSTED
Dec 08, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Color adjustment on Sony 36" Trinitron
Unfortunately, the CRT (Picture Tube) is reaching its very end. Your set is not feasible to service even if the CRT would still be available from Sony or any jobbers.
I would be seriously shopping for a new TV set!
Jerry G.
Oct 27, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Televison & Video Logo
164 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
