Question about Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher
Have a Viking trash compactor VUC181 that will not open. Appears latch is broke. How can I get it open?
I have had this same problem and found two causes. Latch was never the problem.
#1 - Ram not in full up position. To check remove top plate and attempt to run compactor - depressing microswitch when ram is at the top. If compactor will not run you can check the ram position by turning the primary screw drive with a ratchet wrench. When ram is at the top position attempt to open the compactor drawer. The stop microswitch seems to frequently bend out of alignment - check the microswitch positioning before resecuring top plate and adjust if necessary.
#2 - Can (or other debris) is wedged in between ram and drawer. Remove back cover and carefully inspect insides of the unit - use a flashlight. Pry out any debris that may impede the drawer from opening. Attempt to open the compactor drawer.
Good luck,
Jon B.
jbroccoli@aol.com
Posted on Oct 21, 2008
Whirlpool Trash Compactor, Model No. GX900QPPS2 will not compact trash. It will only make a humming noise
drive gear broke on motor shaft,drive kit #882699should fix you.appilance parts pros.com is a good place to get it.
Oct 08, 2013 | Kitchen Appliances - Others
Compactor will not close and latch. I removed the trash bag and installed a new one then closed the drawer like normal, only drawer would not stayed closed. It just bounces back out.
you will need to remove the entire Drawer to see if somthing fell behind inside.
Most of the time you can pull the drawer all the way out and lift the front of the drawer and pull it out.
Feb 21, 2010 | KitchenAid P Series Trash Compactor -...
Trash Compactor Model GCG1500LOBB. the foot
I also found that after 2 years my GE Profile Trash Compactor (purchased in June '07), the pedal was hanging down on the left side. I searched the internet and called GE to no avail.
After a few attempts, I finally solved the problem by removing the screw on the left side and adding a metal "L" bracket, with the bottom of the L flush against the back of the front panel. That way, when you depress the pedal, the screw can't pop out of the metal it's attached to.
Dannys00
Dec 21, 2009 | GE Profile GCG1580LSS 15" Built-In Trash...
Viking trash compactor DUC180
any appliance part place you need your model number.
if you have your owners manuel it may say who to call
Nov 23, 2008 | Viking 24 in. Professional Series VUD141...
GE Profile trash compactor is stuck
This has happened a couple times to me and the fix is fairly simple. The problem is the trash ram is pushing down on the edge of the metal of the trash compartment because the door is partially open. The solution is to back-up the ram the the door will close.
To back-up the ram, you will need to pull the compactor out from under your cabinets and unplug it. Turn the compactor on it's side to expose the bottom. There is a plate on the bottom that covers the motor gears. Remove the plate and turn the large gear counter-clockwise to back-up the ram screws (at least this is how it works on my model works). The gears are a little greasy so you may need to add some after messing with the gears.
Good luck.
Oct 21, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
Stuck Trash Compactor
I can't get to the rear of the compactor. How do I get the front off to get to the rest of it?
Mar 14, 2008 | Dishwashers
Trash compactor problem
I have had this problem on my GE Monogram. The 'smasher' is near the bottom and does not move anymore, even though the motor is working.
What I did was to get a crowbar that would fit through the crack and hook the underneath side of the bottom plate. You also have to hold the switch so the motor runs with the door open and pull up on the plate until the drawer can be slide out. The trunnion nut (a plastic nut) was cracked. I replaced it 3 years ago, and it just cracked again. They now make it out of metal, so maybe it will last longer. Ordered it from appliancepartspros.com.
Jan 11, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher Logo
927 people viewed this question
Top Viking Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Lloyd Carter
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
