Question about GE WBSR3140DW Top Load Washer
Washer overflowing washer over fills and i checked the pressure switch hose, its fine.when i blow in the hose towards the pressure switch it just clicks back and forth from fill and 9 mins.It just keeps filling.What can i do now?
    Sergeant:
  • 409 Answers
Is the pressure switch working. that would be the next thing that i would check. it's mechanical, so you'll just have to see if it engages.
Posted on Oct 10, 2008
  • pjc6912 Jul 29, 2011
    I have had the same problem but I checked the pressure switch and it engages. I can hear it kick in. When I blow in the tube it engages and the water stops, when I stop blowing the water starts flowing again. It fills to high and goes out the overflow tube during the spin. When I disconnect the tube from the box on the side of the tub water comes out, I can also follow the tube as it fills with water. It just doesn't stop at the proper height. Help, I replaced the water level switch and the same thing happens.
I am getting an FH Error Code. The water fills fine but I think it is overfilling because the water level reaches about half way up the door and triggers the FH error. I start the drain and spin cycle...
Washer fills with water and overflows:
The water pressure level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective.
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED).
The other item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board.
Mar 31, 2015 | Washing Machines
When I turn the washer on it fills but then does not stop I have tested the pressure switch what else controls the water solenoid ?
IF NOT THE PRESSURE SWITCH I SUSPECT UR WATER INLET VALVE OR CONTROL BOARD ISSUE.
Mar 29, 2015 | Washing Machines
Lxr6232eq0 whirlpool washer timer does not continue cycle and overflows?
Mar 12, 2015 | Whirlpool Washing Machines
Ipso washer keep filling up with water
Sep 23, 2014 | IPSO Parts IPSO 111/01705/00 Washer PANEL,...
Why does my washer overflow and not agitate?
Jul 29, 2014 | Whirlpool Inglis IP4400 Washer
Water fills washer
Jul 09, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Simpson top loader overflows
Feb 21, 2014 | Frigidaire FGX831C Top Load Stacked Washer...
Washer overflows
Feb 13, 2014 | Frigidaire FGZ831A Top Load Stacked Washer...
I have a Whirlpool stacked washer and dryer combination. The water is overflowing on the washer. It happens during the rinse cycle when the water is filling up. It appears that the cycle gets "stuck" in...
check the pressure hose. a kinked clogged or disconnected hose continues to fill. the pressure switch senses the air pressure in the hose.awaiting your further comments. thank you.
Dec 23, 2008 | Whirlpool LTE5243D Top Load Stacked...
Overflowing
This is a symptom of a pressure switch problem. Open the console and double check the pressure switch (located behind the water level knob) and make sure the rubber hose is still attached. In many case, this hose vibrates loose and comes off the pressure switch. Without the hose attached, the pressure switch never senses the change in pressure from the wash tub required for it to be shut off. The end result: your washer continually fills without shutting off. If it is a simple hose problem, you can prevent this from reoccurring by placing a small zip tie around the air hose at the point where it attaches to the pressure switch. Do not over-tighten as you may damage the switch fitting. Just make it snug.
If the air hose is still attached, and the electrical connections are still attached, replace the pressure switch. I could not find a part number with the model number you listed this under. Please double check you model number again and post back, so I can assist you finding the correct part (if needed). I hope this helps you. Let me know if you have further questions.
Jun 11, 2008 | GE WHRE5260E Top Load Washer
GE WBSR3140DW Top Load Washer Logo
71 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
