Question about Goodman GDS80703ANA Open Flame Mid-Size Heater
Pressure switch I have a fault code for a open pressure switch. Do I just change the switch or can there be another problem
  • glennpc Nov 19, 2008
    I have the same model furnace with the same problem. Sometimes it cycles normally but then its next cycle shuts down prematurely with a "pressure switch stuck open" fault.
  • ateter4358 Jan 21, 2009
    i am recieving a fault code open pressure switch. I have replaced the pressure switch and the control board. Any suggestions?
I replaced the pressure switch last week and the new one did the same thing. Then I discovered the cause by accident. With the breaker shut off I was poking around the wiring looking for loose connections. I noticed that the wiring harness plugged into the control board was not supported in any way. I have considerable electrical/electronics experience and one thing I know is that you never hang anything from plugs or connectors. Playing my hunch I tied off the harness so it wasn't hanging from the plug any more and now the furnace works normally. Apparently the weight of the harness hanging from the connector has damaged its connections on the control board. I'll probably have to replace it eventually but for now the problem is solved. I suspect this poor design feature may be connected with Goodman furnaces being notorious for control board failures.
Posted on Nov 30, 2008
  • 34 Answers
Go ahead and change, or have changed the pressure switch.  they're not too terribly expensive and they are real easy to put in.  we have them in stock and can ship it out on monday.  we'll need the full model number of your unit to make sure to get the correct one priced for you.  you can send a request to our office via our parts website at:  http://hstrial-cseagraves1.intuitwebsites.com/hvacpartsnet.html
Samsung model wa 7584C1. has 1E error code have changed pressure switch and tub hose still shows the same error please help
IE - Water level sensor fault This fault code is fairly self-explanatory and tells you that the washing machine has detected an error with the pressure sensor or pressure switch
  • Check water level sensor
  • Check wiring to water pressure sensor
  • Check connections to water level sensor
  • Check main electronic controller
  • Apr 06, 2015 | Samsung Washing Machines
    Have a kenmore elite washer f35 fault code help!!!!!!!
    this is to do with a pressure switch ..take the pipe of and blow in to it ..then blow into the switch..put together..and put on rinse a few times...ifstill the same change the pressure switch
    Mar 18, 2014 | Kenmore HE2 Plus Front Load Washer
    My washer is displaying the code F35 I can not open it, I can't turn it off, it won't change.
    F35 is a water level error.
    The water level switch (pressure switch) has malfunctioned.
    If you remove the top panel, three screws in the back, you will have access to the pressure switch.
    With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
    If the fault codes return after doing this, you will likely need to replace the pressure switch.
    Also - please be sure to use He soap.
    Jun 28, 2011 | Kenmore Elite 45986 Front Load Washer
    What this code is p-1784
    P1784-LR PRESSURE SWITCH SENSE CIRCUIT
    This is a transmission fault code. Diagnosing it will require the DRB3 scan tool, or equivalent aftermarket scanner, and the transmission simulator tool.
    Remove the VB(valve body) and the solenoid pack is easy to change and a shift kit comes with a non stick switch valve.In most of the cases is faulty solenoid pack causing this eror code.But there are other possibilities to.
    When Monitored and Set Condition:
    When Monitored: Whenever the engine is running.
    Set Condition: The appropriate code is set if one of the pressure switches are open or closed at the wrong time in a given gear.
    POSSIBLE CAUSES
    LOSS OF PRIME P1791 PRESENT.
    RELATED RELAY DTC
    Feb 23, 2011 | 2000 Jeep Grand Cherokee
    Trouble code p1784 on dodge grand caravan
    found this on another page.....
    Originally Posted by vasau viewpost.gif The vehicle came in with 2 trouble codes and complaint on a transmission shifting.
    P1775 Solenoid Switch Valve Stuck in TCC.
    P1784 LR Pressure Switch Circuit.
    After clearing these 2 codes the van ran normal for about 20 minutes without any issue, but after, the problems came back with no codes.
    LR Pressure Switch is always in "Open" position. Must be closed at Park, Rev and Neutral.
    Could anyone explain to me how the switch works. Is this the solenoid pack or the LR Pressure issue?The L/R pressure switch should be closed in P/N only. The switch should open when put into REV if the trans is not in limp-in mode. All switches will stay CLOSED if the trans is in limp-in mode. Disconnect the trans 8-way connector at the solenoid pack. Key on scanner hooked up apply 12 volts to the L/R pressure switch pin in the 8-way connector and watch for the switch to change from open to closed. If it does change the SSV may be stuck in the TCC position. You will have to remove the valvebody and inspect the solenoid switch valve to know for sure. The pressure switch itself is in the solenoid pack. If you have an old solenoid pack changing it is easier and quicker than inspecting the valvebody. Perform your diag for fault P1784. I believe the pressure switch is also closed in 1st gear also. Hope this helps.
    Jan 17, 2011 | 1996 Plymouth Grand Voyager
    While driving home in my 2004 Trailblazer it stopped driving while it was in Drive. I would press the gas and the engine would just revved.
    MANY THINGS WILL CAUSE NO DRIVE PROBLEMS.IF TRANSMISSION FLUID LEVEL CORRECT LEVEL AND TRANSMISSION FILTER BEEN CHANGED.SINCE TRANSMISSION PCM CONTROLLED SCAN FOR FOR TRANSMISSION FLUID PRESSURE SWITCH CODE.OR TRANSMISSION PRESSURE CONTROL SOLENOID FAULT CODE.LOOK FOR SHIFT SOLENOIDS FAULT CODES.LOOK FOR TRANSMISSION CONTROL MODULE FAULT CODE AND TRANSMISSION RANGE SWITCH FAULT CODE.IF NO CODES COME UP.YOU HAVE TRANSMISSION INTERNAL MECHANICAL FAILURE LIKE FORWARD CLUTCH AND INPUT CLUTCH HAS WORN DRIVE PLATES AND LEAKING PISTON SEALS.FAULTY TRANSMISSION OIL PUMP.HAVE TRANSMISSION PRESSURE TESTED.
    Dec 31, 2010 | 2004 Chevrolet TrailBlazer
    Would replacing the egr valve fix the other faults such as egr solenoid fault,egr pressure sensor fault and egr positionsensor fault
    The EGR valve can be tested with a Vacuum pump. If the diaphragm is bad, the valve will not change positions. Hence the error Code for the position sensor not opening to allow the valve to work. And the error code for the pressure sensor not registering a change in pressure because the EGR valve did not work.
    So both sensors can give a false Code. On the other hand, you will see both sensors have Vacuum lines and electric connections. When the electricity is switched on, vacuum is suppose to flow back to the EGR Valve. That is why the first thing you do is test the EGR Valve to see if the diaphragm is broke.
    If the EGR valve holds pressure it should be okay. Then you would want to check for pressure in the lines coming off of the switches. Remember to clear the onboard computer each time you replace a part, or you will get 25-35 Startups worth of false information.
    Both Autozone and Oreillys will scan or clear your car for free. I hope you find my solution very helpful. You usually don't have a complete failure of all 3 parts at the same time.
    Dec 12, 2010 | 2000 Ford Taurus
    I have a 2004 caravan with p0846 and shifts erractic
    Trouble code P0846 means: A/T 2-4 Pressure Switch Circuit Malfunction
    2/4 pressure is incorrect, or internal transmission faults exist 2/4 pressure switch circuit is open, shorted to ground or power 2/4 pressure switch is damaged or it has failed TCM relay power circuit to L/R switch is open (loss of B+) PCM/TCM has failed
    This possible causes are to be checked to confirm the fault.Thats it. Thanks.
    Dec 07, 2010 | 2003 Dodge Caravan
    Meaning of rudd furnace trouble codes
    Error Codes
    A green LED indicates system faults
    Steady On: System OK
    Steady OFF: Board control fault or no power applied
    1 Flash: Ignition failure (control in one-hour lockout)
    2 Flashes: Pressure switch fault, fails open (switch is
    stuck open)
    3 Flashes: Limit switch open (main or auxiliary)
    4 Flashes: Pressure switch fault, fails closed (switch is
    stuck closed)
    A yellow LED indicates flame status
    Steady on: Normal flame is sensed
    Flashes: As flame weakens, frequency of LED flashes
    increases
    Dec 12, 2009 | Heating & Cooling
    E60 error code
    Found These Fault Codes On Internet, Hope This Helps, Daz
    ALARM CODES
    E00(E00)- Problems with water fill during washing
    -Tap closed; solenoid valve, water distributor, wiring ,main PCB, pressure switches
    E01(E00)- Problems with water fill during drying
    -Tap closed; solenoid valve, wiring , main PCB, pressure switches
    E10(E10)- Problems with water drain during washing
    -Drain hose kinked, filter blocked, drain pump, water distributor, wiring , main PCB, pressure switches
    E11(E10)- Problems with water drain during drying
    -Drain hose kinked, filter blocked, drain pump, pressure switches
    E20(E20)- Door open
    -Cycle in Door delay, wiring , main PCB
    E21(E20)- Fault in door delay power triac
    -Wiring , main PCB
    E30- Fault in electronic pressure switch
    -Electronic pressure switch, wiring , main PCB
    E31- Fault in electronic pressure switch circuit
    -Main PCB (fault in electronic pressure switch circuit)
    E32(E10)-Calibration error in electronic pressure switch
    -Electronic pressure switch, drain pump, wiring , main PCB, filter blocked
    E33- Incongruency between electronic pressure switches and safety switch 1
    -Electronic pressure switch, safety pressure switch,wiring, main PCB
    E34- Incongruency between electronic pressureswitches and safety switch 2
    E35- Intervention of anti-overflow pressure switch
    -Solenoid valve, water distributor, wiring, main PCB,anti-overflow pressure switch
    E36- Water leakage (maximum number of resets exceeded)
    -Water leakage, drain hose too low, pressure switch,wiring, main PCB
    E40- Motor power triac short-circuited
    -Main PCB (triac short-circuited)
    E41- No signal from tachimetric generator
    -Tachimetric generator on motor, wiring, main PCB
    E42- Fault in tachimetric generator circuit
    -Main PCB (tachimetric generator sensing circuit)
    E43- Intervention of motor overload protection
    -Motor, wiring, main PCB
    E50- Insufficient heating during wash phase
    -NTC sensor setting incorrect, heating element, wiring,main PCB
    E51- Overheating during wash phase
    -Heating element (to earth), main PCB (relays)
    E52- Insufficient heating during drying phase
    -NTC sensor setting incorrect, safety thermostat,thermostats, drying heater, wiring, main PCB (relays)
    E53- Overheating during drying phase
    -Drying heater (to earth), main PCB (relays)
    E55- Fault in power relay for heating element (K3)
    -Safety pressure switch 2, wiring, main PCB- 6 -
    E60- Fault in washing NTC sensor
    -Washing NTC sensor, wiring, main PCB
    E61- Fault in drying NTC sensor(condenser)
    -Drying NTC sensor (condenser), wiring, main PCB
    E62- Fault in drying NTC sensor(duct)
    -Drying NTC sensor (duct), wiring, main PCB
    E63- Fault in 1/2 power thermostat
    -Drying NTC sensor (duct), 1/2 power thermostat, wiring,main PCB
    E70- Power triac to distributor motor short-circuited
    E71- Fault in power relay to distributor loads
    -Main PCB (relay open)
    E72- No distributor position signal
    -Water distributor motor, wiring, main PCB
    E73- Incorrect timing on distributor contacts
    -Water distributor, wiring, main PCB
    E90- Fault in tank fill pump
    -Hoses obstructed, tank fill pump, wiring
    E91- Fault in tank drain pump
    -Hoses obstructed, tank drain pump, wiring
    E92- Fault in power triac to tank fill pump
    -Tank fill pump, wiring, main PCB
    Jan 04, 2008 | Zanussi ZWF1440 Front Load Washer
    Heating & Cooling Logo
    312 people viewed this question
    Top Goodman Heating & Cooling Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Tim Whalen
    Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
