Question about Hitachi FDX Series 43FDX10B 43" Rear Projection Television
Model 43FDX01B double vision with red ark across bottom . and no user manual.
Problem started with just double vision and just lately has a big red ark across the bottom . if it were and OLD tv I'd say a gun was out of adjustment.
  • Hitachi Master
  • 3,459 Answers
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
model 43FDX01B  double vision with red ark across  - bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on May 30, 2010
I own a Panasonic HDTV projection monitor PT-47WX42C I am having convergence/warping issues; There is a large green/red curve in the bottom rear of screen about 4 inches tall, and stretching over more...
Replace the convergence ICs they will be big black ICs and will have Part number on them example STK392-110
Mats Electronics has them for 9.95 each you will need 2 .
1-800-628-1118
Sep 10, 2010 | Panasonic PT-47WX42 47" Rear Projection...
Tv has double vision all of a sudden unplugged cable to verify problem is W/ tv. Hitachi 43fdx01b
Convergence ICs STK392-110 replace both of them
Mats Electronics 1-800-628-1118
May 05, 2010 | Televison & Video
Red and green waves...double vision ...how old...how valueble...hitachi 43FDX01B
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 05, 2009 | Hitachi 43FDX01B TV
Cna not get red adjusted on the right side of screen
need to replace the convergence Ics STK392-110 there are two of them. Also check the six 2.2 ohm 2watt resistors
Mar 28, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Screen color problems
try the magic focus.maybe it will work.
Jan 31, 2009 | Hitachi 46W500 46 in. TV/DVD Combo
Phillips tv , double vision,
You have bad convergence IC's. Replace both the red and blue drive chips. They are easy to spot. They are mounted to large, finned heat sinks. The # on the chips starts with "STK-" and then there are numbers following. Both red and blue use the same part. There are 20 or so pins to unsolder\solder. These parts are available to the consumer from tritronicsinc.com. Good Luck!!
barneyluc
Oct 03, 2008 | RCA R52WH73 Projection Television
Double vision on my samsung HDTV 1080i
If one or more of the colors, red, green or blue have separated from each other and you can`t correct the problem using the convergence procedure as described in the users manual, that would indicate you have a convergence problem. Bad solder connections on the convergence output chips are common. If the set had a rough ride down the stairs while moving, that may have facilitated in exposing a preexisting condition. However, the most likely cause is the natural failure of one of the convergence output chips and or related components and not the move. The fix is to have a qualified technician address the problem. This is not a do it yourself job.
Feb 22, 2008 | Televison & Video
as the problem cannot be the rectified by the user. as it may require authorised service personnel. the problem might be with Tuner,video processing circuits. also mainly with the deflection circuits
Dec 20, 2007 | Hitachi 43FDX01B TV
MODEL 53FDX018
Faulty alignment mechanism or colour wheel.
Jul 27, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Hitachi FDX Series 43FDX10B 43" Rear Projection Television Logo
138 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
