Question about Hobart N50 Stand Mixer
N-50 rebuild help
I just received a vintage 1966 N50 that needs some gearwork. The motor runs- sounds like a big can opener- and the planetary will only spin in 1st gear, although the shifter will go into 2nd but not 3rd. Can anyone tell me how to get into the transmission? Do I need to remove the motor to get there?
Thanks,
Tom
  • tomthebaker Oct 10, 2008
    Just found a previous post and got the case opened. When I try to turn the planetary by hand, the gears are jumping. Cleaned most of the newer and old original-and hard- greases out. I don't see any "stripped" gears so far. I'd like to get all the gears really cleaned off for a more thorough exam. Any insights are greatly welcomed. Thanks again.
    Tom
  • 135 Answers
Remove the shiny drip ring on the planetary, use a small screwdriver and gently pry it off. Remove the "Tapered pin" that holds the planetary on the shaft, gently use a punch and a hammer to do this. This pin can only be tapped out in one direction. Pull downward on the planetary assembly until it comes free. Examine the small gear and bearing for excessive wear, examine the ring gear that remains in the mixer body for wear. Clean and re-grease these gears if they look OK. These gears are in operation in any gear and as such, receive the most wear. When re-assembling the planetary re-install the tapered pin the way it came out. The previous solution will address the transmission gearing. Replace parts as necessary. Good luck. Please rate this solution if it helps you. ricardok45
Posted on Jan 04, 2009
  • 49 Answers
There is what is called a gear cluster it has a fe gears all together in a bracket it should be held in postion to mate gears with a spring. check the spring.
Posted on Jan 01, 2009
Kitchenaid professional 6000 My mixer has a problem and I know it's in the planetary but cannot figure out how to open it. Any help would be appreciated. John
You need to remove the trim band (one screw at the back) that exposes 4 screw heads where the top cover joins the gear case. There are 4 screws from the top that retain the planetary assembly. I can't remember if you need to remove the motor to expose all of them. The motor is no big deal to remove.
Dec 08, 2016 | KitchenAid Food Mixers
Hobart N50 noises
The frequency is the same in all gears.
disconnect the power and invert the mixer and remove the planetary after driving out the taper pin, then you can access the transmission. It may be a rotor shaft bearing in the motor or no grease on the worm gears.
Nice touch with the video.
If you need parts:
Jan 04, 2014 | Hobart N50 Stand Mixer
Does the Kitchenaid Model G / Hobart N-50 have a motor capacitor?
There does not appear to be one listed in the service manual. The manual is here Hobart 50 Service Manual
Jan 30, 2018 | Hobart N50 Stand Mixer
Hobart N-50 Mixer beater attachment spins but has no resistance
Sounds like the shear pin on the planetary shaft has sheared off. Has the mixer been subjected to a heavy load. Remove the planetary and see if the shear pin is intact otherwise you may have to open up the transmission.
Ron
Jun 04, 2009 | Hobart N50 Stand Mixer
How to completely dismantle a Hobart N50 or KitchenAid Model G
If you only want to service the unit and not open the case, you can add grease through the gear shifter plate opening once you remove it. if you have a grease gun with a flex nozzle that's a bonus.
If not it is a messy job. Keep lots of paper towels at hand and use a narrow spatula to get the grease inside. Get as much in as you possibly can.
To remove planetary, with pin removed, spray a bit of wd-40 or other penetrating oil into where the pin came out of let it penetrate for a few minutes. Plan-A Take two screwdrivers and gently try to pry the planetary away from the body of the mixer. Plan-B Add a bit more lubricant to the shaft pin area and install a beater, then try prying with one screwdriver while putting downward pressure on the beater, alternate prying on both sides of planetary. Excessive force at the planetary top can/will crack it as it is a molded piece of metal. If you found this solution helpfull, please rate it. Good luck.
ricardok45
Nov 19, 2008 | Hobart N50 Stand Mixer
Hobart N50 / KitchenAid Model G: how do i remove planetary?
you need to remove all the back screws then if it doesnt come tap it with arubber mallet it may be seized on
Hobart N-50 mixer clangs on 1st and 2nd speed
CE is the marking that shows its european conformant.  I think the difference is mostly in terms of the no volt interlock switch.  This means the KA style N50 bowl won't work with the CE models - too low.
Jun 03, 2008 | Hobart N50 Stand Mixer
Noisy Hobart N50 Mixer
First, there is a double set screw (one on top of the other - if they are both there) towards the back of the planetary.
Remove the first screw, it should have a normal tip, not pointy. Run the mixer in 1st and adjust the screw, first out then in. Then repeat in 3rd. You should clearly hear a difference.
If not, you probably need to repack the grease in the transmission. The proper grease is called "Darina II". It's expensive ~ $35 per mixer.
Apr 13, 2008 | Hobart N50 Stand Mixer
Hobart N50 Tripped
The reset button is to protect over amping the motor. The N-50 is not a very strong unit, (commercially), but you won't break a gear. If you overload the unit, you'll either trip the overload (reset button), or you will break the taper pin that attaches the planetary to the center shaft.
If you're looking for a small commercial unit, and you're in the US, look into the 10 qt Precision Mixer.
Apr 04, 2008 | Hobart N50 Stand Mixer
Oil leak
hi,its no big deal--the mixer is filled with grease and its coming from the planetary.if it is bothersome remove the drip cup (silver ring) then you will see a roll pin that holds the planetary onto the main shaft.get a small punch and knock out the pin.if the planetary doesnt drop down use 2 flat head scewdrivers and pry it down.clean out the old grease and put in new grease.you can buy it from hobart or get a white lithium grease from an auto parts store.
Oct 23, 2007 | Hobart N50 Stand Mixer
Hobart N50 Stand Mixer Logo
395 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
