Question about Alps MD 5000 Thermal Printer
Incomplete print job
I have an ALPS 5000 printer. Installed on Windows XP and seems to respond ok to the computer. But I can't get a complete print job done. The print outs come out blue. The error that comes out is CARTRIDGE CHANGER ERROR. Is there anything I can do for this? Have tried the turn off computer and pressing power and insert buttons at the same time.
Thank you.
  • GreekLady Oct 10, 2008
    My MD 5000 will begin printing but stops and error light comes on before printing is completed. I have tried the "print on the back side" solution offered but this does not work. I cannot print a test page either from the control panel. The printer error on lower right keeps popping up and reporting a printer error has occured. The other odd thing is that the printer moves the cartridge to a different slot.
  • 83 Answers
Cartridge Changer Errors are series. Did printer work before you installed XP?
Posted on Jul 14, 2010
2 Suggested Answers
  • 83 Answers
Cartridge changer error can be bad. Inspect and clean the changer. Try changing the order of the cartridges in the holder. Any effect? With just the black cartridge installed, try printing an internal self print test. Does that work?
Posted on Jun 04, 2010
Why alps md-1000 printer not responding after driver installed
Can you provide more details about the problem? Will the printer print a self test page? What OS, computer, and cable connection are you using? The ALPS printers were designed to work with Windows 95 using a serial port internal to the motherboard. There is a driver that supports a USB port and Windows XP available. XP will automatically install the MS driver using the plug and play feature. The MS driver is useless and it shouldn't be used, but XP will default to it. Don't delete this driver, but rename. There are no native drivers for Windows 7 or higher.
Jul 15, 2014 | Alps MD 1000 Thermal Printer
I use my MD5000 to print simple logos on decal paper. It prints OK in black or white, but any color printing is incomplete. It's as if the color(s) have ran out, but it prints the same specific incomplete...
Replace the cartridge if it has the printhead attached or if not take a straw and puddle the cap where the printer parks the head and turn it off let it soak 1/2 a day then turn on & off 2 or 3 times
Nov 05, 2013 | Alps MD 5000 Thermal Printer
I have an alps MD400 and am running xp pro with drivers for xp and can't get the thing to print and need a trouble shooter
There are WinXP drivers for the MD-4000. You can find them in the files section in the Yahoo ALPS Group. There are some conflicts with the Windows XP (Service Pack 3) and the ALPS printers. It is best to connect to a computer running SP2 and has a parallel port. The ALPS group also has the Twain for the Scanner. The MD-4000 does require a carrier to scan things.
Dec 17, 2010 | Alps MD 5000 Thermal Printer
White ink printing with alps MD 5000
To print white, you need to use the spot color option in the printer properties. The object to be printed must be all black. It seems counter to what you might think, but the spot color mode will print the solid black areas as the selected spot color.
Mar 09, 2010 | Alps MD 5000 Thermal Printer
How do I print using the foil ribbons? I do not see Gold foil as a color choice.I am interested in any info from a manual on this subject of gold or silver foil ribbon printing.
Your ALPS MD-5000 MUST be set to print in DYE-SUB. mode.... Is there a Memory upgrade plugged into the slot next to the Printer Port? If not, then it's not an option......
Feb 11, 2010 | Alps MD 5000 Thermal Printer
My alps md 5000 doesnt seem to be printing decals as clear as it
these printers are flaky. There is a reason why the mainstream never picked ALPS up. The image quality stinks and the printer break down constantly. Koolaid drinkers in search of the grail love them.
Oct 28, 2009 | Alps MD 5000 Thermal Printer
I am looking for win xp drivers for my alps MD 5000
I found a private indivdual that had an original installation CD with windows xp software  and drivers
Apr 01, 2009 | Alps MD 5000 Thermal Printer
ALPS 5000
Sep 04, 2008 | Alps MD 5000 Thermal Printer
Alps MD 1000 self tests okay, but printing gives "nonvolatile error" (fast blink)
This is a symptom of the following:
You are running XP, and have installed SP3 and, you are using the microsoft driver bundled with XP.
The solution:
The m$ driver will have created a printer with "(MS)" as a suffix. Leave this intact, as it will cause major trouble on every reboot if you delete it.
Download the appropriate driver from the Files section in the Alps YahooGroup found at
With your printer unplugged, install the downloaded driver
Shut down your computer and hook up the printer
XP will detect the printer, and create a new printer in Control Panel without the "(MS)" suffix
Make the new printer your default printer.
The reason why you do not delete the printer with the "(MS)" suffix, is because every time you reboot, XP will ignore the fact that you have the correct Alps driver loaded, and will create a new printer using the m$ drivers, and set it to default. Of course, the m$ Alps driver is fundamentally broken
Nov 08, 2007 | Alps MD 1000 Thermal Printer
Alps md 1300 only prints in black
First of all, Alps MD inks do not "Dry up". They are dry to start with!
It sounds like you may be running XP, with the Microsoft driver for this printer installed. You need to load the Alps driver, which you can get by joining the alps or alpsdecal group at You can find the driver in the files section of one of the groups.
Oct 05, 2007 | Alps MD 1300 Thermal Printer
Alps MD 5000 Thermal Printer Logo
133 people viewed this question
Top Alps Office Equipment & Supplies Experts
Jesse Walters
Jesse Walters
Samuel Konger
Samuel Konger
Are you an Alps Office Equipment and Supply Expert? Answer questions, earn points and help others
