Question about Car Audio & Video
Subwofer question i recently bought two 4ohm rockford forget 10" subs, how do you hook them both up in parrellel so i can make them both 2ohms. . . or is this possible.... my goal is two hook them up to a single channel on an amp if its possible ... or should i just get a multi channel amp so i dont have to worrie...? thanks
    Brigadier General:
  • 6,966 Answers
Hi again,
It would seem that you posted twice on a related concern. Pls see your other post.
As to your question here, to run two (2) 4 ohms speakers in parallel would require connecting both +s and their -s together. A speaker wire to either leading to the amp would suffice. Alternately, both can have their own wires and meet at the amp's speaker terminals. However, with reference to your other post, if the amp is not rated at 2 ohms, then the possibility of early clipping or the amp being overloaded is there.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 10, 2008
How to wire a 12inch 4ohm dvc sub to 2ohm
Take two wires, equal length. Reach from positive of 1 coil and hook too positive of 2nd coil, now do the same with negative, neg to neg.. Then pos of sub to amp. And neg of sub too amp.
Jan 03, 2013 | Rockford Fosgate T1d212 12" Power T1 2-ohm...
I just needed some help with wiring my p8002 rockford amp to 2 fosgate 10 inch subs i just bought. there 4 ohms a piece and dual voice coil. i dont know much about car stereos but people keep telling me...
Well i tried looking up that amp, but Fosgate sight is down. So assuming that the best power out of your amp is 2ohms off the bridged hookup, and the subs are 4 ohms per coil, the best way is to only use one side of each speaker and hook it straight the the bridge. Only using one hook up wont hurt anything, its just for giving you wiring options. And when adding up ohms of speakers, it goes like this. If you had two 4 ohm subs, that'll give you a 2 ohm load. If you hooked up all your hookups, it would be like having four 4 ohm subs, and would give you a 1 ohm load.
Jan 19, 2011 | Car Audio & Video
Alpine x is not reading proper ohm resistance amps blew
the gmax amps are only 2ohm stable. it is odd that they both blew at the same time but if the impedence is too low to amps will fail.dual 4ohm dvc subs wired in parallel should read around 2ohms. allthought impedence varies with frequency and isnt truly stable.
Feb 12, 2010 | Alpine SWX-1042D Car Subwoofer
How do I hook up one sub to my rockford fosgate p3001 amp
Hey i have looked over many rockford manuals,(i own a 300.1 my buddy owns a 325.1) and for there mono(.1) amps there hooked together on the inside so channel A+ and B + are cencted on the inside the amp. So you ither hook one 2ohm sub to channel A or you can hook 1 4ohm subs to channel A and 1 4ohm sub to channel B. There 2ohm stable so any lower will eventualy burn the amp out.
Jan 08, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
Problems with car system help! I have a little older model rockford bd1000 and 2 TXXAPX12RD audiopipe subs hooked up in parallel/parallel to give it 1 ohm, had it hooked up this way for a good solid 3...
Hello srolson,
When electronic components are brand new their tolerances will allow more variation. Once you get down to a 1 ohm load, the actual impedance may vary somewhat below what the amp is capable of handling. Maxxing anything out accelerates how quickly it degrades. When new the amp can deal with putting maximum power into a minimum load, but as the components heat up and wear with age, the tolerances change.
Hope this helps.
Sep 15, 2009 | Rockford Fosgate bd1000.1 Car Audio...
How do i bridge 2-4ohm dvc's to a mono block
If you have a DVC 4ohm speaker, and you are using both voice coils, the amp is seeing a 2ohm load.
If you bridge the amp, you CAN run both subs as long as the amp is Two Ohms Stable.
Wire each subs voice coils in parallel.(Positive to positve, neg to neg.) (2ohms) each.
Then wire the two subs in series.(Neg from amp to neg of sub one, pos of sub one to neg of sub two. then pos of sub two to pos of amp.
If it sounds too hard, leave it as you are already running the amp at two ohms.
Sep 13, 2009 | Car Audio & Video
Overheating amp problem...easially fixed, i think....
depends on the sub rating.
if subs are 2 ohm rated you can ONLY get 1 or 4 ohms..
2x2=4ohm series
2/2=1ohm parallel
if subs are 4 ohm rated wire in parallel
4/2=2ohm
look it up google for diagram if you need one.
Aug 06, 2009 | Car Audio & Video
Protection light comes on
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Dou .A thumbs up would be greatly appreciated if this answer is helpful to you. protection-light-comes-lv2kkrmxrai4iihdvw4m3np2-2-0.jpg http://www.nitrobmw.com/
Jun 14, 2009 | Nitro BMW-482 Car Audio Amplifier
How do i hook them up to work for 2ohm's
Hello rcantu76,
If your CVR's are 2ohm (model Nr. 07CVR122), you connect the voice coils in series and then parallel both subs to the amp. If the subs are 4ohm (model Nr. 07CVR122), they cannot be wired to 2ohms. Your choices are 1ohm or 4ohms. According to Rockford-Fosgate's data on the P1000-1bd, it is stable at 1ohm.
To wire the 122's at 2ohms, you would connect the sub voice coils in series (jumper one positive to the other negative on each sub), and then connect the remaining positives and negatives to the amp.
To wire the 124's at 1ohm, you would connect all of the positives and all of the negatives together to the amp.
Hope this helps.
May 11, 2009 | Jl Audio 500/1 Car Audio Amplifier
Need help with the wiring on amp to subs
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=3&woofer_imp=4 DON'T FORGET MY FIXYA RATING!
Mar 09, 2008 | Phoenix Gold R15.0:1 1500W Octane-R Mono...
Car Audio & Video Logo
74 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
