Question about Vizio L30WGU 30 in. HD-Ready LCD Television
Smoking tv When I turned on the tv set, it made a strange noice, then came out smoke from the rear left side of the tv.
  • 4,234 Answers
Smoke is never a good thing. Is the set still under warranty? If so, request warranty service. If not, can you carefully open up the back and either post a photo here or post what you see? Look for burned resistors or capacitors that have bulging tops. Let us know what you find.
Thanks,
Dan
Posted on Oct 10, 2008
The TV started smoking. Thought it might be dust. doesn't appear to be.
Your tv is burning part of it's electronics. Turn it off and unplug it. Either take it to a repair ship or replace it.
Mar 27, 2015 | Philips 47PFL3603D/F7 LCD HDTV, 47...
Tv smoking
Hi, Sounds like power board issue. Take to repair man.
Good luck.
Feb 11, 2014 | Dynex "- 42"" Class - LED - 1080p - 60Hz -...
CAR IS F**KED !
What do you mean by "smoking up and everything."? Was the engine still running at the time? If so, the engine has not seized. Is it making any strange noises? If it's just smoking a lot, but still running and not making any strange noises, you probably just have a leak and and alarmist friend.
Jul 14, 2013 | 1995 Nissan Cefiro
Overheating brakes
Possibly fitted wrong,,,,possibly calliper or slides seized,,,sticking badly
May 25, 2013 | Ford Expedition Cars & Trucks
Ram 1500 left rear brake smoking
Take it back to dealer they probally over adjusted it
Jul 23, 2012 | 2004 Dodge Ram 1500
Scraping noise while turning left
Could be your wheel bearing or your axle.Well jack the left side of the car and shake the wheel little bit and see if there is any play on the wheel and also turn the wheel with your hands and hear if there is any strange scrapping.
Dec 10, 2010 | 2006 Kia Optima
Smoke from rear of tv
I wouldn't turn it on either. Not needed, it won't work anyways, just cause more problems. You will need to have the rear panel removed and observe for shorted wires, burnt or swelled capacitors and likely a faulty power supply aka high voltage transformer
Apr 13, 2010 | Polaroid TLA-04011C 40 in. LCD TV
When i make a left turn or right turn i get a moaning noice from the rear but strighten the vehicle noice go away ( speed is about 10 miles per hour) and this only occurs when the jeep is warmed up when...
This may sound strange to you,but I think the wrong oil,or no additive has been added to the rear diff when you had it serviced.Did you recently have it serviced?What it is ,is the limited slip diff clutch plates,shuddering as the car is turning.The remedy is to change the oil that is in there ,if it's wrong oil, or put additive into the diff.Its called 'FRICTION MODIFIER'.Check the rear diff also.Hope this helps
Jan 12, 2010 | 1993 Jeep Grand Cherokee
50P8342 tv TURNS ON BUT THEN TURNS OFF AFTER A FEW MINUTES, ALSO AT TIMES IT FREEZES... WHAT COULD IT BE?
This set has an SSB module, they are notorious for causing the set to fail with strange symptoms like the freezing up you are experiencing. This board needs replaced it is a very small board about the size of a deck of cards, mounted vertically on the left hand side. The cost of this board is usually over $200.00. I have worked on many of these, and one thing you need to be aware of is that i have received new board in that were defective, this was a chronic issue, and if you buy a board make sure you can return it, if the tv begins to have other strange problems most likely that board you purchased is defective as well. This is a big issue with this set including the repeat failures of this board
Nov 20, 2009 | Philips 60P8341 60" Rear Projection...
Vizio L30WGU 30 in. HD-Ready LCD Television Logo
488 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
