Question about Whirlpool Duet GHW9150P Front Load Washer
Stopping mid cycle and won't spin
My washer no longer will spin with a large load. It beeps and leaves an error message that I need to check better. I was thinking it was F 2. I have to cancel, take out some laundry that is soaked, then start again. These aren't huge loads but wet clothes are heavy. My laundry is piling up with these tiny loads that I can do now. Any suggestions?
  • boyzmom3 Oct 11, 2008
    That was exactly my problem. We saved over $100, our washer is really spinning and our clothes are almost dry not coming out, saving us energy in the dryer and we found about 6.00 in change,
    Thanks for taking the time to help us here. We really appreciate it and my husband is amazed at how easy it was.
    MR
  • 5,911 Answers
"F02" is a Long Drain error. This is usually caused by debris build up in the drain pump. The following link explains the error and what to do:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
The washer will not complete a cycle if it senses a condition that generates an error code. Follow the advice in the link provided and you should be okay. Now...it doesn't take much to cause irrepairable damage to the drain pumps in these washers. If you do everything I suggest and the error code returns, it is recommended that you replace the drain pump. I hope this helps you. Let me know if you require additional assistance.
Posted on Oct 10, 2008
AEG Lavamat W1450 Electronic - after about 10 mins of programme machine is making beeping sound and stopping
this is an errorcode !
try to download a servicemanual,
then you can figure out the exact failure -
like : does not heat up etc. ....
May 05, 2012 | AEG Lavamat W1450 Front Load Washer
My Kenmore HE 3 washer keeps stopping mid cycle and beeping showing an F 02 message. We cleaned out the hose but it is still doing it. If I unplug it and do the spin/drain cycle again it will work...
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Aug 01, 2011 | Kenmore HE3T Washer
Washing machine shakes excessivley and the washing cycles are stopping mid use.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Jan 06, 2011 | Kenmore Elite 45986 Front Load Washer
Error Message and Tub not spinning
UE is likely an unbalanced load or load is too large. Reduce the size of the load and your issue should be resolved.
Jul 21, 2009 | LG WM-2277HW Front Load Washer
Stops mid-cycle, does not drain, displays nd error code?
Hello.
That code is telling you that the unit is draining to slow. After 15 minutes it is not below the low water level and will not spin out. The best repair for this is to replaced the pump on your unit.
Jul 15, 2009 | Maytag Neptune MAH9700 Front Load Washer
Our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Jan 21, 2009 | Hoover UltraCare HC6 130M Front Load...
Washer stopping mid-cycle with no error
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you have drained, unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out. F-21 filter blocked.
How abt a nice rating for the free help?
Jan 04, 2009 | Whirlpool GHW9300 Duet Washer
E20 code on washer : will not empty water on spin cycle?
something is stopping the water from drainning...check for kinked hose,,,check waste pipe,,,check units sump...onthejob
Dec 18, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidare front loader washer error message 20
If you open the top of the washer , there is a "tech" sheet in there to tell you how to reset the error codes.
My washer started this. Then stopped spinning. Now it will not even wash a load. It stops mid-cycle. The ER 20 means that something is not draining right. We checked all of the tubes leading to the pump. Nothing was clogged. The technition seems to think it is a motor controller error.
Oct 27, 2008 | Frigidaire Affinity ATF7000E Front Load...
Maytag Front Load Washer - SD error
hi there,
it appears that you have a door switch problem. the door latches on these machines are equiped with a mechanical switch and if this switch disengages in any way, the machine thinks that the door is open, even if it's not.
the code that you see is actually a "dS", which stands for door switch.
check the door latch, which is where the door switch is located.
thanks.
Sep 26, 2008 | Maytag Neptune MAH6700A Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
108 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
