Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirlpool gold side by side freezer not freezing but fridge is running
Whirl pool gold side by side seems fridge part ok but not freezer
  • Anonymous Mar 31, 2014
    fridge and freezer not cooling/ freezing
    Problem Solver:
  • 5 Answers
Your fan in the freezer is wearing out. When your food in the freezer is blocking the air, the motor is working too hard. After years of using, it needs to be replaced. Get a repair man in to replace with a new parts. My Fridge/Freezer was totally broken and I found this out because the ice was melting. It got fixed and now no problem.
Posted on Oct 16, 2008
Have a Whirlpool Gold fridge manufactured in 2000 according to the sticker inside fridge. Same sticker says model# is GT22DA or GT22DC. Freezer is working fine. Fridge part is not keeping food cold and in...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Dec 15, 2009 | Refrigerators
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Whirlpool gold:upper half of refridgerator side not cold
Either the evap fan has a problem, or the defrost system has failed. You should never see frost in the freezer section as the defrost sensor should sense that the coils need to be defrosted before that much frost accumulates.
Unplugging to clean out helped because the frost got a chance to melt away.
If you find the evap motor is running, then the things to check are the defrost sensor, the defrost timer, and the defrost heater.
Reply back if you would like more info.
Jan 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirpool gold
I did some research online, and read that the Start Relay is most commonly the problem. My husband bought the part, (about $50) and reattached it to the side of the compressor....and was cold immediately! apparently a very common problem on these fridges.
Jan 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
MY FREEZER FREEZING AND FRIDGE IS NOT COLD ON MY BLACK SIDE BY SIDE WHIRLPOOL
hi thanks for the question i would check to see if the fan in your freezer is working that could be the problem make sure the back of the fridge is clean where the compressor is located also make sure no frost has built up in freezer thanks the appliance doc
Sep 22, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold Conquest side by side (stainless steel front)bought in 2004. Freezer stopped freezing, fridge cooling fine, freezer is running. Thank You!
sounds as if you have an ice buildup restricting the fan from moving airflow to the freezer. Inside the freezer take apart the lower shelf and see if this area is full of ice, if so clean it and defrost it.
Jun 12, 2008 | Whirlpool Refrigerators
Whirlpool et8mtkx gets too cold, freezing
ok renato i believe in teaching so here is refrigeration 101 first the freezer does all the colling for the whole unit there is nothing in the refrigerator that cools its control runs a damper door like on a wood stove or fireplace at what we call the mid point setting the middle point the fridge should be about 35to40 degrees food starts spoiling at 42 the freezer should be about -8 to 2degrees the freezer has the only true thermostat that controls the compressor it has a cut in cut out temp and they are filled with freon like the unit and are subject to leaks at which time they malfunction now you can check the freezer for temp at mid point setting if its way below 8 degrees replace the freezer side thermostat which im betting is bad any way and not cutting out now blambnm email me at b4829@yahoo.com and we will talk ive never seen a whirl pool unit with out a freezer so you must be in another country im in the usa but we can fix yours too ill just need more info ok
Jun 05, 2008 | Whirlpool ET8MTKX Top Freezer Refrigerator
Whirl pool gold GD5RHA side by side.
We had the same problem and I AM NOT a repairman. I found that with a lot of freezer door opening, the rubber fill tube, which fills the ice maker tray, had frozen up inside the tube. I had already replaced the ice maker, and still no ice. I am sure a repair person will shudder, but I simple put a Phillips screwdriver up the tube and found the ice was not allowing the tube to refill the tray. CAREFULLY, use the tip of the screwdriver to dislodge the ice and clear the tube. These units do not cool or freeze quickly, therefore keep the doors closed as much as possible and don't let kids stand with the door open while they gaze into the depths while making their decision.
Dec 24, 2007 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
447 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
