2012 audi a6 is supposed to have a fuse box in the trunk but i cannot find it. The manual only shows a close up and says it:s behind the trim
I have the same problem. Dealer was no help, they said that I should bring the car in and have them replace the fuse.
The manual must be for another Audi.
I found the fuse box in the trunk! It is on the right side behind the inset storage area. You have to carefully remove the storage area.
But how do you open it?
thanks
SOURCE: a6 Battery removal
You should check either - www.audiforums.com www.audiworld.com or www.audizine.com, register and search the forums, should be good info. also check under the battery, man audi cars have secondary brackets underneath to hold the battey in place.
SOURCE: thermostat audi a6
look under car on water pump housing, the thermostat is on a metal housing that looks like an igloo and has to bolts perhaps 10mm or 13mm, and an "O" ring in between
SOURCE: fuse box in a audi a6 1995
Fuses are located by the side of the dash board when you open the driver's door. The fuel pump fuse is situated in there.
SOURCE: HI , Where is the fuse box on a 2006 Audi A6 ?
hi there are 3 places it could be 1 under dash 2 on drivers side stand outside car looking to the left of stearing wheel 3 under hood in a blackbox
SOURCE: Locate oil and air filter on Audi A6 2.5 tdi M reg
IF YOU DON,T KNOW WHERE THE OIL&AIR FILTER ARE.IT WOULD BE BETTER FOR YOU TO TAKE THE CAR TO A LOCAL GARAGE AND GET THE WORK DONE THERE PLUS REPLACE THE OIL.WILL NOT COST MUCH.(GET A PRICE FIRST)..JUST KEEP BACK FROM AUDI DEALERSHIP GARAGES COST TO MUCH MONEY..
