Question about Vacuums
TSC 441 JUKI NEED BOBBIN WINDER TIRE OR ORING DONT KNOW THE PART NUMBER SEWING MACHINE
  • 5 Answers
SOURCE: I need to know how
This is a job for a professional sewing machine repairman. Any retiming must be caliberated accurately in order to sew properly.
Unless you have the proper timing figures and calibrating tools and know how, I would take it to a professional.
Posted on Oct 13, 2010
SOURCE: i have the brother Ls-2000
adjust your tension.You probably did not wind your bobbin properly as well.Make sure you oil your machine every month or so and make sure your bobbin is seated properly before you sew.
Go slower with the pressure foot speed and use the right needle.ALWAYS test on scrap of your sewing material first!!!
I have this machine for like 2 years and can do 2-5oz cowhide and buffalo leather on it (no joke, and it works FLAWLESSLY) inside it has full steel construction,just needs regular oiling compared to pro machines and easily made a few grand $$$ with it while my pro machine is getting repaired (I don't even bother with my pro machine anymore) But you MUST oil it every month and use the RIGHT needle and adjust your tension properly
Also pull out the thread a good 6 inches from the needle and bobbin before dropping the pressure foot and sewing.
Best $70 bucks (WITH TAX) I spent hell,the leather I use costs more than the machine!
Posted on Feb 07, 2011
HansPP
  • 2510 Answers
SOURCE: Thread and bobbin both threaded
Check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out.
Posted on Mar 16, 2011
  • 1739 Answers
SOURCE: where can I get a
Not sure if this is the complete manual but only site where I could find it available for free:
http://www.free-service-manuals.com/Sewing_Machines/Juki_DDL_227_Basic_Repairs_&_Adjustments_L98742/
Click on Download/Visit to receive the manual in zip format.
Posted on Mar 27, 2011
SOURCE: I need a user guide
i went on line on how to thread an industrial machine and the the bobbin is the opposite of a regular machine. when handleing the bobbin have it so the thread is going down the right side so it looks like a number nine.hope this helps
Posted on Jun 11, 2011
Need a manual for my singer sewing machine it is a singer genie 353 or 354
HI......................
Singer 353 and 354 sewing machine service manual.
Note* This is a service manual. If you need the instruction manual or the great little trouble shooting and adjusters manual, we also carry both in our store.
Service manual includes:
* Bobbin winder
* Rotating hook
* Motor and electrics
* Needle bar
* Presser bar
* Much more
THE MANUAL LINK IS GIVEN BELOW.............
http://sewingmanuals.blogspot.com/2011/04/singer-genie-353-354-sewing-machine.html
GOOD LUCK..................
Sep 22, 2011 | Vacuums
I need a user guide for a Commercial Brother sewing machine model DB2-B716-403AB, I need to see how to thread it, and I need to see how the bobbin works(bobbin thread is not picked up by the neddle. And I...
Jun 02, 2011 | Vacuums
I am trying to tread the bobbin of the sewing maching (Singer Merritt 4530) but the bobbin is not turing. The plate under the bobbin is turning but the bobbin its self is not
Look up a singer sewing machine store in your area and you can phone them and they will tell you what to do, or you may get them to fix it quite reasonably, or post your ad for free on www.kijiji.ca and someone can help fix it for you that knows how to fix sewing machines.
Apr 25, 2011 | Vacuums
I just got a new machine (new to me anyway) new home hf106 model. i need to thread the bobbin on the new thead i am using and am not sure where to put the empty bobbin and how to thread it. help!
Janome New Home?
Unfortunately, Janome doesn't put the manuals for older machines on their website. Your best bet is to contact your local Janome sewing machine dealer and ask for a "copy" of the manual from them. A photo copy should be sufficient for your purposes. Otherwise I understand you'll have to buy a manual and wait to have it shipped.
But carefully look at your New Home. On the top toward the right there should be a fitting that looks like the bottom half of a spool. and next to it is a thing that almost looks like a mushroom.
Put the spool of thread on the spool holder, run the tread to and around the tension discs on top then thread the end through the hole in your empty bobbin. Place the bobbin on the thing that looks like a half a spool and push the whole thing to the right toward the "mushroom."
Press start, or hit the foot feed. Wind slowly for best results.
When full, stop and move the bobbin winder back to the Left (sewing mode)
Now... hold your bobbin between your right thumb and fore finger... pull the thread a few inches... your thread should be coming off the LEFT side of the spool, if not flip it over and try again. Open the bobbin area, drop it in with the thread coming off the left to the bobbin.
hold bobbin still with right index finger and with left hand slip the tread between the bobbin race's tension spring then if your model has a channel for the tread... follow it... otherwise pull straight back, replace the bobbin cover on the machine.....
Thread top thread then use the hand wheel to take up the bobbin thread.
(Of course this all assumes your New Home is similar to my janome or brother.) Have fun!
Be sure to get some good needles.... ;)
S
Mar 12, 2011 | Vacuums
What bobbin do I use in a Juki DDL 8300
Hi there.
Nice machine... Here is a link to all the parts for your Juki DDL 8300
http://www.juki.co.jp/industrial_e/webparts_e/partslist2.html
Your bobbin's Juki part number is B9117-051-000
Mar 11, 2011 | Vacuums
I have the brother Ls-2000 sewing machine i threaded the top as well as the bobbin but when i try to sew the thread gets stuck and it bunches up and tangles in the bobbin. also the little bit that did sew...
Jan 12, 2011 | Vacuums
Sewing machine needle not moving up and down
Well there are many things to check (causes) -
Upper thread has run out. Presser foot is up.
Bobbin winder shaft was left in winding position.
Buttonhole lever was not lowered when machine was placed in buttonhole mode.
Anyway you may try the steps below to correct this (Solution) -
Replace empty spool and thread machine.
Lower presser foot.
Move bobbin winder shaft back fully to left.
Lower buttonhole lever.
Good Luck!!
Thanks for using FixYa!!
Aug 28, 2010 | Vacuums
Kenmore YM-40-35 R Sewing Machine Manual (or copy) wanted. If a manual is not available, I'd be OK with instructions for threading the needle and bobbin and any additional details that an expert may...
Please go through the below document which will give you the help you wanted:
http://www.ehow.com/how_4798790_thread-bobbin-kenmore-sewing-machine.html
http://www.ehow.com/how_5839_thread-sewing-machine.html
http://www.youtube.com/watch?v=1j8e8FvwUlQ
You will also find additional information on every page at the left hand side (Ehow.com) and on the right hand side(Youtube).
Please let me know if you need any additional information or have any information that you would like to share with me.
Jun 10, 2010 | Vacuums
Vacuums Logo
151 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
