Question about Gateway FPD1975W 19" LCD Monitor
DELL LCD monitor E151FPb turn white
Dears, My DELL LCD monitor E151FPb screen turns white when power on, no other display at all. Can someone help to provide solution. Next, after taken out all screws from the back panel, I have difficulty to open the monitor casing. Does anyone know how to open the back panel ? Where are the plastic catches at the back casing? I am afraid to break the casing and the LCD panel. thanks ! screen turn white when turn on
  • Anonymous Jan 05, 2009
    Screen goes white and when you tap it couple of times, may be it will comes back up, but after a while it will go white again...
  • jqueen568 Apr 23, 2009
    how do you replace a fuse on the lcd 15" dell E151FPb
    Novelist:
  • 159 Answers
If the screen is all white light then you can have a number of problems.
One could be a bad video board, the next could be a simple loose wire from the video board to the back of the lcd screen OR a simple blown fuse on the back of the actual lcd screen can cause the same thing.
Snaps are all sround these things and can be really stubborn at times. Best to start the bottom first then work up each side to the top.
Something flat, thin and with a decent sharp edge on it will help. A pocket knife held parallel to the joint between the front and rear plastic works, you can also sharpen the edge of an old credit card with a file (nail file works) This isn't as strong as a blade , but safer if you slip !!
Fran
Posted on Oct 11, 2008
Resolder L781 on the powerboard from the backside. Typically L781 is glued to board with white adhesive. Remove the old solder and scrape off some of the wire's lacquer finish for good contact.
This is a known issue.
Posted on Apr 07, 2009
White screen
The white screen you are getting is it just right after turning on the computer? If yes it means that you were not able to see the Dell logo correct?
Try connecting an external monitor thru VGA. While monitor and laptop is on with white screen please do this. Hold down Fn key then press F8 at the same time. This will toggle the display from the laptop to external monitor. If laptop displays to external monitor means that laptop LCD needs to be replaced.
If you do not have an external monitor try this.
While laptop is OFF. Do this. Hold down the D key then press power button at the same time.
Check if the laptop will display colors the whole screen. If you still see white screen then LCD needs replacement.
LCD mean LCD panel or the whole screen together with LCD cable and Inverter.
Hope this helps.
Mar 25, 2011 | Dell Inspiron 1525 Notebook
Dell Monitor Failing
its the problem in the EST of the monitor.just get it replced to solve the problem.
pls do rate the solution
thanks.
regards.
fixya expert team
Sep 02, 2008 | Dell E152FP 15" Flat Panel LCD Monitor
My dell E151fpb 15' monitor screen turns white
Look for loose connection between the LCD panel T-CON board and the logic board first, it may also have lost the 5vdc for the T-CON board.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Aug 05, 2010 | Dell E151FP 15" Flat Panel LCD Monitor
My DELL E151FPb LCD Monitor turns to white screen.
unplug the monitor on at the back fo the computer but leave the power plugged in and if you can see red,green ,blue bars jumpign around the screen it means that the monitor is good check the video card, but if you cant see the colored bars you need to get it repalce.this is monitor selft test process
Apr 15, 2010 | Dell Computers & Internet
My computer monitor will not stay on.
The problem may with the Ram inside your computer
Jul 07, 2009 | Dell E153FP 15" LCD Monitor
Monitor Blackout
Here is a website that provides instructions to repair the inverter on a similar model:
http://josepino.com/?howto-repair-dell
Feb 23, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
Dell E151FPb 15" LCD with power LED blinking.
The problem may be a loose connection. When I turn on my monitor, the green light blinks and a flickering white screen appears for a brief second every time. There must be a loose connection on the power board which may be causing this. The easiest solution is to tap at the back of the monitor. This will reconnect the loose end and the monitor will work fine until it gets disconnected again. I will open my monitor soon to find the real problem. But it will take some time to find it.
Aug 17, 2008 | Dell E151FPp 15" Flat Panel LCD Monitor
Wacko Dell E151FPB
that sounds like a computer problem, not a monitor problem.  Plug the 'old' monitor in and see if your computer will boot with it.
Oct 14, 2007 | Dell E173FP 17" LCD Monitor
Lcd monitor goes white
The E151FPb's seem to have a problem of this sort. After doing some research online I've found that the most common problem is a few dry solder joints on the large circuit board inside the monitor. There was also some talk of a connector suffering from heat creep that sound be connected better on the inside, but usually that would make the screen turn black if it were to become disconnected. The monitor can be opened by unscrewing all the screws on the back, there should be 6 screws you need to pull out before being able to open the case. After those, insert a thin, but strong piece of metal into the side and sort of twist/slide it along the side and it should pop open some clips and just work your way around the perimeter. After that it's just some simple and obvious screws to get to the circuit boards.
Apr 11, 2007 | Dell E153FP 15" LCD Monitor
Gateway FPD1975W 19" LCD Monitor Logo
440 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
