Question about Epson Stylus C66 Photo InkJet Printer
Change printer ink
Hi. What do i press to get the ink cartridge thing to stop in the space where i can change the ink cartridge over? Help
    Genius:
  • 1,605 Answers
Turn on the printer.
lower th epirnter's output tray, pull out the extension, and open the cover.
press and release the ink button.
if your ink lights is on or flashing, the printer head moves to the left, and the cartridge that need to be replaced stops under the ink out mark.
open the cartridge cover
Pinch the back tab of the empty cartridge as your left it out of the printer.
shake the ink cartridge 4 to 5 times while it is still in the package.
unwarp the new ink cartridge and lower it into the holder. Push down gently until the cartridge is firmly seated.
repeal the procedure if more than one ink cartridge is out.
close the cartridge cover.
close the printer cover and press the ink button.
The green power light flashes and the printer makes noise. charge takes about a minutes. When it's finished, the green power light stops flashing and stay on, and the red ink light should go out.
Posted on Nov 13, 2008
How to replace catridges for Epson Stylus Office T40W??
Good day. I hope this steps can help you in replacing your cartridges. This how i remember doing it. Just follow these steps.
>Make sure the power light is on, but not flashing.
>Open the printer cover and the output tray.
>Press the ink button. The ink cartridge holder moves to the ink cartridge check position and the
power light begins to flash.
>Press the ink button again. If more than one ink cartridge is expended or low, the ink cartridge holder moves to the mark.This
occurs each time you press the ink button until all expended or low ink cartridges have been
indicated. Once all of the expended or low ink cartridges have been indicated, the ink cartridge
holder
moves to the ink cartridge replacement position when you press the ink button. >Open the cartridge cover and place the ink cartridge into the cartridge holder with the bottom down.
Then push down the ink cartridge until it clicks into place. Then close the cartridge cover
>Press the ink button and then the printer moves the ink cartridge holder and begins charging the
ink delivery system
Hope this will help you a bit with your ink cartridge replacement problem. Have a great day.
May 22, 2011 | Epson Computers & Internet
After replacing the ink cartridge printer still shows cartridge levels at 0%
Hi
You have to reset the cartridge
To Reset the HP Cartridges Works 100%
Power off the printer
Hold the stop/reset button then press and hold power (for 5 secs)
Hold Power and release the stop/reset button
Press the stop/reset button twice
Release power button
Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press.
On the 3rd press the indicator should be orange.
Press the power button to set data
To set data remove cartridges then replace.
leave for 20 or 30 secs
Press the power button again to shut down
Then press power button to power up.
The printer will feed one piece of paper through
then set language and counrty.
Then ink should be reset
Thanks
Aug 15, 2010 | HP Office Equipment & Supplies
Replaced ink cartridges but monitor still displays "ink low".
Hi, this fix worked for me (i've been wasting few hours on mp150 the first time, so if it soesn't work at the first attempt, don't give up and try at least few more times)
  1. Power off the printer
  2. Hold the stop/reset button then press and hold power (for 5 secs)
  3. Hold Power and release the stop/reset button
  4. Press the stop/reset button twice
  5. Relase power button
  6. Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press.
  7. On the 3rd press the inicator should be orange.
  8. Press the power button to set data
  9. To set data remove cartridges then replace
  10. leave for 20 or 30 secs
  11. Press the power button again to shut down
  12. Then press power button to power up.
  13. The printer will feed one piece of paper through then set language and counrty.
Then ink should be reset.
Good luck, Peter
Aug 08, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Reset To551 ink cartridges
  • Power off the printer
  • Hold the stop/reset button then press and hold power (for 5 secs)
  • Hold Power and release the stop/reset button
  • Press the stop/reset button twice
  • Relase power button
  • Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press.
  • On the 3rd press the inicator should be orange.
  • Press the power button to set data
  • To set data remove cartridges then replace.
  • leave for 20 or 30 secs
  • Press the power button again to shut down
  • Then press power button to power up.
  • The printer will feed one piece of paper through
  • then set language and counrty.
  • Then ink should be reset
Please rate my sesponse!!
Thanks, SF
Jan 28, 2010 | Office Equipment & Supplies
Changing Ink Cartridge
Easy solution:
Press The index sheet button and the scan button at the same time.
In the printers window 'set up' will appear. using the left right arrows proceed to 'Ink cartridge replacement'.
Press 'start'. The ink cartridge holder will align itself in the middle of the space where it is easy to remove the cartridges.
I am disgusted with Epson making this so diificult to figure out. Once you know..then you know. but no amount of guesswork would have come up with the solution
Please rate!! Thanks, Prem
Jan 28, 2010 | Epson Stylus Multifunction Inkjet Printer/...
On my Epson Stylus DX7450 printer ,underneath the stop button is 2 wee lights 1 with a page beside it and the other with a drop(like an ink drop) beside it.Its an orange light that its on on the 2nd...
Hi, one of your ink cartridges are empty, to check which cartridge needs replacing press the stop button, the carriage will move across to the left and sit below a pointer. This will point to the empty cartridge.
Press the stop button again, the carriage will move across either to display another empty cartridge or to the position to allow you to change the cartridge.
This can also be checked using the Status monitor software on the PC.
Nov 24, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Epson sx 200 printer cannot change ink cartridge
Ive just pressed the 'stop' button on mine and it moved the cartridge to show which ink needed replacing and then when pressed again it moved to the replacement gap
Mar 24, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Override alarm for color ink cartridge
Hi Redtail,
Try the following. It will not disable the alarm but will reset the in counter.
  5. Release power button
  9. To set data remove cartridges then replace.
  14. then set language and counrty.
  15. Then ink should be reset
Dec 04, 2008 | Canon MX300 Office All-In-One Printer
Help with Epson Stylus CX 6000
Hi Open the cover then switch on the printer and then off from the mains when the cartridges are in the middle. Hope this helps!
May 23, 2008 | Epson Stylus CX6000 All-In-One InkJet...
I NEEED DRIVER OF INSTALATION OF IMPRESORA STYLUS CX 6000 PLIS MI MAIL IS marsa78_eva@yahoo.com.mx
Jan 14, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus C66 Photo InkJet Printer Logo
225 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
