My Olympus Digital Voice Recorder (WS-311 M) keeps saying "memory full" when I try to record, but I have erased all the files from its memory. Is there some way I can wipe all of the memory on this wonderful little machine clean and start over?
  • 6,487 Answers
Try checking this user manual this my be handy for this concern , in removing all the content of this device and clearing the memory http://www.olympusamerica.com/files/WS-311M%20WS-321M%20Manual_English.pdf
Hope that helps..............
Posted on Oct 10, 2008
  • 1,800 Answers
Try to format it and reset it
and try again
plz do aret this post
    Genius:
  • 1,913 Answers
Connect this divece to your computer.
]then detect memeory .
u see removabledisk in my computer then right clik it foramt it.
thqts all.
also try to reset .
remove battery and also change battery or cell.
best of luck.
Can't erase on my olympus WS-100
Do you plug into your computer? If so, you can erase from there.
Does your recorder have a "format" setting? That will erase entire contents.
May 26, 2015 | Olympus WS-100 Digital Voice Recorder
Olympus WS-802 will not allow me to record, gives "memory full" message
try scanning it for viruses and errors. you can also try to format the device
May 26, 2014 | Olympus WS-802 Digital Voice Recorder
OLYMPUS Digital voice recorder ws-311m memory is full despite all folders being deleted
I had the same problem on a WS 311 and this worked for me as well, thanks so much!
Sep 19, 2012 | Olympus WS-311M Digital Voice Recorder
It says "Memory Full" but
If you are sure you have erased all files in all folders then it would not do any harm to run FORMAT from the menu.
This may well clear your "Memory Full" message and get your device working again.
Hope this helps.
Sep 10, 2011 | Olympus WS-110 Digital Voice Recorder
I deleted my audio files directly from the computer. Now that I try to record again, the device says that memory is full, even though I have no files on it. How do I reset it to record again?
To erase a selected file, first press the [ERASE] button. Next, press the [+] (plus) or [-] (minus) button to select "ERASE," and then press the [ERASE] or [OK] button.
To erase all files in a folder, first select the folder and press the [ERASE] button for three seconds or longer. Next, press the [+] (plus) or [-] (minus) button to select "ALL ERASE." Finally, press the [ERASE] or [OK] button.
NOTE:
The recorder should be formatted using only by using the internal FORMAT function found in the recorder's Menu. Formatting using the computer may corrupt system files needed to run the recorder, so computer formatting is not recommended. Individual files can be deleted using the computer with no negative effects.
Feb 05, 2010 | Olympus WS-321M Digital Voice Recorder
My WS 100 says FULL and won't either let me put it
The recorder should be formatted only by using the internal FORMAT function found in the recorder's Menu. Using a computer to format the recorder may corrupt or delete system files needed to run the recorder, so formatting via the computer is not recommended.
Individual files can be deleted from the recorder while it is connected to a computer without negative effects.
Feb 04, 2010 | Olympus WS-100 Digital Voice Recorder
Olympus digital recorder WS 110, keeps saying connect to pc
the only thing left to try is to try and format the device and see if you can restore it back to factory default settings. You go to the menu and to the format option. This will permanently remove any recordings you have done and as I said restore the device back to factory settings. If that doesn't work then you will probably need to send it to Olympus for repair service.
Dec 04, 2008 | Olympus VN-3100PC Digital Voice Recorder
WS-110 memory full but no files
well, i resolved this myself by going to the sub-menu, and formatting the recorder to its original state. thankfully, i backed up the files on my computer first, so i didn't lose any data, although i did have to go in and re-set all my preferences on the recorder.
lesson: don't MOVE files from recorder to computer. copy them instead, and do the actual erasing from the physical recorder itself.
i don't know if this was the most elegant solution, but at least it did get my recorder up and running again. i'd love to hear if there is a better resolution out there.
Nov 28, 2008 | Olympus WS-110 Digital Voice Recorder
Olympus W_S 100 can't record/erase
the dat files were removed off the recorder. put them back on and it should work fine. also try to format the recorder through the menu and not the computer
Oct 12, 2008 | Olympus WS-100 Digital Voice Recorder
 Grubhead
Grubhead
