Question about Arrow 8000 Power Shot Pro Staple & Nail Gun
Refilling the staple gun
I can't figure out how to reload the stapler with staples
  • 1 more comment
  • Anonymous Oct 29, 2008
    its like stuck or something!!! Arrgh!
  • hecden72 Dec 14, 2008
    Love my staple gun but yes it is a pain to open. The release on the back is to small to grip. I noticed a small gap on the underside by the (really small black grip) found it simpler to just slide it open with a flat screwdriver.
  • Anonymous Mar 13, 2014
    How do I change my power shot 5700 hand stapler from tacks to staples
The staples do not go on the bar you pull back but directly into the bottom once you have pulled the bar back. I was trying to put the staples on the bar at the back and push them into the stapler.
Posted on Dec 05, 2008
I own a Power Sot and the directions are very clear. Squeeze the clip at the back of the unit and pull the spring-loaded clip out. Put your staples in and GO!!
Posted on Oct 13, 2008
How to reload staples.
If this is a staple gun then you need to release the tab on the back of the gun. It will release a long spring with a push rod on it. Insert the new staple bundle and replace the push rod. If this is a desk top stapler then pull the top until it opens. Set staples in and close the top again. Make sure to clear out any staples that may be loose or lodged before.
Nov 29, 2015 | Staples Tools & Hardware - Others
How do you open/refill this stapler?
Push the top of the lever located on the back of the stapler.It will pop out on a spring. Slide a new strip of staples in and push spring/rod assemble back in until it clicks into place.
May 31, 2011 | Ace Hardware Ace Staple Gun
WHERE do I open it to refill it??
Located on the end opposite of where the staples come out, there is a spring loaded cap. Push it in toward the base of the stapler and slightly down to release the retaining hook. then let the spring release the pressure rod and pull it out. Connedted to the end of the rod you will see a plunger that is shaped like a short run of staples. Make a mental note of how and where this plunger slides into the base of the stapler. Place a run of staples into the stapler in the same manner that the plunger fits then replace the plunger into the same place following the run of staples. Compress the spring into the stapler and attach the hook as it was. Now you are ready to work.
NOTE: If you cannot compress the spring enough into the stapler you have inserted too many staples, just remove some of the run of staples and try again.
Nov 12, 2010 | Arrow T50P ARROW STAPLE GUN
Instruction book for Arrow ETF50P staple gun . lost the instructions and can't figure out how to insert the staples in the gun
Look at the rear of the stapler. Push in then down on the stapler tensioner to release it from the rear of the gun. Slide the tensioner out. Next slide the new staples over the rail and into the gun with points down. Slide the spring tensioner back in and connect it to the stapler by maneuvering its clip down and then up.
Apr 19, 2010 | Arrow No.ETF50PBN Extra Heavy Duty...
I have a very old Bostitch staple gun Model T5. It has run out of staples, but I cannot figure out how to put new staples in it.
You should not need any tools to lift the guard/nose piece. The T5 nose piece cleary has engraved on it "Pull Up To Insert Staples". To remove old staples, use a pencil or similar rod to depress the hammer/striker above the staples while the nose is open.
Dec 23, 2009 | Stanley Tools & Hardware - Others
What size staples does the B&G Powershot staple gun use? I bought a refill pack 3/8" & 5/16" long. They fit but the shank when pulled out and loaded with staples won't close. Thank you. Julia Carr
Hi Julia,
You have the right size staples. The problem is the length of the refills. Some staplers can't accommodate a full length clip.
Break the staple refill clip in half, then insert it. The shank will be able to close and latch that way.
Best regards
Mike
Dec 06, 2009 | Black & Decker 5700 Powershot Forward...
There's a jammed staple but I can't figure out how to open it to fix the problem and refill it
This is how it works on the Arrow staple gun. On the back bottom, opposite end from where the staples come out, there is a little plate. Push it in and it unhooks and pops out. attached to a rod. When you refill with staples, just push them in, then put the rod back in and the spring applies the pressure.
May 31, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Loading staples
Hi Sharon. It is absolutely essential that you get the staples designed for this stapler. These are Powershot 5700 staples.
please mark this answer as a fixya! thanks.
Mar 12, 2009 | Black & Decker 5700 Powershot Forward...
Hi can't seem to reload stapler
All you do is open the end peice and slide the staples in on the two rails, point down. You should be able to see in the end to make sure nothing is blocking the rail with a flashlight. You probably have the wrong size staples. You can only use # 214, 215, 276.
Nov 26, 2008 | Arrow T50P ARROW STAPLE GUN
Can't load the stapler
check those staples or take to home store where you and i am sure they will help you figure it out
Nov 20, 2008 | Powershot Tool Company Cobra 8000 Forward...
Arrow 8000 Power Shot Pro Staple & Nail Gun Logo
3,269 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
EugenesDIYDen
EugenesDIYDen
Paul Sikkema
Paul Sikkema
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
