Question about Breville SK500XL Stainless Steel Cordless Electric Kettle
It won't turn off automatically
The scale gaurd has fallen off and i can't put it back on now the kettle does
not turn off automatically
How do i clean the inside of illuma kettle
You can use Lime-Away (at Home Depot) or Apple Cider vinegar. It seems to work much better then regular vinegar. In either case let it boil if it has no element inside the water compartment, put a small clean rag inside and use a wooden spoon to clean the heavier areas. Boil it a few times, then dump it, and boil and clean with clean water twice, then put it back in service.
Feb 26, 2015 | Morphy Richards Illuma 43121 Cordless...
Why won't our BOSCH TWK8633 stay switched on?
You don't say how old your kettle is, but if it is less than 1 month, I would go back to the retailer where you purchased. Make sure you have your guarantee or proof of purchase.... Otherwise, going by past experience, kettles that won't stay switched on usually need de-scaling. Even if you can't see any lime scale in the kettle, there are sediments in the water that will build up over time & that can cause the element to overheat. This makes the kettle switch off prematurely or not switch on at all. In the UK, regardless of where you live, you should de scale your kettle at least once a month. If this doesn't work, you should still go back to the retailer, but if it's found that the malfunction uis diue to lack of de-sclaing, this isn't usually covered by the warranty....good luck!
Aug 09, 2014 | Bosch Styline Collection Kettle Twk8633gb,...
Gainsbourgh stanza 9.5 shower is boiling and water running slowly
it could be your shower is full of lime scale if it an electric shower if so try turning off the power and take the shower front off remove the heater chamber and block off the out let pipe and pour in a kettle descaler and wait this should remove scale then rince and put back together checking for leaks .
Jan 30, 2013 | Home
Fuse box turned off when switch on the kettle
kettle defected check for short or to many plugs on servie line try another plug
Sep 02, 2012 | Russell Hobbs Kitchen Appliances - Others
Scale between the kettle and the base?
I don't particularly know the model of your kettle. There are so many out there. It sounds like the tank is leaking.
Some of these cleaning and descale agents are very powerful and corrosive. The cleaning solutions you are using may have eaten through the tank of the kettle! This is what it sounds like to me.
Check the recommendations in the instruction manual for cleaning this kettle model.
Jerry G.
May 04, 2012 | Kitchen Appliances - Others
I bought the Russell Hobbs Whisper Kettle expecting it to boil quietly. Wrong. It is quite the opposite. Not sure if I can take it back due to "false advertising"??
Have you tried descaling the kettle? When scale builds up over the whisper quiet element, it reduces the effectiveness, and the kettle becomes noisy. Try 1 tablespoon of citric acid, fill the kettle to the max line, boil the kettle then leave for 10 minutes. Rinse and repeat if necessary.
Feb 23, 2011 | Russell Hobbs RHOK3123 Cordless Electric...
How do I remove limescale from inside an elecric kettle?
You could buy in any grocery shop and in the net any brand of KETTLE and THERMOS DESCALER! Just put it in ur electric kettle and leave it for a day, it will disslove those lime scales! Taah!
Nov 12, 2010 | Morphy Richards 43072 Cordless Electric...
My kettle does not turn off when boiling
this is more likley to be the switch its just a bimetallic type,when it gets hot steem on it it flicks the switch to turn the kettle off try giving it a realy good clean up inside around the switch it may just be lime scale blocking the vent hole
however normaly when the switch playes up its a new kettle
Nov 03, 2009 | Russell Hobbs RHOK3123 Cordless Electric...
Kettle not switching off after boiling so carrys on boiling untill you turn it off
To state the obvious, the steam sensor has failed. Unless you are quite adventurous, and confident dealing with electrics, there's nothing for it but to get a new kettle (unless the kettle is still within warranty, in which case you should be entitled to a replacement of course).
Oct 11, 2009 | Morphy Richards 43025 Electric Kettle
Siemens porsche kettle on/off switch problem
Make sure that the lid is securely on. Otherwise its the replacement of the auto bi metalic strip which turns the kettle off
Feb 14, 2009 | Breville SK500-XL Stainless Steel Cordless...
Breville SK500XL Stainless Steel Cordless Electric Kettle Logo
78 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
